Old 05-26-2010, 12:30 PM   #1
tummyman
Default Weather at the Lake menu item broken ?
Has anyone noticed that the link to the Black Cat Weather Station on the left hand menu area is broken ? Seems to be stuck for some time now on May 17th. Anyone checking this out ?
Old 05-26-2010, 12:36 PM   #2
TomC
TomC's Avatar
Default works directly
http://www.blackcatnh.com/weather/
Old 05-26-2010, 01:44 PM   #3
tummyman
I know it works directly, but seems to be broken on the Forum. Thought someone should know.....
Old 05-27-2010, 03:37 AM   #4
TomC
TomC's Avatar
Default there is a site support section for technical difficulties
i thought you needed to get to the weather site.
Old 06-01-2010, 06:45 AM   #5
webmaster
Moderator
webmaster's Avatar
Originally Posted by TomC View Post
works directly
Mike from the WeatherCam just sent me an update on the Weather Station problems. A power supply failed on May 17th and it has not yet been fully repaired. The data on the WeatherCam site is being updated manually but the image we use here has not been updated since the failure.
Mike is expecting the replacement power supply in the next few days and our weather image should return to normal operation.
You can follow Mike's comments here:
Facebook Feed Provided by CanisLupusArctos and the Black Cat Island WeatherCenter
This page was generated in 0.25116 seconds
