Old 09-21-2026, 08:45 AM   #1
Default Winter Service Advice
Hi!
We put less than ten hours on our pontoon this summer (egads, right?!), so I'm wondering what I should be having the marina do for winter work. It is a 20' Harris Cruiser with 150 Mercury outboard. We usually put enough time on the boat to do the complete service, but with only 10 hours I'm thinking that might be overkill?
At this point, I have them doing the regular winterization and a tune-up (which hasn't been done since '21), and they'll be double-checking the oil/other stuff before storing.
Does that seem reasonable, or should I spend the $5xx to have the complete service done? A note that we did burn through a couple tanks of fuel and refilled before returning it for the winter, so that's fresh.
Thanks for your thoughts!
Sent from my SM-S931U using Tapatalk
Old 09-21-2026, 09:09 AM   #2
Hi!
I only put about 20 to 25 hours a season on my boat. I have my guy winterize and shrink-wrap yearly and have the engine oil and outdrive oil changed every other year, but I have a Merc outboard. They must check the outdrive for water, it sits at the bottom. If it has any water in it, they should change it.
Old 09-21-2026, 01:14 PM   #3
I would do both Think and I will tell you why…
It’s always good to change you lower gear lube yearly just to make sure you have no leaks. If it is in fact leaking, you will be leaving water in your gear case all winter and running it all next summer which would not be a good thing!
If you want to save money, changing gear lube and oil is about as easy as it gets and you could very easily do it yourself. You could probably do both gear lube and oil change for about $60.00. In less than an hours time. If it was me, I would do it…Not worth not doing it…
Just my thoughts…
Old 09-21-2026, 02:37 PM   #4
A regular winterization should include a lower unit gear lube change. This is a must, if you have a leaky seal and get water in the lower unit you could risk freeze damage.
If you are doing a tune up and winterization, I'd be surprised if they weren't doing an oil change as well. Exactly what is on their list of services to perform?
Outboards are pretty much set it and forget it these days. You'd be due for plugs and a fuel filter, lower end gear lube change, and fogging for winter. An oil change could be questioned with 10 hours of use, but I usually do them in the fall regardless of time used as oil viscosity will vary over time.
ishoot308 (09-21-2026)
Old 09-21-2026, 03:04 PM   #5
Just my thoughts…
Thanks for this, Dan. I called and was told they check all the fluids before storage no matter what for exactly this reason and will reach out if anything looks amiss.
This page was generated in 0.07405 seconds
