Go Back   Winnipesaukee Forum > Winnipesaukee Forums > Diving Winnipesaukee
Old 05-22-2010, 09:03 AM   #1
Diver1111
Default Lees Mills objects
Went out last Sunday with a buddy up to Lees Mills; Big wind and white caps-long boat ride in those conditions. Wanted to dive objects I had on side-scan from last year, attached.
What I thought was a boat-although the dark curve had me confused because I saw no hard target to speak of to generate it-turned out to be a piling driven into the lake bed. Two pilings actually-pretty big; I thought I saw lines off both extending up into the water column as if someone had marked them; The lines into the water column are actually the pilings themselves about 30 feet apart. The big dark curve is the shadow from one of them. Not at all what I was expecting.
The two fuzzy circular objects that appear on both the left and right side of the scan just off the bottom is actually a single bait-ball, a tight school of fish.
The Following 2 Users Say Thank You to Diver1111 For This Useful Post:
Senter Cove Guy (05-22-2010), Tallyho (05-22-2010)
Old 05-23-2010, 10:55 AM   #2
Grant
Grant's Avatar
Close to shore or was it a random location for pilings? 20+ ffw is kinda deep for pilings. Interesting.
Old 05-23-2010, 07:21 PM   #3
Diver1111
Default Re: pilings
The two pilings can be found offshore perhaps about 300-400, off the Lees Mills dock/ramp. While I have never dropped my boat in at the Lees Mills ramp and have no reason to because it's such a hike (vs. going there by boat-and thus enjoying a nice ride in the process), this positional data will help you orient you to where these pilings are.
If you were standing on the Lees dock/ramp and looking south directly at the channel leading out of the Lees Mills basin, these pilings are at about 10 o'clock/11 o'clock in that "pocket"/body of water to the left.
Obviously they served some purpose, and I assume that purpose was logging, based upon my reading. I know from diving the CT. River and the logging-related history there, on the Connecticut they built heavy heavy-duty log "islands", from which they directed log-traffic. Logs floated down the river were of course not owned by only one company, so the stamps on the butts of the logs identified their owner; To identify them you must examine them; To examine them you must stop them-hence these islands-which we call "piers"; Basically a log traffic-island.
These piers are serious structures-built from logs that average 1-2 feet in diameter, notched at their connection points like a log cabin forming right-angles. They can be 15-30 feet high off the bottom, then filled with rocks in the center-big ones (my guess is 500 to 1,000 lbs each)-as ballast to hold them down. They are typically 25 x 25 feet in dimension at their base.
I am guessing that these pilings in Lees are remnants of the logging industry in some fashion.
I participated in a film about the logging industry on the CT River made by Ed Klekowski from U-Mass/Amherst a few years ago, where we filmed these piers, but they did not show up well, due to lousy viz.
Some images of this can be seen at:
http://www.wgby.org/localprograms/logdrives/index.html
Hope it helps.
D1111
Grant (05-24-2010), secondcurve (05-24-2010)
This page was generated in 0.31800 seconds
