I did a search, but some of the threads are a bit old. Looking for recommendations (and approx cost if you have it) for a mooring installation. I am located in M'boro
Thanks ahead of time Newbie |
Ours were done by Diversified Marine a while ago, about $1k each with regular chain.
Spend the money up front for stainless chain though. Our regular chain only lasted about 5-6 years. We had Central NH Divers do an inspection and found them to be paper thin so we went stainless. They did the service work as well as moved our neighbors mooring at the same time. We used stainless on the mooring block for our swim raft, still looks great. This came from Watermark. I recall someone mentioning that am employee at Fay's does it as well in his spare time. |
Hi Newbie,
Depending on your water depth, the size of your boat, and what material you prefer, moorings run from around $1,000.00-1,600.00. Usually galvanized will last 3-5 years depending on its location and use but its good to inspect it yearly for unusual wear prior to the start of each season. Stainless should last 10+ years but again its important to inspect it prior to putting your boat out for the summer to make sure all of the cotter wires are intact and the chain is in good condition. Feel free to send me an email with the type and size of boat you have, water depth, and type of chain you'd like and I'll put a formal quote together this evening. Thank you, Mike info@winnipesaukeeis.com 603-707-4677 http://www.winnipesaukeeislands.com/mooring.php
Winnipesaukee Island Services - Moorings, Docks, and General Construction 603-707-4677 www.WinnipesaukeeIslands.com |
....say-hey....I have a 12" diameter, mooring ball & swivel that was floatsum & jetsum which washed ashore a couple days ago. It has the mooring sticker intact from 2002....and I plan on dropping it off at the free store at the Meredith town dump about 12:30-today if you is looking for a worn, but usable freebie.
Try Northeast Dock and Barge. 603-515-9032
#6 | |
La vita è buona su Isola Gatto Nero |
#7 | |
However my mooring does not get a lot of heavy use. If you have a heavy boat tugging on the chain for months and years wear could be a problem. |
#8 | |
In many cases a SS chain will last much longer than 10 years and a galvanized may last more than 5 years in the lake but I was just giving a generic ballpark. The galvanized chain and SS chain wear out the same way which is from the friction of the links rubbing together and from being dragged across abrasive sand and rocks on the bottom. Mixing galvanized and stainless under water will also cause the hardware and chain to fail much quicker than it should. Here is an example of what a chain we replaced a couple of years ago. The links were completely worn through at the bottom of the chain near the mooring. The upper chain was still in great shape and you would have never known this mooring was as close to failure as it was by just looking at the top 4' of chain. The mooring had only been used for 5 seasons at the time of this photo: ![]() We offer spring mooring inspections where we check for things like abnormal wear on the chain as well as check all of the cotter wires on the shackles /swivels and inspect your mooring block or disc. If you have any more questions please let me know! Thank you, Mike
That chain looks like it wouldn't even hold the mooring ball.
SIKSUKR |
