Old 04-10-2009, 10:11 PM   #1
Bear Island South
Bear Island South's Avatar
Default Opening Day
If anyone wants to share their opening day experiences, would love to hear them.
We arrived today at 11am, water is running and dock is in. One problem, no hot water, can't figure out why the hot water tank is not heating water, any suggestions, I need a shower in the morning.
Old 04-11-2009, 03:07 AM   #2
TomC
TomC's Avatar
Default try these ideas
Switch is off, if so equipped. Breaker (fuse) is tripped or off. Heating element(s) burned out - which will happen if power is turned on even momentarily when the tank is empty. Thermostat is gone. Less likely: connection at panel or heater is loose/dirty or wire broken/chewed by rodent, etc.
Old 04-11-2009, 08:36 AM   #3
Bear Island South
Thanks, I just pulled the heating element, it is fried.
Old 04-11-2009, 09:46 AM   #4
hazelnut
hazelnut's Avatar
Darn! No hot shower then....
We hope to be opening next weekend. I can't wait. I'm thinking everything should be fine considering that I stayed there a couple of times this past winter. The only bad news.... I left Bread and some other perishable items thinking I would be back one more time.... oops.
hazelnut is offline   Reply With Quote
Old 04-11-2009, 10:11 AM   #5
EricP
No worries, I'm sure the local wildlife cleaned it up for you
EricP is offline   Reply With Quote
Old 04-11-2009, 10:36 AM   #6
Steveo
Opened up yesterday. Water is on, no heater problems and only one leak. Of all things it was the sprayer for the kitchen sink. Must have left some water in the handle and it cracked. First time for that.
Old 04-11-2009, 01:09 PM   #7
Bear Island South
I just replaced the heating elements, hot water is cooking now.
Aubuchon Hardware in Meredith had everything I needed.
The ice has moved back in, I'm glad I got the dock in yesterday
Old 04-11-2009, 08:42 PM   #8
JTA
JTA's Avatar
I hope the moving ice doesn't damage your dock.
This page was generated in 0.25606 seconds
