09-02-2011, 09:58 AM | #1 |
Boat gas on pontoon boat carpet
I had a gas tank erupt on the stern of my pontoon boat. I closed the vent prior to Irene's arrival, and left it closed while I was gone. When I returned I found that the tank had apparently erupted due to heat, which spewed gas all over the carpet on the stern.
It's discolored the carpet some, but the smell is really bad. Any ideas on how to remove this smell other than time and air? |
09-02-2011, 12:44 PM | #2 |
Let it dry out then maybe baking soda and water. Just don't let rinse water run into the lake.
Good luck! |
09-02-2011, 03:10 PM | #3 | |
In addition to these: I think the best thing I've done has been to use a "steam cleaner" or "steam vac" - (which don't really use "steam") - but any of the types of machines that soak it with hot water and sucks it away - irrigating the carpet with hot, soapy water. You could even do this with a bucket of HOT water and soap, and a shop-vac if need-be. Heat - not a lot, but a little - like for example, leaving them in the sun (or heated room, or a sun-room), as opposed to a frigid shed all winter long. Obviously, if there is any risk of *fumes*, then *don't* keep them in an enclosed space. - Have to add this for liability ;-) But like I said, you will need time, air and warmpth to get to job from 95% to 100% done! |
09-02-2011, 08:53 PM | #4 |
Time and air will remove the gasoline and its smell but usually not the other stuff in the gas. I would use a detergent, at least some simple green to soak it and then rinse it with clean water. Bk's idea of the steam cleaner is a good way to do this.
I bet the barometric pressure drop during the storm caused your eruption. This is why there is a vent in the first place. |
09-03-2011, 05:48 AM | #5 |
You may want to try this...
http://biogreenclean.com/
I haven't used this product, but I've talked to someone that used it to clean oil spills on a garage floor. He loved it. Good Luck.
"Before you criticize someone, walk a mile in his shoes. That way, if he gets angry he'll be a mile away and barefoot!" unknown |
09-07-2011, 06:54 AM | #6 |
Thanks for all the suggestions.
09-12-2011, 05:30 PM | #7 |
Carpet cleaning
We can come to your location and clean your boat carpets. We use van-mount carpet cleaning. www.greatnortherncleaning.com
