I've got two large rocks about 30' off the end of my dock that have a history of collisions with boat propellers. The size of the rocks (at least what is above the lake bottom) is about 4' x 4' x4'. At full lake elevation, they are about 24" below the surface. One of the largest barge-mounted excavators operating on the lake was unable to move these rocks. I am told that one cannot get a permit from the NHDES to dynamite the rocks.
Does anyone know of a marine contractor, or a drilling and blasting outfit, that could drill holes in these rocks and split them up using expansion agents, rock-splitters, etc.? I was going to try to expose the rocks during the winter and drill holes for an expansion agent, but the lake was too high and the ice too thin this year! |
You can get a permit to "pop" rocks from the DES Wetlands Bureau. It would be recommended that you get the permit to either relocate them or "pop" them before hiring a contractor to do the work.
I have no clue about the legality of the following advice.
I have sucessfully moved big boulders on land using chains, big nylon straps, come-alongs and trees. You need to make a lasoo around the rock with the chain and a slipper hook such that the end of the chain comes from the side of the rock opposite the direction of pull, and over the top of the rock. The nylon strap is used to connect to and protect the tree. When you apply tension this way, the rock will roll instead of slide and it is much easier to roll a rock than it is to slide it. If you can make a hole in the ground for the rock to roll into, your problem will be solved without a whole lot of effort or explosives. You could also make some home made markers for the rocks and leave well enough alone. They weigh about 6758.4 lbs under water if they are indeed 4x4x4 (and granite). Above water, they would weigh 10752 lbs. |
For anyone interested, my application to remove the aforementioned rock was denied by the local Conservation Commission. Their suggestion was to move the dock; their main concern was environmental harm and setting prededent. When I look at some of the construction/demolition underway on the lake (i.e., 4,000 SF houses on 10,000 SF islands, tree removal along the shoreline, etc.) I find it pretty ironic that my rock has to stay!
Does the local conservation commission have the last say though? I thought DES would take into consideration when the CC says but that the DES makes the final decision. I've seen many times in the DES Decision Reports where the local CC says one thing and the DES still approves the permit.
In the State of NH the local Conservation Committees serve an advisory role. They do not have the authority to approve or deny applications as they do in MA. They can make recommendations If they do and the State chooses to take an action contrary to those recommendations the state must explain why through decision findings. The State is not required to follow the Conservation Commission's recommendation.
How can moving a dock have less environmental damage than moving a rock. Typical bureaucratic nonsense. Maybe the ice will move them for you this winter.
Yankee, the mass stays the same, but the force needed to lift the rock is less in water. Think about a tree, it weighs a ton on land but nothing in water, it floats. |
#8 | |
These Conservation and Wetlands people need to get their heads out of the same sand that they are chartered to protect. Any given weekend dozens of cruisers leaving Mountainview, Silver Sands and the other yacht clubs in Gilford throw up enormous wakes and destroy the shoreline in front of my house on Dockham Shore. Where's the outrage over this shoreline destruction by the environmentalists? Yet moving a boulder is a major problem?
#10 | |
terms which people tend to use interchangeably, but they do not mean the same thing... |
I know what you mean Seaplane,I've seen the damage done at your Dockham Shore property.
SIKSUKR |
Any chance you can just mark the rocks well and leave them alone? I see plenty of privately maintained navigational aids on the lake. I can't imagine why marking would be a problem. Of course, being denied the option of moving them seems utterly silly to me. Love to hear a good reason why the rocks should stay.
#13 | |
If your marine contractor removes the excavator and empties his hull, he can put a "necklace" of chain under the boulder and raise it off the bottom by pumping out the hull. He could then move it to deeper water. (Or to my place—I could use a boulder to break up wakes.) ![]()
Is it ![]() ![]() |
#14 | |
#15 | |
You got way to much time on your hands!!!!!!!! ![]()
#16 | |
In the meantime, someone tell T.H.E. Binz to file a Standard Dredge and Fill Application to move that rock because the Town Clerk must forward that application type directly to the state. It cannot be held by the town. |
#17 | |
#18 | |
#19 |
The two-word answer to Dave R and Yankee: Archimedes' Principle.
The more detailed answer: A 4 ft x4 ft x4 ft block of anything, fully submerged, displaces 64 cubic feet of water. Fresh water has a density of 62 lbs/cubic ft. By Archimedes' Principle, the block would thus have a buoyant force on it of 64 x 62, or 3970 lbs. If the block itself weighed less than that, the buoyant force would be greater, pushing the bnlock up, and the block would float. In fact it would rise out of the water until its weight and the weight of the water it displaces were equal, then sit there floating peacefully; so-called positive buoyancy. If the block's weight and the buoyant force were equal, the block would submerge completely and remain at whatever depth one wished to place it at; so-called neutral buoyancy and very hard to maintain for a number of reasons - just ask a SCUBA diver! If the block's weight was greater than the buoyant force, the block would submerge completely and continue to sink, since the downward force is greater; so-called negative buoyancy. Example - Concrete has a density of roughly 100 lbs/cubic foot, so a 4x4x4 block would weigh 6400 lbs. That's greater than the buoyant force on it if it were completely submerged, so it sinks. It would also weighs only 6440 - 3970, or 2430 lbs underwater. You have to pour a block weighing over 3 tons in order to get just over one ton of holding weight! |
#20 |
Well,I just posted a disagreement with Skprbob and then did a little research.He/she is right on with the displacement calculation.By the way,granite weighs 165 pounds per cubic foot.You can do the math.
SIKSUKR |
#21 | |
I think I can see a reason why rocks should stay, specifically only along the shore line which is what I think they are talking about. and that is too stop the errosion of the beaches or land. I say that cause they said to "move the dock" why not find a way to anchor your dock on the rock. My dad often says that an old timer stated sonny if you find anything that can stay in that lake you will make your first million. Well boulders do stay put. Even when hit by boats or propellars. |
#22 | |
Another favorite of mine is when they run em half speed right up to the no wake sign as the 3 foot waves keep rolling for a half mile past the boat. The area between lockes and pig island needs to be a no wake zone ! |
#23 |
Just blow the damn thing up and take the consequences if any.
#24 |
Hi Yankee,
At risk of being ostentatious, pedantic, elitist, and/or haughty, I will say the I probably should have used the term "apparent weight" for the block in the water. However, since you're an engineer, and I'm a former prep school Physics and Chemistry teacher, I suspect we know what the other means! |
#25 | |
#26 |
Mass, you people are talking about the mass of an object, which doesn't change. Weight is generally a measure of force exerted by an object due to gravity. Weight generally falls under the auspices of f=ma where f equals the force measured (weight in this case), m equals the mass of an object and a equals the acceleration due to gravity. Weight (the measure of force) is also influenced by the medium in which an object is weighed, even air has an effect. Also, although we generally consider the acceleration of gravity to be a constant, it does vary dependant upon your location on the earth. This variation is very small fortunately. The mass of an object is constant no matter where an object is weighed.
A rock, however, will weigh less in the water than on land. |
#27 |
Maybe David Copperfield could make it disappear... worked for a 747 in 1981.
![]() Another thought, maybe someone could go down to the dock and read this entire thread to the rock.... it may just leave on its' own. Considering that it has been suggested to tow it, drill it and even blow it up.. ![]() PS... I'd feel better if someone would admit to having had to look up the word pedantic like I did. ![]()
"Before you criticize someone, walk a mile in his shoes. That way, if he gets angry he'll be a mile away and barefoot!" unknown |
#28 | |
Actually, reading the second definition made it seem an apposite choice. For those less likely to exert the effort, here's the definition: pedantic One entry found for pedantic. Main Entry: pe·dan·tic Pronunciation: pi-'dan-tik Function: adjective 1 : of, relating to, or being a pedant 2 : narrowly, stodgily, and often ostentatiously learned http://www.m-w.com/dictionary/pedantic
[Assume funny, clever sig is here. Laugh and reflect... ![]() ![]() |
#29 |
As a half-an-engineer, I think the real question all of us geeks at heart should be asking is this:
When do we get to blow up the rock, and how much explosives do we get to play with?
Is it bikeweek yet? Now? |
#30 | |
#31 | |
#32 |
A series of holes with wedges tapped in could also be done, has worked for hundreds (thousands???) of years. Probably a little tougher to do underwater though.
#33 |
Exactly, a few wedges and in a couple million years the rock will split. Problem solved.
#34 |
I thought I actually received default approval for the "popping" of the rocks off my dock, i.e., I had an administratively complete application and hadn't heard back from the DES in several months. Unfortunately, DES had mailed a request for additional information to my P.O. Box in Meredith which I never received. As a result, my application was automatically denied and, if I wish to pursue, have to begin the application process (and $100 application fee) all over again.
However, I gather from the request for additional information (which the DES was kind enough to fax me) that NH Fish & Game is not too keen on popping rocks. They don't want rocks completely demolished, but popped to provide a useful size for fish habitat. I'm not sure this is practical for 4' rocks in 5' of water so I probably won't pursue this matter any further. They also wanted a construction sequence showing materials utilized with methods to control turbidity. |
#35 |
The result of your legal effort to resolve a problematic situation is a sad commentary on life in NH when dealing with state government agencies.
Would seem that the DES and Fish & Game have yet to hear the expression "K.I.S.S." in their daily conversations. Whatever happened to simple, common sense solutions?
#36 |
For better or worse, I have found that these situations are best handled by a professional contractor. I have used Winnipesaukee Marine Construction. They deal with all the permits and have experience in dealing with the various officials and all the correspondence goes to them.
Sure it's more expensive then DIY but less stressful and it usually gets done! ![]() |
#37 |
I agree with Cow Man. I am an avid do-it-yourselfer, but when dealing with government agencies, the pros know what you can get away with and how to frame it in the application process. I've used Diversified Marine for several projects and he's always been able to "get 'er done".
