Old 05-11-2014, 05:40 AM   #1
aquabones
aquabones's Avatar
Default Dock pipe problem
What can I put over 2"dock pipes that got peened and spread out from hammering them into the water? The edges are ragged and sharp. The 2" rubber caps that I just bought won't fit since the end are now wider than 2".
aquabones is offline   Reply With Quote
Old 05-11-2014, 06:00 AM   #2
GodSmile
GodSmile's Avatar
Get someone with a sawzall or a just get a hack saw and take an inch or so off the top of the pipe. That's what I'd do anyway,
The Following User Says Thank You to GodSmile For This Useful Post:
Old Hubbard Rd (05-11-2014)
Old 05-11-2014, 07:06 AM   #3
Use one of these next time...........
http://dockmaker.com/shop/super-driving-cap-painted/
Old 05-11-2014, 10:16 AM   #4
Massasauga
Massasauga's Avatar
PVC Pipe...
Massasauga is offline   Reply With Quote
Old 05-11-2014, 12:24 PM   #5
http://nh.craigslist.org/boa/4453645628.html
This is my ad. If you want spares let me know.
In previous posts some members have advised they just squirt a hose at the bottom of the pipes to set them down. In a day or two, the sand washes back in and they are firm.
I have used a driving a tool similiar to the one described above. Eventually the ends still deform enough that removing the tool requires some effort.
Eventualy I made a tool from some 1/2" copper pipe sections joined by threadded connectors. At the top end I have a valve and a hose hookup. You can get away with just the hose hookup piece and get a cheap valve to go to the end of your hose if you want to. This tool is inserted into your pipe and washes the sand up and out. As you get into deeper water you will add more sections.
Wear eye protection and expect to get wet. lol. I don't know who puts in a dock and doesn't expect to get wet but just in case...
This page was generated in 0.17431 seconds
