I’ve been researching and educating myself on propane as a heating source. I’m starting to narrow down a few details and I have a very general question. How many gallons will I burn during the year? I understand this is a broad question but one I must ask even at the risk of being heckled. A few bullet points to consider:
2200 Sq ft., 2-story new construction home Propane would be the primary source and also gas stove Thermostat would be set around 66-67 Again, I understand this is a broad question. I’m just looking for ballpark usage for winter months. Thanks |
For a broad answer to a broad question, here’s some info. New construction in 2013. 2,600 sf of living space. Hybrid insulation, foam and fiberglass. Propane used for heat, dryer, stovetop and oven, Rinnai on porch, fireplace and generator. Useage over the past few years has been about 1,200 gallons.
The Following User Says Thank You to winni83 For This Useful Post: | ||
BroadHopper (04-25-2022) |
#3 | |
Sent from my SM-G950U using Tapatalk |
#4 | |
#5 | |
Built in 2014, the average use was about 1250 gallons a year!
Cshipley (04-25-2022) |
Rinnai is on during entire heating season, set at 68 during the day and 60 after 10 PM or so. Gas fireplace is used for perhaps an average of 3 hours per day mostly for ambiance, but not as a supplemental heating source, although it does throw out a lot of heat even with the fan off. House is kept at around 68 during the day and 63 or so after 10 PM. Occupancy is year round. Except to the extent that the various devices using propane require electricity to operate, no electricity is used for heating purposes.
thinkxingu (04-25-2022) |
Are most efficient in running continuously. They are designed to change the heat output to the radiant heat elements by monitoring the room temperature setting to the current outside temperature. Thus maintaining a constant inside temperature. No temperature swing!
