Hazelnut, we must have had the same instructor, he told us the same thing ( Red-South and West etc.) That is the ONE new thing I learned while taking the boating course.
Mat. To be honest with you, most people I know follow the chart to see which side of the buoys you go on. After you become familiar with your area you will know where to go without looking at the chart. When you leave familiar territory, you will need the chart for guidance again. Those charts are a boater's best friend and noone should ever be without one IMO. I think trying to figure out directions as you said just confuses people, especially new boaters. |
I also use the light dashed navigation lines on the chart to determine where I should be in relation to the buoy. I rarely use my compass. Maybe not the way of the real navigator but it's worked fine for me for 14 years.
Mat --- I agree totally with all of the above. But remember one small word that was said ........ "generally" ......
Case in point -- look at Floating Light #30 (Southern edge of Long Is - North of Mink Is). Although I can explain the why -- in this situation you actually "split" two black tops. When your out there for the first time -- this one (and there are a few others similar) will throw you for a loop! If you are as unfamiliar with Navigating the Lake as it sounds (and there is absolutely nothing wrong nor should you be intimidated because of that) try a trick our family did when we first explored. Find a clipboard and fold the map in such a way that the area you are boating is visible. As you leave the area, refold the map to the next section. The clipboard (which keeps the map from blowing all over the place) is on the floor right beside you at all times. Some here will suggest that you can do away with the clipboard by buying the "Laminated" chart --- my experiance with that is inevitably the area I'm concerned with is in the "crack/seam" and thus difficult to decifer (Murphey's Law). Enjoy, keep a chart handy ...... and explore!
A bad day on the Big Lake (although I've never had one) - Still beats a day at the office!! Last edited by Phantom; 04-08-2009 at 07:36 AM. Reason: typo |
Thank you to everyone for all the great info. I feel a lot better about being able to get around the lake using the chart lines. I'm sure I'll stay out of difficult areas till I gain enough experience.The chart will be with me all the time. This forum is a such a wonderful help for people new to the area.
Thanks again. |
Here is a little cheat sheet I created in windows paint a few years ago to help me remember. I used to keep it under my chart on the helm. I like Hazelnut's trick, that is a keeper. One place that always throws me is entering dog cove on Meredith neck where there is a red top and black top marker which looks like a channel entrance luring me to go between the markers then I remember that channel markers are solid red and black.
#6 | |
Where is Dog Cove? That's new to me. |
#8 | |
Nauset,
That little chart is a cool way to think about it. Like some others have mentioned I had some confusion. I was checking out near the east side of Barndoor island. I was seeing the line split two black and white buoys there. I thought it might be an error but after learning about others I guess its not. So just follow the lines. |
Matt you have got a lot of good info here.The way I always remember which way to go is remember BEN (black east north)then red has to be south and west.
Just be careful and use the chart and you won't have any problems PS it wasn't till I thought I knew the lake before I dinged a prop. It will happen |
Here's another way(Coast Guard) of remembering about which side of red or black markers to use-at least it worked for me several years' ago and on the ocean port areas. I assume it would work the same on the lake. If anyone knows differently please reply about it. Thanks.
I did use it on Winnipes.several years ago also. BPOE-RRR -stands for Black on Port(Left) on Entry-Red Right Returning. Of course it's the reverse when going out from Port. After a very short time you will remember the ditty. Hope this helps. |
#12 | |
Red Right Return will not work. |
I'm surprised your an "oletimer".
I'm only kidding! |
#14 | |
![]() ![]() As said Red Right Return does not apply to the lake. Another tip: Never ever ever use Left or Right as terminology when navigating the lake. When I teach people to navigate I am always careful to say "Pass to the west of that buoy or pass to the south etc." Your right and left changes depending on direction. |
#15 | |
Ken |
#16 | |
#17 |
Dave R --- your right, I meant Bear Island
Oletimer -- Sorry.....RRR (Red Right Return) has ABSOLUTELY no bearing in the Cardinal system of navigation and will certainly get you a lower unit repair bill sooner or later if followed..... Nauset -- neat little Pie Chart!! Just when ya think you've seen and heard all the little tricks over time ...... a new one pops up ..... kudo's.
