01-06-2010, 09:01 AM | #1 |
Contractor Needed in Laconia
Hi Guys,
I am looking for referrals for a contractor to do the bathroom Over in our cottage Very small 4x8 bathroom, but basically a complete gut and start over, Need it done before Memorial day Need to move some drain lines, extend some fresh water lines Install new shower unit, pedistal sink, new toilet and wall cabinet (have these purchased already) replace subfloor and floor re-sheet rock walls where needed from renovation maybe some electrical but do not think so Looking for a trustworthy person to do the job without me having to be there becuase I am from MA and would then need to drive back and forth But I will be there to show the job and get estimates. Hoping this will not kill the budget
Capt. of the "No Worries" |
01-06-2010, 10:06 PM | #3 |
Granite Creek Properties
Look into Granite Creek Properties, Steve Dami, in Belmont
455-5670 www.granitecreekproperties.com He's doing a bedroom remodel for us in South Down and is very reasonable, is doing a great job, and has excellent sub-contractors. |
The Following User Says Thank You to thebix For This Useful Post: | ||
AC2717 (01-15-2010) |
01-06-2010, 10:37 PM | #4 |
Tom Kuziel
I have had Tom build out several rooms including a bathroom. He is terrific!
1 (603) 393-5000 Jetskier |
The Following User Says Thank You to jetskier For This Useful Post: | ||
01-07-2010, 05:29 AM | #5 |
Give Rick Achenbach a call as he is the owner of Granite Shore Builders out of Moultonboro the office number is 279 8600 or his cell phone 455 4939 great work done by this contractor and tell him David referred him
The Following User Says Thank You to hoopdawg For This Useful Post: | ||
01-13-2010, 08:27 PM | #6 |
i can help if your still looking for a carpenter?
hello my name is Shaun with Skys Carpentry. there are many good carpenters in the Lakes Region and by all means talk with as many as you can without wearing yourself out. i do on an average of 3-5 bathrooms every year. if theres anything i can do please don't hesitate to call or visit our site thanks and good luck. www.skyscarpentry.com by the way we use a very good plumber here in Moultonboro and he is reasonable.
The Following User Says Thank You to sky's For This Useful Post: | ||
01-15-2010, 09:12 AM | #7 |
Bobby G's Contracting
I refer all my customers to Bobby G's Contracting out of gilford. we do property management and house checks for many vacation homes throughout the area and have never been let down by him when reffered. I have had him quote many jobs for me as well and he is very reasonable, just a good guy making a living, not trying to get rich.
His number is 455-5535. |
The Following User Says Thank You to sasquatch For This Useful Post: | ||
AC2717 (01-19-2010) |
01-15-2010, 02:07 PM | #8 |
Tradesmen Builders
Tradesmen has done several projects for me (including building me a new house). 524-5357 Ask for Larry or Rich.
01-15-2010, 03:20 PM | #9 |
David Gammon
An independent builder/contractor in Laconia. No job is too small or big for that matter. He's been around for 40 years. Very reasonble price and knowledgeable. I would give him a call at 603.528.1089
01-21-2010, 01:19 PM | #10 |
Tradesmen
03-11-2010, 04:15 PM | #11 |
home repairs
try eric's & phil's home improvement at 603 509 3880. they do great work and do it right.i live in mass and they keep up on my summer house in alton and my house in mass.good people for the job. no job to small or big they will do what you want or they have some good ideas to work with too.
03-14-2010, 10:32 AM | #12 |
03-14-2010, 11:52 AM | #13 |
I know you have already bought your supplies... but for others considering a bathroom redo, or adding a new bathroom, or upgrading a cabin, consider composting toilets, an inexpensive way to add capacity in your home or bringing the bathroom in from an outside outhouse.
My store Sustain Ability (www.sustainabilitynh.com) sells Sun-Mar composting toilets - inexpensive, odor-free, good for the environment. People who haven't used a composting toilet say "odor-free?" because it goes against their image of a toilet that doesn't flush. The electric units have a fan that draws air in through the seat area and expels it through a vent pipe; the non-electric models have a chimney-stack like vent system. Both whisk odor away from the house. Composting toilets are legal in New Hampshire. The only place you will have a problem is if you are building a new home and want to eliminate the (unnecessary) septic system. Most places require you to put a septic system in and pretend to use it... even though composting toilets are better for the environment. There are two types of composting units - self-contained systems (toilet is also the compost chamber) and central unit systems (where one or more toilets empty into a composting tank usually in the basement or crawlspace under the house). Self contained units are easy to install (open box, put in place, drill hole for vent, put up vent pipe, plug in fan and start using). They range from around $1500 to $2000. Capacity for a self-contained unit is 2-4 full-time, 3-6 weekend use. See http://www.sustainabilitynh.com/prod...osting-toilets for a picture. Central system units are slightly more work as you need to cut hole in floor, position drain pipe, put toilet in place, position unit in basement arrange vent pipe, plug in and start using. There is an option of a flush toilet (1 pint per flush as opposed to 1.5 gallons typical for plumbed toilet) or a water-free unit, which needs to be positioned straight above the central chamber. These units, with one toilet, cost around $2400 - $3000. Capacity ranges from 3-7 full-time and up to 11 on weekends for the largest unit. See a picture at http://www.sustainabilitynh.com/prod...toilet-systems I would be happy to answer any questions on composting toilets anyone has. |
03-30-2010, 07:10 PM | #14 |
Hello
My name is Scott Compton of Scott Compton Builder. I have just joined this forum. If you haven't already chosen a builder, I would be interested in talking to you. I can be reached at my Office/Home 603-279-1029 or my cell phone 603-234-1277. Hope to hear from you. Scott |
04-08-2010, 04:49 PM | #15 |
Welcome
welcome to the forum!
04-18-2010, 01:34 PM | #16 | |
04-18-2010, 09:34 PM | #17 |
Hello All
Thank you for all your help and I have chosen a contractor and I can tell you the referrals and things to know given above, it was very helpful
04-20-2010, 12:22 PM | #18 |
5x8 bathroom..
Need the same thing done to a 5' x 8' bathroom. I'm curious as to how much $$$ this will cost.
04-20-2010, 04:11 PM | #19 | |
04-20-2010, 04:29 PM | #20 |
Sky Carpentry was very good and very professional in meeting with me and going over the costs, and was one of my finalists
04-22-2010, 06:18 PM | #21 | |
My name is Scott Compton of "Scott Compton Builder". I am located in Meredith and was wondering if you have spoken to anyone. My numbers are 279-1029 or 234-1277 or my E-mail address is SCOMPTONBLDR@METROCAST.NET. Feel free to call if I can be of any help. Thank you and have a good evening. |
08-20-2010, 08:52 AM | #22 |
How did it go?
Greetings, I need the same work done on a very small bathroom in my camp in Laconia. AC2717 will you share the name of the contractor you used and how it went?
08-20-2010, 10:52 PM | #23 |
Very Happy
I used Scott Compton two years ago to replace a bathroom including installing a tiled walk in shower with a floor to ceiling glass door, a stand-up washer/dryer and granite counter with recessed sink.
He did a great job. I never once had to call him. He was on the job from when it started until it was completed to my satisfaction. I would have him work in my home anytime! |
The Following User Says Thank You to Winopt For This Useful Post: | ||
Joby (08-21-2010) |
08-23-2010, 01:08 PM | #24 |
Contractor
Hey give Chris Cleveland, 603-455-1720 Very reasonable prices has several reference name of business is CAC Contruction and is register with the State of NH.
