Old 11-08-2004, 10:26 AM   #1
Zee
Zee's Avatar
Default Green algae on boat bottom
I finally pulled the boat out of the water this weekend. All good things must come to an end. BUT, I now have a green slime on the bottom of my white boat. We have never had this problem in the three years we have had summer dockage. The first two years we were at Trexlers and this year we are at Pier 19. There must be a big difference with the nutrients in that part of the lake. Be that as it may, what can we use to clean the bottom? We tried orange cleaner and a stiff brush and a blue scotchbrite. Any other suggestions?
Zee is offline   Reply With Quote
Old 11-08-2004, 11:06 AM   #2
ahopper
Default Slimy Grimy
Slimy Grimy is what you're looking for. It's a mild cleaning acid designed for removing growth from boat hulls. Just mix the powder with some hot water in a spray bottle, spray your hull, wait a couple minutes, and poof you can hose the algae off.
ahopper is offline   Reply With Quote
Old 11-08-2004, 11:56 AM   #3
Zee
Zee's Avatar
Any idea where I can buy it?
Old 11-08-2004, 12:24 PM   #4
Tyler
Default On & Off
Another good acid based cleaner is On & Off. Available at most any marine store. READ the precautions on the label such such as not getting it on the trailer etc... Great product.
Tyler is offline   Reply With Quote
Old 11-08-2004, 02:44 PM   #5
searay220
I don't recommend "On Off" it ate away my trailer.I covered really well but the acid solution found it's way on to the trailer and took off the galv finish.
I do recommend the Slimy Grimy that stuff works Great.I purchased some at Parker Marine in Alton Bay.
searay220 is offline   Reply With Quote
Old 11-08-2004, 03:28 PM   #6
Zee
Zee's Avatar
Thanks for the info on the Slimy Grimy. I had no idea my bottom was ready for mowing. Maybe I will get a few more MPH and MPG with a clean bottom. I'm sure when my boat was on plane it wasn't very pretty.
Old 11-08-2004, 04:25 PM   #7
Arrow Preventive Maintenance
I wax the bottom of my boat with Starbrite premium wax with teflon. It makes removing the algae a lot easier in the fall. If you remove the algae immediately after taking the boat out. It is a lot easier than waiting for it to dry.
Old 11-08-2004, 05:16 PM   #8
Belmont Resident
Belmont Resident's Avatar
Whenever you’re using a product that could harm anything that is in the area you’re working in, try hosing the area down with water first.. If your trailer is covered with water it will dilute anything that gets on it and save your finish.
Old 11-09-2004, 12:21 PM   #9
Island-Ho
Island-Ho's Avatar
Default Slimy Grimy
I have used Slimy Grimy for the past few years, but find it is not quite as easy as 'spray it on and hose it off'. Be prepared to use a sponge or brush to really be effective. It does a good job at softening the grime, but needs a little more help than just the hose to get it clean.
This page was generated in 0.41307 seconds
