Go Back   Winnipesaukee Forum > Winnipesaukee Forums > Area WebCAMs
Old 09-03-2007, 07:27 AM   #1
wifi
wifi's Avatar
Default Mountain WebCAM
A webcam has recently been installed up on top of the Ossipee Mountains, up on an unnamed peak. It faces WSW (towards Lebanon, NH); in the morning, when the sun is behind you, it looks spectacular. In the evenings, with the sun in your eyes, the close up trees are difficult to make out clearly, but you can see, for instance, the sun reflecting off Squam Lake. See attached morning/evening photos
Apologize for the focus, it’s not easy to tune, running up and down a ladder to check out the changes on a laptop, which really isn’t that clear. The mountain range in the foreground is Red Hill; it’s top is about 800 feet below this cam. There is a tree in the foreground ‘marking’ the saddle of the Red Hill range; the fire tower is to the right, on top of that knoll, and only visible at certain times. In the evening, with the sun in front, you can see light reflecting off Squam, right behind that tree in the saddle. Just to the left and top of this ‘saddle tree’, in the very distance is Mt Cardigan.
It will be interesting to see what winters are really like up there. I have only visited the site during service calls, and in reasonably good weather (for safety’s sake). There is what appears like a rectangle, just above and to the right of where the fire tower should be, I believe that is a reflection of the aperture. Now does anyone have any tricks (other than what the manual says) to focus it quickly, my legs are still tired
The cam downloads during daylight hours, and is available at:
http://www.lakesregionwireless.net/webcam
The drop down bar will return the last 10 pics (usually taken every 15 mins)
Morning:
Evening:
Old 09-03-2007, 12:15 PM   #2
paddler
Thumbs up Great spot for a webcam
The link you provided just takes me to a page with html code. Until the page is corrected this link will get you to the image.
http://www.lakesregionwireless.net/netcam.jpg
paddler is offline   Reply With Quote
Old 09-03-2007, 01:26 PM   #3
wifi
wifi's Avatar
Thanks paddler, try this link with the proper suffix:
http://www.lakesregionwireless.net/webcam.html
Old 09-03-2007, 02:09 PM   #4
Bear Islander
Bear Islander's Avatar
Congratulations on a great location. That sounds like hard work.
I hate focusing webcams! I finally decided I must be looking at a live image while I focus. Or there must be two people, one focusing and one watching and yelling.
Have you considered pointing the camera down a little to sacrifice some sky for more ground detail.
Old 09-03-2007, 07:22 PM   #5
paddler
Both the Ossipee Lake Cam and OVSC trailcam are Stardot netcam and were focused prior to installation.
This is what my Stardot Dealer recommends for focusing the cams.
The "C" mount lens that the Stardot cams use just screws on, they are focused by how far in you screw it in. This should be done on a bench, not on the site. The lens should be placed at infinity, and the f/stop opened wide, and pointed at a distant wall or something in a dimly lit room. Then the lens is screwed in, back and forth, until the focus is sharp as possible.
Old 09-04-2007, 03:55 AM   #6
wifi
wifi's Avatar
I hate focusing webcams! I finally decided I must be looking at a live image while I focus. Or there must be two people, one focusing and one watching and yelling..
Thanks. Think next time I'll have someone manning the laptop and yelling, beats dropping that off the ladder too.
I'll try that. There is some cleared land and guy anchors below the current view, I didn't think its very interesting. However, a snow stake with graduated colors might be informative. Over the last decade of winters the max snow levels have ranged from 1.5 feet to 5 feet. Hoping for some of those lightening shots hitting Red Hill... or any spot but this one
This one was focused on the ground as well, looked good, until I dropped it on the way up .... arrrghhh
I got the cam with a extra wide angle lens. It didn't give me the picture that I wanted to see, so I screwed on the standard lens. I believe one was a C and one a CS, and I didn't have that spacer ring. In any event, the time the cam takes to process the image before displaying it makes the whole process rather long. Maybe there is a way to look at a non processed image?
Old 09-04-2007, 07:50 AM   #7
paddler
You could temporarily change the camera settings to 320x240 black&white while focusing it. That way the camera updates the image much faster and will make it easier. Turn the lens one half turn at a time and judge if better or worse. Keep repeating until sharp. When done make sure it is set on f/16.
Is there any way to point the cam North? The image quality would be much better and it would better for the camera sensor.
Old 09-04-2007, 02:56 PM   #8
Long Pine
Long Pine's Avatar
Default Focusing is tough!
I just went through many hours this weekend trying to get my Stardot cam focused after ordering a new lens (auto-iris varifocal 4.5-12 mm replacing the stock manual-iris 8mm lens). I had the laptop up on the ladder with me, but dropped it once (luckily no damage). I was having trouble getting the entire image in focus. If the center was in focus, the edges might not be. I had a Stardot technician on the phone with me looking at the image as I tried to focus it and giving me some tips. I ultimately got to a satisfactory image, but not the perfectly crisp one I was hoping for. They said I could send the camera and new lens back to them and they would re-focus it for me for free but I would need to tell them the focal length I wanted - I wasn't sure of a convenient way to describe that to them so I just did my best.
Long Pine is offline   Reply With Quote
Old 09-04-2007, 06:01 PM   #9
wifi
wifi's Avatar
Paddler:
Thanks for the info on changing the resolution. I was turning the lens about 10 degrees at a time, 180 sounds good, I was afraid I would over shoot the right spot too much. Reguarding to repointing it, the best shot is where its looking, the building is to the west of the very top of the mountain for protection from the weather. I could put it on the tower with its spectacular views, but with the regular lightening hits and winter icing (falling chunks), it wouldn't last a year. Great idea tho.
Long Pine:
Thanks for sharing your experiences. My recording thermo showed -30F as a low, so I opted out of mechanically moving lenses or I would have ordered an auto lens, tho with the heat this cam puts out, it might not have been a problem. It will be interesting to see what the weather station reports for temperature. It certainly shows lower humidity than I expected... fire danger weather.
Old 10-15-2007, 05:10 PM   #10
mcdude's Avatar
Sunset tonight on the Ossipee Mt. Cam
This page was generated in 0.14881 seconds
