Old 11-08-2015, 10:40 AM   #1
lagoon
Default Winter Lake Water
OK here is my question;
We have a traditional cottage that draws water from the lake via a pipe now. We are debating adding a winterized small garage home behind it and update the septic and all. The lot is pie shaped so away from the lake it gets narrow and steep. I think there is 75' rule for septic to well.
I was thinking there should be a way to warm up lake pipe so that it does not freeze and we could use it as well.
Any thoughts?
lagoon is offline   Reply With Quote
Old 11-08-2015, 11:31 AM   #2
There is a thread called "Using Lake Water year round" in this same forum a few weeks ago. Very thorough discussion.
lagoon (11-08-2015)
Old 11-08-2015, 06:06 PM   #3
Default Here's the link...
Here's the link:
http://www.winnipesaukee.com/forums/...ad.php?t=19931
( put the link in because as I searched it, I only got this thread as a response.)
Old 11-09-2015, 08:57 AM   #4
Pine Island Guy
Pine Island Guy's Avatar
Default lot's of info on the forum
The overall subject of year-round water from the lake has generated several threads with a lot of really good info out on the fourm - using a deep well pump, filtration systems, quick disconnects, and heated water line.
For the heated water line I used a Canadian product (assuming they know cold protection haha)... you can check it out here: http://www.heatline.com/pdfs/carapace_brochure.pdf
Been in use now for 3 years without any issues, and there is a thermostat coupling that you can embed along the line at what should be the coldest point (like where ours goes above ground into the water).
Give me a shout if you'd like more info on the other pieces/parts of the system, happy to help -PIG
Pine Island Guy is offline   Reply With Quote
Old 11-10-2015, 07:14 AM   #5
Gilford Well, which is located in Gilford close to Wal-Mart, has these winter waterline heated supply lines in their building, and you can go look at them and ask them all about it for a do-it-yourself installation.
One nice feature is that digging the trench is not so diificult because it is recommended to dig a very small and shallow trench ..... like just two inches below the ground surface, and about three inches wide .....no need to dig down below the frost line ....just a small, shallow trench.
The line I installed back in November 1992, a 125' x 1 1/4" black poly tube that cost $1050 has worked perfectly ever since with no issues....hut-hut-hut!
This page was generated in 0.24000 seconds
