Go Back   Winnipesaukee Forum > Lake Issues > Boating Issues > Speed Limits
Old 10-28-2009, 04:42 PM   #101
OCDACTIVE
OCDACTIVE's Avatar
I could use a little Adrenalin rush!
Well if you really have one, I will definately take you up on it. I have a couple of ads out to trade but if that doesn't happen think up a price and I will take you up on it if it works out.
Any dings on it?
OCDACTIVE is offline
Old 10-28-2009, 04:46 PM   #102
elchase
Guest
Posts: n/a
Two killed in this high-speed crash;
http://www.milforddailynews.com/news...ision-in-Maine
It amazes me how many of these there have been once one looks for them. There are literally dozens of high-speed fatal boating accidents every year. They must be one of those stories that has become so common that the news barely mentions them in passing now. I could probably post another one every five minutes for the next three months if I wanted to stay logged on that long. Given the number of them, it's amazing that we didn't have on eon Winnipesaukee in over a year...oh ya...we had a speed limit.
Old 10-28-2009, 04:46 PM   #103
Default Ocdactive
If you look at the header, its a 25' LH Bravo 1 3 blade. Solid hub. When you ask me for a ride, I couldn't resist!
BroadHopper is offline
Old 10-28-2009, 04:54 PM   #104
OCDACTIVE
OCDACTIVE's Avatar
Ahh.. I would try it but I think the 4 blade is the way to go.. Trust me you are going to get a ride regardless.. I can't wait to test out the new engine next year. I just don't know if I will be putting a paint job on or not...
I may just leave her white and have the A/T symbol painted on (right now it's vinal and have OCD done on the sides and top.)
Old 10-28-2009, 04:55 PM   #105
elchase
Guest
Posts: n/a
Only one lady was killed when this guy slammed into a sailboat, Wonder what kind of prop he had?
http://iteamblog.abc7news.com/2007/0...boat-cras.html
Old 10-28-2009, 04:57 PM   #106
DEJ
Once you get a prop and try it out there are many prop shops that can tweek it for you for optimum performance.
DEJ is offline
Old 10-28-2009, 04:58 PM   #107
OCDACTIVE
OCDACTIVE's Avatar
The paint job will really only depend on what is wrong.. if it is simply 2 pistons then it should be fine. But I was also looking to cut out the compass in front of the passenger and insert an 8 inch GPS. Where the boost gauge is put in a flat compass by livorsi. Pretty cool.. Hoping for new throttles as well.
Hey easy question. My water pressure gauge works but it is only reading like 5 psi as speed when it should be 40. I was thinking of getting a new one but someone said the sender may need replacing. Any experience with that?
Old 10-28-2009, 05:01 PM   #108
OCDACTIVE
OCDACTIVE's Avatar
Are there any around the lake that you know of? someone you can recommend?
Old 10-28-2009, 05:01 PM   #109
elchase
Guest
Posts: n/a
this boat "flipped, capsized and sunk" while "traveling between 90 and 120 mph", killing FOUR people;
http://www.thefreelibrary.com/BOAT+M...SH.-a090640393
Old 10-28-2009, 05:04 PM   #110
DEJ
I will get that info for you, none around the lake that I know of.
DEJ is offline
Old 10-28-2009, 05:06 PM   #111
OCDACTIVE
OCDACTIVE's Avatar
if you look top left you can see the Flat Livorsi compass. The one I hope to have is similar to the size of the smaller bottom gauges.
Old 10-28-2009, 05:07 PM   #112
Default Good Choice
With the 3 blade, I was experiencing blow outs from a standing start or when cornering. The 4 blade cures this. As well as less vibration.
Powerboat Mag ran an article a while ago about a graphic house that prints on vinyl decals for boats. The decals runs the whole length of the boat and claims to be about 5 times cheaper than a real paint job. There is a 5 year warrantee on the vinyl.
OCDACTIVE (10-28-2009)
Old 10-28-2009, 05:17 PM   #113
elchase
Guest
Posts: n/a
Default Fatal Folsom Lake Boat Crash Raises Water Speed Concerns
One dead;
http://www.topix.com/forum/sacramento/TNL3DLDV73ORC0C5L
Old 10-28-2009, 05:31 PM   #114
DEJ
The 4 blade I agree will be the best choice.
DEJ is offline
Old 10-28-2009, 05:31 PM   #115
OCDACTIVE
OCDACTIVE's Avatar
I meant to ask... I have many of the past years PB magazines. Do you know what year? month? or issue it happened to be?
Old 10-28-2009, 05:43 PM   #116
elchase
Guest
Posts: n/a
This one is great for seeing how difficult it is to convict when you don't have a defined limit. The poor girl killed in this crash will probably never get justice; http://abclocal.go.com/kgo/story?sec...eam&id=5832004
Most memorable quote: "The problem is when you don't have a speed limit and you've got to rely on the safe speed laws, the issue is very vague."
And what does this exchange sound like?;
Q: "If Chief Deputy Perdock was going 10 miles an hour, would Lynn Thornton have died?"
A: "I can't answer that."
The Following User Says Thank You to For This Useful Post:
fatlazyless (10-28-2009)
Old 10-28-2009, 05:54 PM   #117
Default Oh Boy.
I have years to go thru! Check these sights while I try to find the article.
http://www.signzoo.com/graphic-wraps/Marine-Wraps
http://www.stickers4u.com/patriotic_graphics.htm
http://www.skinzwraps.com/vinyl-boat-graphics.html
http://www.jaxwraps.com/Our_Services/Boat_Wraps.aspx
Old 10-28-2009, 06:23 PM   #118
OCDACTIVE
OCDACTIVE's Avatar
don't go out of your way.. I really am not sold on vinal.... I like paint.. but it is very impressive!
Old 10-28-2009, 06:45 PM   #119
elchase
Guest
Posts: n/a
Luckily, ONE of the passengers in this high speed crash survived;
http://lakeconews.com/index2.php?opt..._pdf=1&id=9389
Old 10-28-2009, 06:50 PM   #120
Default Paint Experience
When I bought my boat in VA, The previous owner painted the boat with automotive paint. (He was a body repairman) The paint is very fragile. It was cracking, chipping and peeling everywhere! Last year, I had the boat stripped to it's gel coat and repainted with IMRON. Much more durable and expensive! After two summers, it survived very well.
Just thought I let you know my experience about paint.
You can use a gel coat but it is wicked expensive!
Pineedles (10-28-2009)
Old 10-28-2009, 06:52 PM   #121
OCDACTIVE
OCDACTIVE's Avatar
I have heard those stories as well and know to be VERY very careful who does it...
Same reason you never let an auto mechanic work on your boat!
The Following User Says Thank You to OCDACTIVE For This Useful Post:
Old 10-28-2009, 06:54 PM   #122
elchase
Guest
Posts: n/a
A whole family was killed in this one;
http://www.naplesnews.com/news/2007/...y_say_goodbye/
Old 10-28-2009, 07:01 PM   #123
DEJ
I agree OCD. Lot of money one can spend and get ripped off if not careful.
DEJ is offline
The Following User Says Thank You to DEJ For This Useful Post:
Old 10-28-2009, 07:04 PM   #124
Post #115 is all about a California lake, night time collision between a motorboat going 50-60-mph, driven by a local county deputy sheriff sergeant, off-duty, and a sailboat resulting in the death of a women who was the chief investigator for the California Dental Board.
...her dying words....."oh please....getting three defective root canals all at once, would have been less painfull than death by a four-bladed stainless propeller, even without the novacain"......(sorry-couldn't resist....my bad)
...and don't-ya-know....who gets indicted?......not the sergeant......but the sailboat tiller-man for supposed operat'n with no navigation lights.....a claim disputed by several witnesses.....read all about it in #115........verrrrry interesting....
fatlazyless is offline
Old 10-28-2009, 07:11 PM   #125
Pineedles
Pineedles's Avatar
Thumbs up
Hey guys, thanks for the education Props to you!
Pineedles is offline
Old 10-28-2009, 07:14 PM   #126
OCDACTIVE
OCDACTIVE's Avatar
sorry if we got a little off topic but the thread was originally in the boating thread when originally made then it went off subject and it was locked down when SL's weren't being discussed. It was reopened here.
Some trolling may try to take it off track but you have to see past that...
I have learned SO much from forums on different boating aspects it is amazing.
PS: the ignore button really makes it a much more pleasant experience here.
Old 10-28-2009, 07:17 PM   #127
DEJ
I love the ignore function this site offers.
DEJ is offline
gtagrip (10-29-2009)
Old 10-28-2009, 07:22 PM   #128
OCDACTIVE
OCDACTIVE's Avatar
in all seriousness it may not be even be intentional... Many times they build the engine correctly to Auto standards. But they are completely opposite especially from a compression stand point.
Keep in mind a car or truck runs at 2000 - 3000 normally where boats are 3000 to 5000 depending.. Alot more torque and hardship on the engine.
It needs to be compensated for.
Old 10-28-2009, 07:28 PM   #129
Default Boat vs. Auto
A boat is running under constant load. Much like a car running on a hill. So durability and torque is an issue. Most blocks are truck blocks and valve timing is more for torque. I can go on and on.
Old 10-29-2009, 06:30 AM   #130
chipj29
chipj29's Avatar
Originally Posted by elchase View Post
Seems I'm the only one staying on topic today...this is the Anti Speed Limit thread, no? Let's move the engine/prop talk over to the Boating threads and leave this thread to discussion of the dangers of high speed boating.
This high speed collision had four deaths. The driver was going so fast at night that he didn't even see the anchored barge he smashed into. Wouldn't it have been a coincidence if that barge had been named "Eagle Island" or "Diamond Island"? I bet he coudl have stopped in time if he was only going 25;
http://www.atsb.gov.au/newsroom/2008...e/2008_17.aspx
Actually, the topic of this thread is "new boat...see you out there". And that is what is being discussed.
Nice try, but thanks for playing.
And to think you don't consider yourself to be a troll.
Getting ready for winter!
chipj29 is offline
The Following 4 Users Say Thank You to chipj29 For This Useful Post:
brk-lnt (11-03-2009), fatlazyless (10-29-2009), Resident 2B (10-30-2009), robmac (10-29-2009)
Old 10-29-2009, 07:54 AM   #131
elchase
Guest
Posts: n/a
But the title of the section is "Speed Limits". There is a "Boating" section to talk about new boats. This section is to talk about speed limits and things related. The reason this thread was started in this section is obvious...and therein lies the trolling.
Here's one in which a guy plowed into a pylon at 70MPH;
http://www.theleader.com.au/news/loc...4.aspx?src=rss
ouch.
Old 10-29-2009, 08:10 AM   #132
jmen24
But if your memory was as good as you think it is, then you would remember that this thread was started in the Boating section. It was moved to the Speed Limit Sub-forum after it got off track, and understandably so, if this was my boat I would be talking about how fast I would like to go with it as well.
jmen24 is offline
The Following User Says Thank You to jmen24 For This Useful Post:
chipj29 (10-29-2009)
Old 10-29-2009, 08:20 AM   #133
elchase
Guest
Posts: n/a
It is in the Speed Limit section now. You guys turned it into a speed limit bashing thread so it got moved. Go back and start a new thread about props and new boats in the Boating section and stay on topic and it won't get moved and I won't take part.
Old 10-29-2009, 08:28 AM   #134
OCDACTIVE
OCDACTIVE's Avatar
Thanks Jmen24... I appreciate it but it is best not even to bother. Most everything he writes now is blocked by most of us so we don't even know or care what he is saying. You may want to do the same.
Thanks for the support. I really am excited about the boat. Saved for 4 years and worked very very hard to get the one I wanted. It was a shame it only lasted 12 hours last season but it gave me a good excuse to save for upgrades and gas for next season.
I am hoping to set up a meeting some weekend so that all of us can meet face to face and maybe do some runs up and down the lake. I am always up for giving rides if you are interested.
Take care!
robmac (10-29-2009)
Old 10-29-2009, 08:28 AM   #135
jmen24
Let the guy talk about his boat, that was the original intent of this thread. You started a thread on sailing and based on the number of people ignoring you, you would be able to talk to yourself till you are blue in the face about something you enjoy without anyone bothering you.
If OCD wants to discuss props for his boat in the thread he started about his boat than let him. We are not in high school anymore, it is time to grow up.
I am taking my own advice, the button has been pushed!
jmen24 is offline
Old 10-29-2009, 08:36 AM   #136
Ryan
Ryan's Avatar
How did the speed limit not work here?????
And how did the Maine Legislature shoot down the proposed speed limit after the Long Lake conviction?
Please do not feel the trolls.
Ryan is offline
Old 10-29-2009, 08:50 AM   #137
elchase
Guest
Posts: n/a
Here's one where a formula "traveling at a high rate of speed" crashed and killed two people;
http://www.newstimes.com/brookfield/ci_9929801
Old 10-29-2009, 09:03 AM   #138
Ryan
Ryan's Avatar
Hmmmmm....didn't I just post that above. Doesn't help your cause.
A lake with a Speed Limit, and there was a boat crash with a fatality?
Let me guess, a speed limit doesn't stop ALL high speed crashes???? Maybe he was drinking....
Ryan is offline
Old 10-29-2009, 09:09 AM   #139
sunset on the dock
Don't know about you but I don't want all highway speed limits repealed just because a drunk may not obey them. BTW, cops often pick up the DUI's because they're being too careful to obey the speed limit and going significantly below the speed limit.
sunset on the dock is offline
Old 10-29-2009, 09:19 AM   #140
elchase
Guest
Posts: n/a
So a drunk boater going too fast crashes and kills two people and this somehow makes the argument that boats should be able to go as fast as they want? Should CT's BUI law be repealed too, since he didn't obey that? At least now they can throw the book at him. Had there been no BUI or SL laws, maybe he would have walked. But maybe that is what some of you guys are really concerned about....getting off after you've killed someone.
sunset on the dock (10-29-2009)
Old 10-29-2009, 09:52 AM   #141
OCDACTIVE
OCDACTIVE's Avatar
Having second thoughts of putting in the flat compass in the dash. They don't make a size that will match and will have to put a fitting or housing in the open hole for it to fit.
I already have a depth gauge. so if you guys have a second any thoughts as to what other gauge would work here? I think I have everything covered but am definately up for suggestions.
Threw the last picture in as a fond memory.
Old 10-29-2009, 09:54 AM   #142
Ryan
Ryan's Avatar
Sorry, you cannot have it both ways.
Ryan is offline
Old 10-29-2009, 10:25 AM   #143
hazelnut
hazelnut's Avatar
2008 - Connecticut
hazelnut is offline
Old 10-29-2009, 10:32 AM   #144
elchase
Guest
Posts: n/a
It is you that cannot have it both ways. I only want it one way. I want it just like last summer from now on.
Originally Posted by hazelnut View Post
2008 - Connecticut
So what? 9-11 was in NY, does that mean it is not of interest to Granite Staters? Are the people in NH constructed differently?
One dead in this one;
http://www.live5news.com/Global/story.asp?S=11280141
Old 10-29-2009, 10:48 AM   #145
DEJ
Hnut, use the ignore function, it works great.
DEJ is offline
Old 10-29-2009, 10:49 AM   #146
elchase
Guest
Posts: n/a
Here's another fatality in NJ;
http://www.nj.com/news/index.ssf/200...ounts_key.html
Old 10-29-2009, 10:52 AM   #147
DoTheMath
Default Ignore?
Hmmm... I like that idea, show me the way people, show me the way!
DoTheMath is offline
Old 10-29-2009, 11:01 AM   #148
DoTheMath
OCD - You should have Pat do it for you, it's 1/2 way there now, so might as well tow it the rest of the way down and get it done right. You know he'll treat you right on the price and do an amazing job! Just keep it classy and "resellable" cuz you know you'll be buying a 33' in a few years and you don't want to have the same (potential) issue that SL had - although I personally loved his paint job!
As for the water pressure gauge, where is the sender located? I used to install them up by the t-stat housing, or down low in the block and run a full mechanical gauge - so water line all the way from sender to the dash, don't do a mechanical / electric, not as accurate or reliable.
For the empty hole, do you have a clock? How about oil temp? Or drive lube temp? There are a bunch of valuable gauges you can install - the more info the better!
Old 10-29-2009, 11:02 AM   #149
OCDACTIVE
OCDACTIVE's Avatar
No problem. I have been getting this same request thru my PM's so I might as well tell everyone:
Go to: User CP - at the top of your screen
Left side Go to: Edit Ignore list
Enter: el.... oops I mean the person you want to ignore.
You will no longer get notified of the posts and they do not appear (Great function)
only thing you see is if it is copied from another user.
Happy Un-trolling.
Old 10-29-2009, 11:03 AM   #150
elchase
Guest
Posts: n/a
Another one in FL takes the life of another 17 yr old girl. The boat entered the harbor "at a high rate of speed," officials said;
http://www.allbusiness.com/safety-ac...3127527-1.html
We should go back to letting cowboys like this decide how fast they want to boat, eh? Then we can start having deadly accidents like these again. (he said facetiously)
Old 10-29-2009, 11:03 AM   #151
Default Ignore Function
Go into the person's profile and click on the ignore function. You won't be able to see his posts but you will be able to see his quotes in those replies of people who are not in the ignore list.
robmac (10-30-2009)
Old 10-29-2009, 11:06 AM   #152
OCDACTIVE
OCDACTIVE's Avatar
I think I may just end up putting the OCD on the sides with the AT Oval / logo on the back.. It is easy enough for someone to paint over.. but honestly this is my "step up" boat. I originally was going for the 25 and someone said I would want the 28 years to come. So I waited and did my inital step up..
My wife would kill me if I ever wanted to go bigger. Plus on the logistical side I don't have the huge $$$$ to do that..... (opposed to some peoples thoughts we are not all 200K trust fund babies).. So I am at my limit especially with a young son and who knows when the second will come.
As far at the gauges and senders................ You and I are gonna have to hang out! Great ideas.. boat is in VA so I don't know where the sender is coming from. I will ask the guy rebuilding to take a look before I start replacing expensive gauges.
Old 10-29-2009, 11:07 AM   #153
elchase
Guest
Posts: n/a
But it's not the eight of you that I am posting this stuff for anyway. I just want the rest of the readership to understand how widespread this carnage is and how lucky we are to have ended it (fingers crossed) in NH. You eight are never going to appreciate the danger in what you do, but I'm showing everyone else what is going on all around us. And it's very hard for me to accept that OCD is not peeking anyway. Maybe even he will be converted once he sees how massive this problem is that already took the life of my dear friend.
I was going to keep posting these accident reports every few minutes; one after the next. There are enough to do this for months, but I've just been put on a five posts per day limit, so I'll only be able to post five times a day now. At that rate, I'll be able to post pretty much for ever, because there are probably more that five fatal high speed accidents every day. Don't know why anyone who boats would not want to know how common this problem is and how dangerous high-speed boating is.
Old 10-29-2009, 11:07 AM   #154
DoTheMath
Thank you!
Old 10-29-2009, 11:08 AM   #155
Seeker
Seeker's Avatar
Man, I didn't know it existed. Thank you very much.
Seeker is offline
Old 10-29-2009, 11:11 AM   #156
Thumbs up Gallons per hour.
How about a Flowmeter? With gas prices going up, it is important that you know your GPH at any rpm.
http://www.floscan.com/html/blue/ser...sid=14&catid=2
Old 10-29-2009, 11:14 AM   #157
OCDACTIVE
OCDACTIVE's Avatar
I know. Someone PM'd me the info a little while ago.. It just wasn't worth dealing with anymore.. It has made the forums enjoyable again. Don't get me wrong I like a spirted argument and enjoy discussing topics, even when they get heated. There are just those who have motives to get the threads shut down and pretty much will say anything to move their agenda along. So again that function helps weed that unpleasant aspect out.
Old 10-29-2009, 11:16 AM   #158
OCDACTIVE
OCDACTIVE's Avatar
OH GOD NO!! I don't even want to calculate that.... thanks though.
I actually heard a salesman say to a first time person purchasing a boat when they asked what MPG do you get? He responded: If you ask that question you shouldn't be buying a boat. Wow was he right.. LOL
Old 10-29-2009, 11:25 AM   #159
Seeker
Seeker's Avatar
Default New TIDF guage
OCD, I think they make a TIDF (Troll Identification and Direction Finder gauge) that will fit right in a 2 1/8 in hole.
Seeker is offline
The Following User Says Thank You to Seeker For This Useful Post:
Old 10-29-2009, 11:28 AM   #160
OCDACTIVE
OCDACTIVE's Avatar
LMAO!!!! I literally just choked on goldfish.. Thanks I needed that...
However you should patent that idea quickly.. I think there would be huge market for those. You could put your advertisement at the top of the page.
Old 10-29-2009, 11:34 AM   #161
OCDACTIVE
OCDACTIVE's Avatar
hey dothemath.. so can I convince you to tow to Jammin this year?
Old 10-29-2009, 11:38 AM   #162
Default lake Norman
I will be heading down to Lake Norman in NC for the holidays. My sister lives in a lake association. They pretty much boat year round down there.
There are some bad butt boats down there. It is the NASCAR racers playground. I thought I saw some toys here on the big lake. You should the babies they have down there!
They have the biggest rafting party ever! Spreading from one end of the lake to the other!
OCD maybe you can do a preseason test in NC. I'm sure sis would not mind a couple of boaters for a weekend.
Old 10-29-2009, 11:39 AM   #163
OCDACTIVE
OCDACTIVE's Avatar
Not a bad idea.. how far out of richmond is that?
Old 10-29-2009, 12:35 PM   #164
DoTheMath
Sounds good, I believe that "less is more" at times when it comes to paint on a boat, esp. if it's a nice boat with nice lines like the AT's.
And if you need / want any help with the mechanical stuff - rigging, etc... let me know - be happy to help. I always seem to be doing something to my boats, I just enjoy the work and doing it myself, that way I know it has been done right and the process behind it. I had bought a brand new (factory order) Formula back in 2000, had Lingenfelter power in it, I spent about 50 hours on the boat before I took it out the first time. I pulled the dash panel and all the gauges, repainted the panel, added / replaced gauges, mechanical indicators, etc... It came out nice - then sold it to a guy on L. Tahoe a year later.
This is what you have to look forward to with your little guy, this is my son a couple summers ago at 2 1/2 y.o. - he's 4 1/ 2 now and loves being out on the water!
Old 10-29-2009, 12:38 PM   #165
DoTheMath
You can try - but not sure that'll happen, but... I never say never!
Old 10-29-2009, 02:00 PM   #166
About 4 hrs and 15 mins down I-85. You can meet me there and we can bring the boat back up here together.
Old 10-29-2009, 03:45 PM   #167
VtSteve
With the GPS, I didn't have much use for the speedo anymore. That was a good thing, because my "seasoned" mechanic didn't hook up the cable after they aligned the drive.
OCD, I've heard that the 28 AT is pretty darn competent in big water. From what I've heard about Lake Norman, that would be an interesting test. There are a few larger boats, say 33, that have great headroom in the cabin, 6' and as high as 6'7. That would make for a great dual purpose boat as well.
I've heard there's definite interest in adding more diesel power to models as well. The increase in mileage is extraordinary.
VtSteve is offline
Old 10-29-2009, 04:05 PM   #168
I think I here OCD screaming as BH twists on his arm!!!!!!!!!!!!
LIforrelaxin is offline
Old 10-30-2009, 11:07 AM   #169
elchase
Guest
Posts: n/a
I guess can understand the desire of those who want to boat at unlimited speeds to see this stuff stifled. It is pretty devastating to see how many high-speed boating collisions we have every year and how many people usually die in them. I can see why some want to keep me limited to five posts per day so information like this is not seen. But I can’t understand the argument that this is less relevant in a Speed Limit thread than someone’s new prop.
FIVE dead and nine injured when this guy “slammed into a docked tug boat”; http://www3.signonsandiego.com/stori...-crash-041309/
Old 10-30-2009, 11:12 AM   #170
DEJ
I can hear him scream as well.
DEJ is offline
Old 10-30-2009, 11:37 AM   #171
VtSteve
I experimented with props both last year and this year. Last year was with a 21" Rev 4, which proved to be too large. This year, I tried a 21" Laser II, which is still on the boat.
The stock prop was a 21" Black Max aluminum. So far, the Laser II has dropped RPM's by about 400, and the speed is down as well. Since this summer was somewhat time-challenged on the water, I didn't have the opportunity to do more scientific testing, eliminating other variables, and doing a head to head alum/SS test under identical conditions.
I will say one thing about the Laser, it was far more efficient than the aluminum blade, and gave the boat better steering control, and much better cruising attitude.
VtSteve is offline
Old 10-30-2009, 12:04 PM   #172
chipj29
chipj29's Avatar
Not sure who is being stifled here. People are choosing to ignore you on their own.
And from the article, I am not sure where this accident is directly related to speed:
"Joy Hill, spokeswoman for the Florida Fish and Wildlife Conservation Commission, said investigators are looking at several factors including speed, capacity of the boat, lighting and whether people were drinking".
Of course there are horrible boating accidents that happen all across our country. No one here has disputed that. But the relevance of these accidents, especially those accidents which were not directly related to excessive speed (in excess of 45/25), is being disputed.
chipj29 is offline
The Following User Says Thank You to chipj29 For This Useful Post:
OCDACTIVE (10-30-2009)
Old 10-30-2009, 12:09 PM   #173
OCDACTIVE
OCDACTIVE's Avatar
Wow I step away for a little while and everyone comes online..
Lets see:
Dothemath: Yes please if I can take you up on the offer.. Whatever I can't get done in VA, perhaps you could give me a hand? That would be awesome. I also would love to do the work myself but I am timid to do anything because I do not have the experience. I have friends that work on cars and such but again I would prefer someone with marine experience. So if you are really up for it that would be GREAT! Also, I just can't wait to have my son at the wheel. Only good times to come! As far as jammin on the james.. Seriously, if you go once you will never stop. It has become a yearly family tradition. It is set up so well and the people are so helpful. Let me know if you need details for I am very good friends with the organizers (actually one of them is doing the rebuild)
BH: I seriously would love to head down that way. I have friends who are there... It will really all depend on when I go to get her next spring and if she has been tested. If she has been then I might just take you up on that. If not I may have to do the testing on the James river with the mechanic. But I will definately keep that in mind. I am sure we will have some good times next season regardless of where.
VTsteve: The 28 has incredible room. If you look at the AT its cockpit depth is about 1-2 feet greater then most any other brands. Reason being is its top goes as high up as the windshield on other different models so the bow is higher to begin with. This is why there is so much headroom on the A/T's. Not to mention the extreme Deep hull. This allows for it to crush waves like a 30 ft (insert other brand here) . Like I said whenever you want to check her out I am up for it! Just ask Kracken, he's seen her in person.
APS: you mentioned this thread in a different thread but to bring the conversation back to the proper thread: again this was originally in the boating section, it was moved when the discussion went off on a tagent. I do not have the ability to move it back. It is fine here for this way the discussion, if it does get off subject again on SL (due to the type of boat I have) is fine. You can take off your law enforcement badge now.
As for my engine being abused. Please tell me where you got that data? I had a professional survey done and know the previous owners. They are maticulous with their servicing. So if you know now of why my engine (that you have never seen or have experience with) has issues please enlighten us all. That would be a wonderful talent that you should share with not only me but the world. A man able to diagnoss engine failure without running a test or seeing it.
As far as the polling goes, the compromise poll was the first poll made. Then it was argued "by supporters" that if we had a poll that was "one way or the other" that the result would be entirely different..... Well that didnt happen so now lets attack the poll???
As far as having my boat painted and fixed in VA, how do you know I didn't solicit people in the lakes region. Fact is I did and was told by many different marinas around the lake that they couldn't handle the job. Do you think I wanted to tow a boat 12 hours straight? taking time off work? risking damage to the boat on such a long tow? Think will you before you speak. If you also search my threads: I have asked if their was any specialized painters in the lakes region. Again there wasn't any that would fit the position.
Anyway, Thank you everyone for the help and suggestions on the new boat. This website just goes to show what people can accomplish and figure out if issues are brought to light. I really do appreciate all the help. Please keep the ideas coming.
cheers!!
Old 10-30-2009, 01:48 PM   #174
hazelnut
hazelnut's Avatar
Forget it chip it won't register with him. He is lost in his own little world. Facts do not apply in this fantasy land. Only painting this picture of horror and tragedy that has absolutely nothing to do with reality. I for one am enjoying the show. He reinforces the stereotype of the typical SL supporter with every post. Fear and scare tactics, facts need not apply.
hazelnut is offline
Old 10-30-2009, 04:06 PM   #175
DoTheMath
Absolutely - once you get it back, figure out what's left and we'll tackle it. If you can get any preliminary info (before you get it back) on what holes in the dash you'll want to fill /add to etc, that will be good for planning purposes. I've got a bunch of tools, (rotary cutters, etc...) so don't buy anything like that, I'm sure I have just about anything we'd need. As for Jammin' - I'll think about, I know it's a good run - it's just a logistical / timing thing.
Now we get to wait out the winter - it's gonna be looooong I'm betting!
Old 10-30-2009, 08:34 PM   #176
Yawn...
Yawn...
Yawn...
Yawn...
Yawn...
Yawn...
Yawn...
Yawn...
Yawn...
Yawn...
Anyone else falling asleep from the repetitiveness?? Wait, there's more...
Double yawn...
I can't take anymore, I am going to sleep. Shake me if anything changes
codeman671 is online now
Old 10-31-2009, 06:54 AM   #177
Smile Let's Attack the Poll...
Originally Posted by Lucky1 View Post
Don't we all want a safe lake for all? I mean why boast about breaking the rules? Not a good example for young people either.
No kidding! I should have entered this discussion from day-1, but it reads like the chatroom at SOS.
Things picked up about 2005, when SOS noticed that a whole lot of subscribers were dying in Poker Run collisions—(plus making victims of a few of those other boaters of no great consequence). The SOS forums disappeared into smoke-filled chatrooms—hidden from view by us "ordinary boaters".
Originally Posted by Boater View Post
"...Do you realize that the Marine Patrol reads this forum? You've showed them pictures of your boat and made it clear that you intend to come here (from NY?) and intentionally disregard the law..."
Not only that, but isn't the owner in the demographic age category of "highest-risk"—like Erika?
"...The driver was going so fast at night that he didn't even see the anchored barge he smashed into..."
That was in Australia: I guess the owner never had a chance to vote in any of OCD's poll(s).
I guess you missed the nine that died colliding with an anchored barge near my former home—this June.
Please: Have that—and any other hormonal or chemical stimulations—away from the lake. Wait a minute! You can get an Adrenalin rush in any sailboat off Rattlesnake Island!
"...Two killed in this high-speed crash;
It amazes me how many of these there have been once one looks for them. There are literally dozens of high-speed fatal boating accidents every year. They must be one of those stories that has become so common that the news barely mentions them in passing now..."
Those accounts will eventually disappear from the Internet: make hard copies. You can duplicate them as you discuss these collisions with legislators concerned about drunk and reckless boating. (Unless a Citizen headline makes a meeting moot, that is).
When used as "blinders" by a cult, it's not in the spirit of free exchange of ideas—but you knew that already.
"...Actually, the topic of this thread is "new boat...see you out there"..."
It's a "Vanity".
(Meaning, a vain exercise, sometimes with only one contributor).
BTW: Don opened the "Donate" button open months ago: I suggest everybody here—particularly all contributors at these Anti-Speed-Limit threads. (That's where oversized photos of oversized boats (and overlong mutual-admiration of each other's—whatevers) has been using up bandwidth all season.
"...You started a thread on sailing and based on the number of people ignoring you, you would be able to talk to yourself till you are blue in the face about something you enjoy without anyone bothering you..."
Except for weather and wakes, sailing has no death-dealing controversies to keep the pot stirred. Too many sailing fatalities are produced as a result of the overextended throttles of their two- and three-engined ocean-racers who speed across inland lakes without considering other boaters.
"...We should go back to letting cowboys like this decide how fast they want to boat, eh? Then we can start having deadly accidents like these again..."
Please. Two headlines in recent memory are enough.
"...I will be heading down to Lake Norman..."
Finally, some good news!
Please ask somebody at Lake Norman how many survived the Baja that launched from Lake Norman, jumped the guard rail onto I-75, and hit a truck!
I never saw a followup, and elchase will want to have a printout.
"...this is my son a couple summers ago at 2 1/2 y.o. - he's 4 1/ 2 now and loves being out on the water...!"
Has The Cult been reading the warnings and disclaimers on the newest PFDs? (Don may have a copy of the exact wording).
"...APS...to bring the conversation back to the proper thread...You can take off your law enforcement badge now...As for my engine being abused. Please tell me where you got that data...?"
Right here:
Just bought her yesterday.. Look forward to seeing you all out there!!!!
You got 12 hours out of the engine, and don't consider that abuse?
"...so now lets attack the poll...???
OK.
The most accurate poll could have been answered in one week—an option available to you that wasn't used. In that time, the majority of Winnipesaukee.com forum users (ONLY!) could have voted in that poll.
"Word" gets out to SOS and dozens of SpeedFreak websites, and the voting goes on and on and on. One of your cult can even be read complaining to a sympathetic Volkswagen website!
"...risking damage to the boat on such a long tow...?"
The boat? Discounting the risk of injury to others?
Seems to be the trend.
"...As far as having my boat painted and fixed in VA...I...was told by many different marinas around the lake that they couldn't handle the job...Again there wasn't any that would fit the position..."
Sorry that no skilled New Hampshire workers could meet your demands: a 1½ hour drive through NH probably took you past someone who could have used the work. (Not that I'd ask for altruism during a period of high unemployment). A 12-hour drive probably took you past a hundred willing workers.
I don't "get" the need to paint gelcoat in the first place: it's like painting aluminum canoes—and only FLL does that!
ApS is offline
Old 10-31-2009, 07:36 AM   #178
Thumbs up Winter Activities
After the boat is put away, I usually hike until the snow flys. Then head for the hills for skiing. I have a sled but only use in when the gang says 'Let's go!' I am a Winnilaker. A bunch of folks who like to raft together and sled together. We have an annual rafting party of Badger Island every year and an annual ski/sled party up at the Beacon in Lincoln. I keep myself busy year round. I get bored easy. Anyone is welcome to join the WinniLakers. A fun group.
Old 10-31-2009, 07:43 AM   #179
Default Nice to have a weekend get together
Not sure where everyone lives. We can pick a place within easy drive to go. A little bit of a family place in case one has to bring the family. I'm suggesting Heat (JT BBQ) up at the Weirs. Close to Meredith as well as the Weirs. It is not crowded and there is no music to drown out the conversation. Any suggestion?
Old 10-31-2009, 12:29 PM   #180
Default Did you use it??
It's a "Vanity".
Right here:
OK.
Did you use the donate button? You are using more BW than anyone else on this forum by "parsing" text and attaching that silly image to everyone of your posts
BTW: I used the donate button.
You don't need to get why anyone does anything or chooses where to have work done- see, this is a free country and we are still allowed to do pretty much as we please with the things that we have worked hard to earn. I sent the heads from my 70 Olds 455 to California to be ported and polished by a guy named Joe Mondello. Perhaps I could have found a local shop to have the same thing done, but Joe is the guru and I felt it was worth the shipping$$.
Abuse? There isn't a motor built in this country that can't run at WOT for 12 hours- obviously some component was weak and gave up the fight. What if it were a sailboat that you bought used and a sail ripped- would that be abuse??
I don't use the ignore button, but when some JA floods the forum with stories that don't even back up his point, I become tempted.
You on the lake today?? I was and didn't see a single sailboat out there especially one with someone wearing a hat with 2 Nat King Cole CDs glued to it.
VitaBene is offline
The Following 2 Users Say Thank You to VitaBene For This Useful Post:
OCDACTIVE (10-31-2009), robmac (11-01-2009)
Old 10-31-2009, 04:40 PM   #181
Cal
Cal's Avatar
It's amazing how you had to search world wide for a few storys and some weren't that fast anyway. Now lets hear some stories about speed that don't kill.
Oh, thats right, nobody speaks of those
Cal is offline
Old 10-31-2009, 07:21 PM   #182
elchase
Guest
Posts: n/a
Can't find any recent high speed boating accidents on Winnipesaukee to report...oh yeah, that's because we've been basking under the protection of a speed limit.
They should consider a boating speed limit in VA, where accidents are on the rise. I guess "education" and "enforcement of existing laws" didn't do the trick for them either;
http://norfolk.injuryboard.com/misce...oogleid=270684
Old 11-01-2009, 07:44 AM   #183
hazelnut
hazelnut's Avatar
HA HA HA HA HA HA
Best ever! The best post ever by elchase.
Thanks for the morning laugh!
hazelnut is offline
The Following User Says Thank You to hazelnut For This Useful Post:
Cal (11-01-2009)
Old 11-01-2009, 01:17 PM   #184
Airwaves
I think he got his Masters Degree in revisionist history in college!
Airwaves is offline
Old 11-01-2009, 08:10 PM   #185
OCDACTIVE
OCDACTIVE's Avatar
will all depend on when... I would be willing to have it at my place.... Get the gang of 8 together.. Although, I don't even know who makes up that gang..
Sunset is welcome as well. Very spirited night.. actually could be fun...
I was actually hoping that there might be a winter party for winni.com members.. any idea if they have ever done that? Mount might be tough.. LOL
Old 11-01-2009, 08:38 PM   #186
elchase
Guest
Posts: n/a
This looks like a similar 38' performance boat that flipped in MD "traveling at a high rate of speed" with four persons onboard. All four individuals were ejected from the vessel, but ONLY one died. Wonder what kind of prop he had;
http://www.stmarystoday.com/News/Hig...nPatuxent.html
Old 11-01-2009, 08:38 PM   #187
Default Forumfest is once a year.
As most people here are summer residents.
If there are only going to be 8 of us, we can rotate the meetings among the 8 homes.
SOTD and APS will be the highlight of the party! I'm sure they will be civil.
I will be on Lake Norman for a few weeks in Nov., Dec. time frame. I will be spending Thanksgiving with my sister in Mooresville.
If everyone sleds or skis in the winter we can get together for a day of fun this winter.
Old 11-02-2009, 07:09 AM   #188
Yosemite Sam
Default Why?
Does it make you feel good to post images like this? Probably one of the images was taken with the Tattle Tale switch being on. But why post it in the first place?
I really don't think that you are mature enough to pilot a boat with the potential of reaching speeds over 45 MPH.
Yosemite Sam is offline
Old 11-02-2009, 08:25 AM   #189
chipj29
chipj29's Avatar
How about "high speed boating accidents" on Winnipesaukee that happened BEFORE we were basking under the protection of a speed limit (which was implemented on January 1, 2009)??
I agree completely. It is completely immature to post a picture showing what his prized possesion is capable of.
chipj29 is offline
OCDACTIVE (11-02-2009)
Old 11-02-2009, 08:49 AM   #190
Yosemite Sam
Those images aren't showing what his prized possesion is capable of, but what it might just be actually doing.
I think you know what I'm getting at but you just have put your own spin on it.
It just seems immature to post such images about how fast he was going at sometime during the operation of the boat...and if he wasn't on any Lake or Pond in NH doing that speed, why dosen't he just say so.
I don't get it
Old 11-02-2009, 09:02 AM   #191
OCDACTIVE
OCDACTIVE's Avatar
How do you know those were taken on the lake? If you read back you will see this was not supposed to be turned into a speed limit thread. It was posted in the boating sections at the beginning of the year before the speed limits were being discussed. It went off on a tangent and ended up here.
As for posting pictures it was in the discussion about the boat itself and I can see the relevance.
As for your beliving I am not mature enough?? Personal attacks will get you no where on here. keep it civil....
Old 11-02-2009, 09:16 AM   #192
hazelnut
hazelnut's Avatar
Sam, while I generally enjoy your posts I feel like you are being a bit harsh here? Why? Why are you calling another forum members maturity into question in reference to a photo of a Speedometer? The title of this thead is "New Boat... See tyou out there." The originator of the forum was excited and proud of his new toy. So he subsequently posts various photos and now his maturity is called into question.
Look it's one thing not to understand someone's passion. Harley Riders like loud pipes, Snowmobilers like zipping across the lake, Ice-Fisherman like to stand out in the freezing cold with string on a hook, Sky Divers like to dive out of prerfectly good working planes???
What I don't like or agree with is when people on this forum start bashing those individuals that enjoy doing things that they don't understand.
Everyone wants to ban everyone else's activity because THEY don't enjoy it. This usually falls under the "Well it is offensive to me and it prohibits ME from enjoying MY activities." I can't stand this NIMBY pansy new American attitude.
Sorry Sam this entire post wasn't directed at you. I ended up going off on a rant!
hazelnut is offline
The Following 3 Users Say Thank You to hazelnut For This Useful Post:
OCDACTIVE (11-02-2009), robmac (11-03-2009), Ryan (11-02-2009)
Old 11-02-2009, 09:36 AM   #193
Yeap. Been there before. I've been driving performance boats since I was seven. My Dad had wooden hydroplanes back then. My Dad skippered the Miss Winnipesaukee after WWII. We had many performance boats. My favorite was the Hydrostream Viper with a merc 150SS with cleavers. That boat was a handfull!
In 2001, I had the opportunity to go to the Cigarette 'Top Gun' school. That was the most rewarding experience in my life! To be able to work and be trained by professional performance drivers. Their primary goal is SAFETY.
No doubt, I probably logged more boating time in my life than 99% of the folks on the forum. Except maybe ELChase who claimed to put over 1000 hours on a boat in a summer.
Yet, I have been told by SL supporters that I lack the ability to handle these babies and that I am a cowboy. I have never had a moving violation ticket on the water. Nor have I ever been in a collision on the water. My insurance company reward me with the cheapest rate that I know.
I have seen the MP having trouble at speed. I remember the time when one of the MP ran over a small whaler in Alton Bay. And the MPO was put on administrative leave and eventually quit.
Be careful who you call immature!
The Following 3 Users Say Thank You to BroadHopper For This Useful Post:
DEJ (11-02-2009), OCDACTIVE (11-02-2009), robmac (11-03-2009)
Old 11-02-2009, 09:56 AM   #194
Yosemite Sam
Then why make comments about hats that won't fly off because "I bought a set of head wraps for that reason... (already lost one in Long Island sound test driving her)"
Also other comments about how fast he might be going in the broads and then post an image that he was going 86 MPH somewhere.
Maybe it's me but I think it's immature to add comments like this when the reason for starting this thread was to show us his new boat and some of it's fancy features.
I am closer to 70 in age than I am to 60 so I have been around and could build or repair any engine that might go into a boat.
I'll stay out of this thread because I don't think that anyone reads what I am trying say anyway.
Below are the posts that (I think anyway) don't belong here.
The Kayakers don't have to worry about the hats.. LOL..
I highly doubt they will be sitting in the middle of the broads gunning people. So I will just take my chances
Old 11-02-2009, 10:19 AM   #195
DoTheMath
Umm, are you insinuating something by this post or just checking to make sure that I am keeping my son safe? If it's the former - spill it! If it's the latter - yeah, I make sure that he is more than safe and protected. And FTR - that pic was taken at about 25 mph, on a TUESDAY when the lake was F&C and there was next to no traffic. And my boat (that particular boat) was capable of well over the 25 mph we were doing, so it was a very controlled and stable ride! Was I "breaking the rules" there - yep, sure was... Do I loose sleep over that? Nope, not a minute - my Dad did it with me, and I have been told I turned out ok. So my son will get the same opportunities - and then some - to see what boating is all about, while having fun AND being safe and responsible! Start 'em young and it can only benefit him and everyone around him.
The Following 4 Users Say Thank You to DoTheMath For This Useful Post:
BroadHopper (11-02-2009), gtagrip (11-02-2009), OCDACTIVE (11-02-2009), robmac (11-03-2009)
Old 11-02-2009, 01:24 PM   #196
hazelnut
hazelnut's Avatar
Don't even TELL me that APS is on a crusade to rid the lake of us irresponsible parents who let our kids sit on our laps and "drive" the boat.
Seriously though I have absolutlely had it and this one will throw me over the edge. Lets legislate the fun out of life now shall we. Perhaps George Orwell was correct in his vision of the future. Emotion is frivilous and unproductive. We should teach our children early on what kind of life these people are shaping for them. Sit down, be quiet and above all do not have fun and sit on Daddy's lap while he is driving. The APS' of the world cluck their tongues and shake their heads, tsk tsk, that is unsafe behavior. How Sad.
hazelnut is offline
The Following 2 Users Say Thank You to hazelnut For This Useful Post:
gtagrip (11-02-2009), NoRegrets (11-03-2009)
Old 11-02-2009, 02:42 PM   #197
DoTheMath
I'm going to go with "reaching" - I could be wrong, but even APS seems more sensible than that...
Old 11-02-2009, 04:54 PM   #198
RTTOOL
Banned
Originally Posted by ocdactive View Post
very very nice.... What type of 25 ft are you putting that in? Did you have to upgrade the drive?
25ft. Sunsation with blackhawk lower unit should go 100+..
RTTOOL is offline
Old 11-02-2009, 07:19 PM   #199
NoBozo
Default Actually
The Photographs are of EXCELLENT quality....Maybe even like ... High Def. What do you think ..?? NB
NoBozo is offline
Old 11-02-2009, 07:29 PM   #200
Default Age has nothing to do with it
Hey Don, you hired another moderator.
Sir, your age has nothing to do with maturity. Frankly, your recent posts have been immature (I think anyway).
Finally, your age has nothing to do with being able to build a motor. My 72 year old father doesn't know an open end wrench from a socket but I have been tearing motors down since I was 12 years old.
Don't worry, people know what you are trying to say- it is how you waded in to say it.
VitaBene is offline
This page was generated in 0.53092 seconds
