#101 | ||
GEE, we might just as well ban ALL powerboats from the lake!! But then, how would all the island dwellers get to their respective islands?? Don't bother, I know.......rowboats. I'm sure they'll all love that.
Cancer SUCKS! ![]() |
#102 | |
#103 | |
And once again, I am sorry I didn't specify LAKE WINNIPESAUKEE when I asked the original question. What happens on other lakes has NO bearing on what happens on this one. History somewhere else does not equal history here. Sorry. |
#104 | |
High speed fatalities are rare enough that any particular lake is to small a statistical universe for evaluation. The sample must be increased to have the data show results. Looking at all lakes in a geographic area is perfectly valid. Especially as nobody has come up with a reason why that accident could not have happened on Winnipesaukee. The 150' rule has been quoted as a reason, but that was obviously a joke. |
#105 | |
Winnipesaukee is not as large as the great lakes for example, but it is the only regional lake with enough surface area to safely support high speed (where I'll say high speed is > 60MPH) boat travel. Including regional lakes much smaller skews, rather than supports, the findings. You could most likely show that as lake surface area decreases, probability of fatal accidents increases for a given boat speed/size ratio. A 32' boat operating at 60MPH on Winnipesaukee poses no threat, provided that existing boating laws and regulations are being observed. The same boat at the same speed on Winnisquam is a moderate threat, and on little squam is an outright danger. |
#106 |
I have no problem with BI bringing Long Lake into the equation, it is in our back yard. My problem is that other than his THEORY that a speed limit may keep this type of boat off Winnipesaukee, a speed limit would not prevent the Long Lake accident from happening here.
No factual data exists that a speed limit would prevent this. It can happen on a street with speed limits and it happens more often than on the lake, why would a speed limit on the water prevent it? It wouldn't. Drinking and driving is the cause of the accident. the boat didn't do it, the drunk driver did. A speed limit will not prevent it from happening here, and being that it appears all high speed accidents that have happened here have been alcohol induced, nothing will change. |
#107 | |
FINALLY! You hit it on the head... "HIGH SPEED FATALITIES ARE RARE ENOUGH" You & WINNCRABS NEED TO INCREASE the statistical pool to legitimize your argument! The reality is that high speed accidents are EXTREMELY RARE and statistically NON-EXISTANT if you remove ALCOHOL from the equation! Statistically, every time someone gets behind the wheel of any sort of vehicle, car, truck, snomobile, boat, atv, etc there is a POSSIBILITY of an accident occurring. The PROBABILITY of an accident increases dramatically when the operator has been drinking! If you dissect the Long Lake accident, All things being equal, if remove ALCOHOL from the equation, the POSSIBILITY of the accident doesnt change, however the PROBABILITY of that accident occurring would be NIL. There is always the POSSIBILITY of a boating accident on Lake Winnipesaukee, however the PROBABLILITY IS NIL!! Still waiting for that SOBER High Speed accident..... Woodsy Possibility: the state or fact of being possible Probability: Statistics: the relative possibility that an event will occur, as expressed by the ratio of the number of actual occurrences to the total number of possible occurrences.
#108 |
BI I would think that if you lived near a transition from a No Wake to non-No Wake you would prefer performance boats. Because the engine is not what makes a wake, the boat hull does. The horsepower does go somewhere, it goes to moving the boat forward.
The definition of a wake from wikipedia is "a wake is the region of turbulence around a solid body moving relative to the water, caused by the flow of liquid around the body. The wake leading the body is caused by the compression of the liquid medium by the moving body, and is often called a bow wake when observed preceding a watercraft. As with all wave forms, it spreads outward from the source until its energy is overcome or lost, usually by friction or dispersion." The engine provides thrust not the wake. As the props spin they provide the thrust to move the boat through the water. The shape of the hull determines the type of wake a boat produces. Descriptions of different hull types from wikipedia. * Displacement -the hull is supported exclusively or predominantly by the pressure of water displaced by the hull * Semi-displacement, or semi-planing - the hull form is capable of developing a moderate amount of dynamic lift, however, most of the vessel's weight is still supported through displacement * Planing - the Planing Hull form is configured to develop positive dynamic pressure so that its draft decreases with increasing speed. Performance boats are planing hulls. So as they move through the water their wakes decrease. A boat with a planing hull with "enough" horsepower, will be able to transition faster from a big wake to a small wake. As the power increases the positive dynamic pressure increases lifting the hull out of the water. So performance boats are actually good for shoreline erosion. ![]() Now cruisers on the other hand being semi-displacement are worse so lets get rid of them. Or increase their horsepower so they have enough thrust to push those hulls up on plane. ![]() The only reason I can see for not liking performance boats when they transition from no wake up to speed is that they are noisy. So I would accept that performance boats do cause more noise pollution. My neighbor has a Harley with loud pipes, can I banish him too? ![]()
If we couldn't laugh we would all go insane |
#109 | |
#110 | ||
I am sure Bear Islander or his crony Islander will find someway to try and discredit your last message. Just as easily as BI did in the Lt. Dunleavy thread when they tossed out your post # 438 (click the post # for the entire post) Quote:
Just because you were there working at the camps on Bear Island BI knows better than you do. Just ask him. ![]() Thank you Parrothead ![]() |
#111 | |
OK...how many of those 5 fatalities were at speeds higher than the proposed limits? |
#112 | ||
#113 |
#114 |
This is where the faithful jump in with a list of silly reasons why those 4 or 5 deaths don't count.
#115 |
Again, I guess I should clarify.
What speeds did those accidents occur at? Were the speeds above or below the proposed limit? And remember..."excessive speed" does not equal anything over 45. And what was the primary cause of the accidents? |
#116 | |
#117 | |
If you go back and read #432 you will find I told Parrothead the "Camp Directors" new better, not me. But let me ask Parrothead directly - Who is better able to determine the current situation and needs of the Bear Island camps, you, or the camp directors? Chipj29- The answer is hubris. |
#118 | |
I do believe we landed on the moon, I don't think it was a sound stage or something if that is what you mean. I also never said anything about the current situation and needs of the Bear Island camps. What I did say in the referenced post is that I was working in the transportation department for both camps when the weekend boating programs were stopped. I also stated the reasons that were discussed and why decisions were made. I have worked and interacted with both camp directors. I can say that their primary concern is the safety of the children and staff that are placed under their responsibility for the summer. And they take that responsibility very seriously. At the time that this decision was made which was quite a few years ago, the safety concern was that there were too many boats out on the weekends not speed. If those concerns have changed now, then you are right I can't speak to that, but I can speak to why the decision was made originally.
#119 | |
Bear Islander at first wrote that high performace boats were chasing camp children off the lake, then he spent how many posts denying that statement when I questioned him? Now he continues to try to fear monger by perpetuating his fear of high performance boats and linking them with summer camps and then tries to discredit you by saying that he, through his alleged conversations with camp directors, knows better than you who was actually there at the time, what the motivation was behind the suspension of whatever on water activities on weekends. Hell, I'm afraid of heights, so by the logic Bear Islander and his supporters are putting forward, he and they and everyone else should be prohibited from any activity that could possibly take him over not only my property but wherever I happen to be at any given moment because they might fall on me! Heavens! Bear Islander has yet to tell us where he got the data about a 130 mph boat that is causing fear among family boaters on Lake Winnipesaukee or provide details of these 5 fatalities that he's linked to speed on Lake Winnipesaukee. Pretty easy to make accusations when you don't back them up. |
#120 |
You can do all the research you want, sit on my dock for a weekend and you will know the facts about wake. I can tell by the sound of the waves hitting the shore when a Marine Patrol boat is in sight.
You made the statement.. "the safety concern was that there were too many boats out on the weekends not speed" Even Woodsy has admitted that a speed limit will lower the number of boats on the lake. HB847 isn't just about speed. A speed limit will make the lake less hectic and crowded. Not a lot, but a little. Perhaps that is why the camp directors support HB847. |
#121 | |
A good example to me that we need more enforcement of current rules rather than adding another rule. You said it. MP in sight people behave better. Thanks for making the point.
#122 |
Once HB-847 is enacted, I will ask one Lakes Region website to open its doors to new members when the spamming finally ceases there.
Another website will not be "moving" speed limit threads, and still another that will not be "purging" their Boating Forums entirely. Another, www.tuftonboroforums.com was closed down due to the dreaded Unlimited-Speeds onslaught, and could very well re-open for business. ![]()
Is it ![]() ![]() |
#123 | |
#124 | |
I'm sorry, but you have several of those things wrong. I do not dislike performance boats, their sound, their look, or their speed. Personally I like speed, and the sound of a powerful engine. Some performance boats are beautiful, like the pirate boat that often passes our place. However I see the lake getting out of control. Water quality is going down, kayakers afraid to go out on the water, my son's camp having to limit lake activities. Something has to change, we are going in the wrong direction. Do you believe the directors of the camps HATE performance boats? Why do you assume my motives are not the same as theirs? I spent 15 summers as a waterfont director, camp director or Red Cross Water Safety Instructor. I look at the lake and I see a problem I think I must do something about. However it's easier for you to assume that I just "hate performance boats". Its the easy answer, but wrong and unfair. I hope you are wrong about the effects of a speed limit. I think it will help, at least a little. |
#125 | |
Having a Marine Patrol boat in view everywhere on the lake would have an incredible positive result. However the Marine Patrol can not enforce laws that do not exist. Plus there is no way we are going to see the additional funding that would be required to significantly increase their presence. Which to do prefer.... 1. Ideas that might work and can be implemented with existing equipment, funding and personnel. 2. Ideas that are fantastic in theory, but have ZERO chance of being funded or implemented. I will go with number 1. |
#126 | |
#127 | |
I suspect they really hate to hear about camp directors supporting limits. Camp directors are obviously experienced, responsible professionals with a lot of lake experience. Its hard to argue away their opinions or pretend they have a personal axe to grind. Last edited by Islander; 05-03-2008 at 10:43 PM. |
#128 | |
It's not about not liking certain boats, it's about not liking them in his backyard. I'm sure Teddy Kennedy loves windmills, just not where he sails. Get a camp director on the forum to tell us what he thinks. Forgive me, if I don't take your word for it. I guarantee the camp director will be more concerned about boats traveling too close to his campers than some boat traveling over 45 MPH in the middle of the broads. |
#129 |
I second that, I would love to hear a single camp director say that the proposed speed limit would allow them to let their kids go out sailing and do stuff they can't now!! I didn't hear a camp director at the Senate public hearing opposing! Just a bunch of people putting words in their mouths, like they are on this forum.
#130 | |
I am not against safety, I was responsible for 100's of campers over the years I transported them back and forth from the mainland to Bear Island. In fact for the years that I worked there it was my responsibility to get every staff member and camper to the island. I drove the Bear every change day when the campers left and came to the island. In my opinion education and enforcement are a better way to make the lake safer. If the speed limit is passed I will operate my families boat within the law as I have been doing all along. As for pollution and erosion, I didn't buy BI's opinion on the matter. And apparently he didn't buy mine. So be it, life goes on we agree to disagree. Where did anyone ever say that they hate the fact camp directors support limits. We are just making our own choices on this issue. I just happen not be making the same choice as you. And since this is a public forum I have just as much right to let my opinion be know as you do. I did, and provided the reasons why.
If we couldn't laugh we would all go insane Last edited by parrothead; 05-04-2008 at 09:54 AM. Reason: One more point |
#131 | |
Anybody? |
#132 | ||
#133 | |
#2 Instead of talking about it, do it. Go ahead. So if this supposed camp director "FEELS" like the lake would be safer with HB847 we should all just cave in and say, yup BI you were right?? I have to agree with sentiments put forth by Parrothead and a few others. Islander has no original ideas on this forum. All I ever see from Islander is whining when someone "isn't nice" to BI or Islander trashes other peoples opinions and discounts them. And Islander has a problem with OTHER people on this forum, well I have a complaint to lodge against Islander. If your sole purpose on this forum is to come here and say BI is right and everyone else is an idiot, I respectfully request you refrain from doing so. How about being constructive and forming your OWN ideas for once? That'd be refreshing. ![]() |
#134 |
#135 |
My guess is that some camp directors and staff would vote for speed limits. In life after speed limits few, if any, would act differently when making the rules about how campers could use the lake.
-lg |
#136 | |
So answer the question now please. What do YOU think camp directors think about limits? |
#137 | |
Do they cause erosion? Any power boat in motion will contribute to erosion. So it can't just be that, because cruisers are much more offenders than any other type of boat. Pollution? Any internal combustion engine will contribute to pollution, as well as cars, planes, trains, and space ships (sorry had to throw that in). Do GFBL boats produce more pollution than any other boat. Yes! I'll give you that. Some have two or three engines compared to the normal runabouts one so they produce more exhaust. Also performance boats with through hull exhaust do contribute more to noise pollution than boats with through prop exhaust. So GFBL boats do contribute more to pollution. But given the number of GFBL boats on the lake compared to the other types I can't imagine it will make that big of an impact. The increase in boat traffic in general is more of a pollution concern than just GFBL boats. So I guess hate might be a strong word, but you certainly don't want them on Winni. As for camp directors "hating" performance boats, I really don't care. Everyone is entitled to their opinion, you, me, and Camp Directors. And I know you will take this as spin, but you state in the first sentence of your post that you don't dislike GFBL boats, and in the next paragraph you ask why if directors hate performance boats why can't your motives be the same. Well they can't be because you like performance boats and they apparently don't. Not that we have heard from them as to what their opinion is. You stated your opinion as a one time Camp Director, so we do know that at least one Camp Director doesn't like perfomance boats. You.
#138 | |
And we have heard from the camp directors. And yes they do support HB847. |
#139 | |
#140 | |
Several HB847 opponents on this forum have spoken out in favor of "camp zones" around the lakes children's camps. I joint them in that worthy idea. I wish you did as well. |
#141 |
I seem to remember, which is tougher after all these years, that the camp boats themselves used to make me slow down so I wouldn't get jarred. Those big hulls made for some waves.
I think the wave issue and erosion issue ought to be discarded. I'll take the wake from a 42 Fountain anyday over a 32' Carver or whatever the barge of choice is nowadays. |
#142 | |
How about we get ride of the Fountain and the Carver and every other boat that belongs on larger bodies of water. I think most people like special consideration for the camps. If parrothead really worked at the camps I think he would as well. |
#143 | |
If we couldn't laugh we would all go insane Last edited by parrothead; 05-04-2008 at 01:16 PM. Reason: Misspelling |
#144 |
Sorry, I didn't realize he was talking about a No Wake Zone in front of your house. Unless boaters go through that area at higher speeds, and only slow down when MP is present...which I doubt is the case.
#145 | |
I have no problem with camp areas being protected someway. The issue I was trying to address is the wake and erosion issue, which you seem to think is "central" to the law. I have to say, anyone that's been on a lake for more than a day has to realize the wakes coming from planing hulls gets bigger as they go slower. As for the cruisers, they're just BIG all the time. ![]() I'll agree that there are several issues here, and very few are addressed by the speed limit law. The only by product of this law is that boats that can do 80, mph and all that, might just go elsewhere. If that's the intended result, people should just say so. Otherwise, I'd recommend that everyone that is responsible, and hates this type of law, do the following. Every Saturday afternoon, every boater, regardless of the size of boat, throttle up to around 12mph to 18 mph, whatever produces the largest wake before planing occurs. Do that every Saturday for a couple of hours. See what happens then. If you want to, and are truly dedicated, do it at night too. |
#146 | |
Most boats go reasonably slow, however that speed drops incredibly when the MP are around. The most dramatic difference, laughable really, is how the NWZ line moves. When a patrol boat is around the NWZ begins and ends 200' to 400' OUTSIDE the NWZ. When the patrol in not around many boats bring back the throttle as they pass the marker. Several times a day boats go through full speed, even at night. Now and then they have to replace the marker after it gets hit at night. The most common violator is a very large cruise boat that passes more than once a day. I will not guess at its speed, but I have seen boats being overtaken by it have to go full throttle, in the NWZ, to get out of its way. |
#147 |
Well that sucks that people don't obey the NWZ. And I mean that seriously. However, it is great that people slow down when MP is around to enforce the current law.
#148 | |
#149 |
#150 | |
#151 | |
We had a neighbor that would throw tennis ball at them, but he is gone now. A have a few videos but you can't read bow numbers from that distance. I have been thinking of setting a camera up with motion detection. Take a picture of every boat that goes through. |
#152 | |
#153 |
BI
Why don't you and your neighbors petition to have the NWZ extended? I've always felt that it is too small, and adjust my behavior accordingly. I'd even be happy to show up at a hearing and speak in favor of expanding the NWZ! Silver Duck |
#154 | |
So. What does this have to do with the speed limit again? They are breaking the speed limit in a NWZ for chrisakes. Does that mean a speed limit of 45 they will do 125mph ? Get some common sense already, The issue is enforcement, not more laws. |
#155 | |
R2B |
#156 |
The reality of the situation is that if the speed boats were quite we would not be having this conversation now. I have talked to a few legislatures and they all say that is the main reason for the complaining. Most MP's will tell you that speed boats are not a safty concern. Most people that drive them have a very large amount of time under their belts. That is not to say that they are never involved in accidents but they are involved in very few. The noise is what bothers most people.
The Long Lake Accident we still do not know much about. They have kept the details of that accident very hush hush. We still do not know if Ray Trotts boat (the smaller one) had his lights on or not. There are a lot of other details that we still do not know about. I am sure it will all come out in the trial. Then we can talk about that accident with some facts. |
#157 | |
#158 |
I'm not sure increasing the size of the NWZ will make any difference. It's already about three times as large as the law allows. And it isn't about wake its about slowing people down in a crowded area. The biggest advantage of the NWZ is it keeps many boats away. Before the NWZ was enacted that was the most scary place on the lake. Worse than Eagle island was.
In general I don't think laws that require intense enforcement are the best answer. The NWZ solved 99% of the problems it was intended to solve. If the MP could show up more often and make it 99.9% that would be great, it's not likely to happen however. |
#159 |
I'd say a 99% success rate is pretty good....
#160 |
#161 | |
#162 |
A speed limit was not my first choice, a horsepower limit is infinitely easier to enforce.
However a speed limit is self enforcing to a degree. Having a speed limit sets a standard. It draws a line and tells both visitors and regulars what the standard of behavior is. A boater going 60 mph will know they are breaking the law. I believe most people are law abiding and will obey the speed limit. I'm sure many will go a little over the limit and get away with it. But if you go to far over the limit, to many times, you will end up talking to the Marine Patrol. If they get a ticket or if it holds up in court will not make much difference. If there is a scofflaw or two out there that ignores the law and repeatedly gets stopped for speeding, I'm sure they will eventually end up standing in front of a judge having an unpleasant conversation. It's like our NWZ, 99% do it the right way. We need to keep our eyes open for that other 1%, but that is true everywhere, and will never change. |
#163 |
With no new law, there will be no reason for people to scoff at it. Most experienced boaters believe the Coast Guard and existing rules are effective in defining proper speed for conditions. A purchased, feel-good speed limit law deserves to be scoffed at.
-lg |
#164 | |
#165 |
It's so much easier to get a consensus of opinion when the facts and the truth come out. If the intention of most people had been to,
1) Address the noise issue 2) Address the boaters speeding though congested areas then, I think you'd have had most people on board, assisting in the process. Instead of coming up with crap like wakes and erosion, not to mention malarkey about accidents and speed, we might all be talking about a new bill to add to the marine patrol's budget to enforce existing laws, and also expanding NWZ. This is how things work. I'm certain that the lake would be a far better place if the law is not passed, and everyone proceeds along those lines. Now that "those" boat owners know what could happen, perhaps a little self-policing would be in order. It's rather obvious from the debates where the most problems are, and clearly obvious where the most upset people are. In this day and age, having a marine patrol segment dedicated to certain trouble spots on a rotating basis is very doable. |
#166 | |
Noise is not a prime concern, I would list it around number 8 or lower. Speeding through congested areas is not the issue. The Bear Island NWZ has been in place for about 15 years, with reasonable compliance. |
#167 |
What do you mean by this? NWZ's or any congested areas?
#168 |
Dear Senators:
Once again we are seeing posts about how this is not a concern or that is not a concern. Another favorite is the "we tried to compromise", or "I would rather have had a horsepower limit", or fast boats make wakes that kill loons, or an accident a few years ago caused by a drunk not looking where he was going somehow magically would have been prevented by a speed limit. The bottom line: A SPEED LIMIT WILL SOLVE NOTHING, a speed limit will cause enforcement officers to move to the Broads looking for speeders who don't exist or are few and far between taking them away from much more productive public safety oriented tasks. Why???? So a few people on an island (or islands) can put the first notch in their belt in their effort to remove boats from the lake. Don't fall for it Senators, your job, is to see through frenzies stirred up by rabble-rousers and do the right thing. The right thing here is to defeat this bill. |
#169 |
BI
There's a legal limit to the size of an NWZ? How does that work? Silver Duck |
#170 | |
If the northern part didn't extend 800' then it wouldn't make it to Pine Island, and boats could just drive around the NWZ. I don't know how they screwed this up but 150' would never work. I wonder if they write it up as being small so they don't get a lot of resistance at the hearing. |
#171 | |
Paddle faster , I think I here banjos |
#172 | |
Your rebuttal is hysterical by the way BI. Bill Clinton could take lessons. "I did not have relations with that woman." Actually it's more like Clemens, we must have all misremembered your post. ![]() |
#173 | |
Funny perhaps, but 100% accurate. |
#174 |
Greetings all,
OK... now I want everyone to take a deep breath...go ahead...I'll wait.....now, don't you feel better? No, ok let's try another one....that's good....breathe in...hold it....slow exhale....nice. There, now that the blood pressure is under control, I have a proposal. It may sound crazy at first, but Bear with me. (how did you like the pun?) There's a little lake just north of Winni that goes by the name of Squam. I understand that there are certain "restrictions" on that body of water which are appealing to some and not so appealing to others. Whether it's size restrictions on boats, conditional land use permits or whatever, it sounds like a nice quiet, slow, safe and serene body of water. No GFBL's (what does that stand for by the way?), no kayakers in immediate danger of being....of being...I don't know, what are kayakers in immediate danger of again? The loons up there, I am told, are much more...what's the word?... Loonish than they are on Winni! And yes, whether you believe it or not, the little children up there are well above average. Doesn't it sound like a dream? Hmmm...come on, I know some of you feel that way right? Well here's my idea. Leave! If other people are having too much fun, or being silly or enjoying themselves in a way that you find unpalatable, just remove yourself from that environment. It's simple really. Put up the old For Sale sign, put your stuff in a boat and go! Just head north, buy a place on Squam or Rust Pond or Mirror lake or Beach Pond or wherever. All of these places are beautiful and maybe more to your liking. No....are you sure? I'm serious, I'll think you'll be happier there. Are you sure you really want to stay on the big lake? I mean, when it gets really windy, the waves can get scary out there. Perhaps something a little less intimidating would be more to your liking. Seriously, 99% of the folks operating a boat on the lake are doing so in a safe manner. So what is really getting under you skin is the so called "one percenters". And guess what, there is no legislation or enforcement that will ever keep us 100% safe. Welcome to life! |
#175 | |
#176 | |
I have just as much right to safely kayak on Winni as I do on Squam, but it has been my experience that I am less safe on Winni, due mostly to the high speeds of some powerboats. Whether you or others believe it or not, some people on Winni operated their powerboats at speeds that are beyond their ability to spot smaller boats (like kayaks) in time. My 150 foot zone has been violated by some of these people - not intentially, but just because they were traveling too fast. 99% of the folks on Winni are not operating their boats in a safe manner, at least not 100% of the time. People on this forum keep claiming that I am exaggerating, or that I can't tell when a boat is going faster then 45mph, or that I can't judge distances. Yet no one on this forum has had the guts to borrow a kayak and go out on the main lake with me. If you guys would just experience the lake from my perspective once, perhaps you would finally believe me. And you might even agree that perhaps we do need a speed limit. The truth is that it is not as safe on Winni as you think - at least not for paddlers.
"Boaters love boats . . . Kayakers love water."
#177 | |
Hey Islander! Here are two of my favorite restrictions on Squam! This is what happens when common sense lawmaking is allowed to be replaced by fear mongering and the desire by a few landowners to keep "undesirables" away!
#178 |
Yeah, right. We'll also see Indians (sorry - Native Americans) traveling to the Weirs in their birch bark canoes, setting up fishing nets. If you look up in the sky, you might even see a pig fly by. Ain't gonna happen in this lifetime or ever.
#179 | |
Maybe if all of the speed limit proponents had put their time and energy into pushing for a solution to increased enforcement, something would have been done. After all these years, you May get the speed limit. Seems pretty darn stupid to me given your comments about lack of enforcement for the speed limit areas already in place. Perhaps for the next 20 years a new thread can be in place for Why No Speed Limit Enforcement? I remember traveling that area frequently years ago. It was pretty congested then. We usually slowed down in that area, primarily due to congestion and waves, but also because it narrows out and is close to land. |
#180 | |
I suggest you contact Marine Patrol. One of them on a Sea Doo following you from a distance could bag all those 150' violators. You seem to be a magnet for them. The word will spread quickly and those that still break the law will face the consequences while you feel safer. Of course you could help your situation by making yourself more visible. Evenstar, I seem to remember that someone did offer to go kayak with you this coming season.
#181 | |
#182 | |||
He never responded top my offer - nor has anyone else. Perhaps it was the fact that I do not hug the shoreline like he does. I made this a standing offer a couple of years ago - and my offer still stands, but so far no one on this forum has had the guts to actually go with me on the main lake in a kayak. And yet you guys call me "afraid". ![]()
#183 | |
A sped limit won't change that. So as far as I see it you are deliberately putting yourself in harms way. I believe that the operators of every vessel are required to keep a sharp lookout but that is not the case. I know you feel passionately about your right to paddle across the broads but even the swimmers do something to draw attention to themselves. Most "Broads" swimmers swim off a boat and don't venture more than a few feet from it. Others who have done the whole length of the lake usually have an entourage of support boats with them. You Kayaking across the broads isn't much different IMO. I think most Marine Patrol officers would caution against it, not because of speed, but because of traffic and inattentive boaters. However, being that it is not illegal they couldn't stop you. I bet if you asked them they would prefer it if you didn't do it. A speed limit won't change their mind. With that said why couldn't you make special arrangements with a chase boat when you decide to take on this risky endeavor. Any way you slice it speed limit or no speed limit you are taking a large risk when you kayak across the equivalent of I-93 on lake winni. |
#184 | |
![]() http://www.upi.com/NewsTrack/Top_New...kayaking/7360/ Rescuers cite need to regulate kayaking Published: April 30, 2008 at 10:24 AM WASHINGTON, April 30 (UPI) -- The growing popularity of kayaking in the United States is prompting rescue organizations to call for laws requiring kayakers to take boating safety courses. The head of the National Association of State Boating Law Administrators says an explosion in the number of kayakers along the nation's waterways has become a "huge drain" on rescue teams, USA Today reported Wednesday. "Paddling represents our greatest risk in the recreational boating community," says John Fetterman, who is also a member of the Maine Marine Patrol. Fetterman told USA Today he supports legislation to require kayakers to take courses that teach them the basics of water safety. No government agency tracks the number of kayak-related rescues nationally each year but the U.S. Coast Guard does track boating fatalities. Twenty-seven people died kayaking in 2006, the most recent year for which numbers are available, USA Today says. Experts says one of the reasons for the sport's popularity is that kayaks are relatively inexpensive and can be hauled and used with ease." |
#185 | ||||||
My sea kayak is designed especially for large bodies of water – so, there is nothing extreme about using it out on my state’s largest lake. I’m a collegiate athlete, and kayaking is one of the things I do to keep in top shape. My “non-smart” recreational choices also include collegiate sailing, and hiking, and cross-country skiing – so I’m probably in better shape that most of you. Only on this forum would a healthy form of recreation be considered to be less safe than speeding across a lake at unlimited speeds. Yeah, there’s no slant here!!! Quote:
Again, I’m not swimming across the lake. I’m in a boat the is just as much a boat as what you use on the lake. Quote:
There are people who always get in over their heads – due to inexperience and/or to not using/having the proper equipment – or to not paying attention to the weather. The same thing happens with hiking – but that doesn’t mean that hiking is unsafe. How many of those rescues were in white-water or out in the ocean? How many were in cold water? How many of those paddlers were not wearing the proper gear? I would guarantee that only a tiny percentage of those rescues involved paddlers in sea kayaks. I’ve taken coastal navigation and advanced paddling. I have all the proper gear and can do self-rescues. I even have CPR training – since I do my work study on the waterfront, instruction and overseeing the use of kayaks at my university. I have actually assisted a power boat that was in trouble – I have never needed to be rescued and I paddle hundreds of miles each year.
#186 |
You know, every time I'm on an on-ramp to a major highway in NH (Rt. 93, 95, 89) I see a sign that says something like: No horses, bicycles, scooters, etc. They put these signs up for safety reasons. Now, in my opinion, Winnipesaukee is the lake equivalent of a major highway, and kayaks, canoes, paddle boats, etc., are the water equivalent of scooters, bicycles and horses. Therefore, I believe that we should ban the use of kayaks, canoes and paddle boats on Winnipesaukee (for their own safety) and force them to utilize the lake equivalent of secondary roads, i.e smaller lakes and ponds. This sounds logical and fair to me. Time to contact the Senators and Reps to have them introduce a bill. The precedence is certainly in place for this to pass.
#187 | |
"You ain't gonna learn what you don't want to know" |
#188 |
That makes too much sense
#189 | |||
My kayak doesn't polute, moves through the water nearly silently, doesn't create damaging wakes - and I am not a risk to others on the lake. And you guys want to ban us! Quote:
Other than being at risk from powerboats, how is my paddling on the lake unsafe for me - and I would love to know how my kayak and I are making the lake unsafe for others. Please explain that statement. That makes absolutely no sense and is probably unconstitutional - you can a type of vessel from a recreational body of water, just so others can continue to travel at unlimited speeds. A speed limit however makes total sense - and doesn't ban anyone.
#190 |
Gee, maybe we should just shut down the major interstate highways as well. Let's go back to horse and buggy travel on dirt paths and cross the oceans in sailing vessels vs. airplanes. It's called progress.
#191 | |
http://www.nh.gov/safety/divisions/s...estricted.html Oh, btw when I printed this out it was 20 PAGES LONG! ![]() |
#192 | |
#193 | |
I'll slow it down for you. A speed limit does not equate to attention. A boat traveling at 45, 35, or 25 operated by an inattentive operator is 100 times more dangerous than a boat operating at 75MPH with an attentive operator. You obviously have ZERO high speed boating experience so there is absolutely no way you could or would ever comprehend how it works. I'll try to spell it out. Boaters operating at high speeds usually focus all of their attention on the task at hand and keep the sharpest of sharp lookouts. Casual boaters cruising at or around 25-30MPH are much more likely to take a casual approach and get lulled into a sense of security while they carry on and converse, sightsee, etc and end up failing to keep a sharp watch. I've seen it and encountered it daily. Sorry I'll never ever agree that kayaking in the broads is wise speed limit or no speed limit. I think it is dumb actually. Tell me you can't get a good workout hugging the shoreline? Comparing your craft to powerboats is absolutely ridiculous. Your profile in the water is much closer to a swimmer. If you can't understand that there is no point in even discussing rational thoughts with you. Just like swimming in the broads alone is stupid, so is kayaking in the broads. There is a place for everyone on the lake to do their favorite activity. You think everyone else is selfish yet you are the only one trying to take away somebodies activities. Coves are for skiing, shoreline for kayaks, paddleboats and canoes, large open spaces for speed boats. How is that not sharing. No, you want it all and if you can't have it you'll kick and scream and tell everyone else that they are wrong. The whole argument is ridiculous. If I saw a canoe in the broads I'd rescue them because I would be sure they'd be in trouble. A canoe is more visible than a kayak. Why would you even THINK to go out there. I'll make this SAME statement after the speed limit passes. The speed limit will not change any of the above statements. |
#194 | |||||
There is nothing old-fashioned about me or my kayak. My sea kayak is made out of a high-tech, light-weight composite material, called Airalite - that wasn't even available a few years ago. Even my paddle is high-tech. And, when the water is cold, I wear a high-tech breathable drysuit. Perhaps you are the one who needs to adjust the this new eco-friendly world. Gas-gusseling high-speed boats are so out there. High-tech paddling is the new in thing. Quote:
Excuse me; I have no trouble at comprehension. I’m likely smarter than you, so don’t treat me like an idiot just because I happen to disagree with you. Now let me explain something to you. Inattention above 45 mph is more dangerous than intention at slower speeds – simply because you are traveling faster – anyone with any sense at all knows that. Show me any scientific evidence that proves that higher speeds actually increase a person’s attention span. A person who is inattentive at 35mph will still be just as inattentive at 70mph. How many powerboat operators have Attention Deficit Disorder? How many consume alcohol while they are boating? How many have less than perfect vision? If all high-speed operators are so acutely attentive, why don’t they see me in time to stay clear of my 150 foot zone? I contend that slowing down increases your ability to see better – if that isn’t true, then why can I see other kayaks a mile off, while operators of boats traveling at high speeds seem to have so much trouble seeing me? Quote:
There is nothing “stupid” about taking a SEA KAYAK across the Broads – my kayak is designed to handle large waves, and I’m very experienced – and have all the proper gear. Have you ever even been in a sea kayak? Do you even know what one looks like? “You obviously have ZERO” sea kayaking “experience so there is absolutely no way you could or would ever comprehend how it works.” Quote:
All a speed limit does is make you slow down to what the state has determined is a safer speed for others on the lake – it doesn’t kick you off the lake, of permit you from using any part of the lake – and you think that is unfair, while stating that paddlers should not be able to use the entire lake just so you can travel at unlimited speeds on it. Others, who I was replying to here, have stated outright that kayaks should not even be permitted on the lake at all!
#195 |
I have as of late had more problems with Kayaks then jet ski's. Come in to the harbor (ocean) and they are lined up tip to tail across the channel clogging it up so that I have no place to go. This is in a 45 mile per hour zone. That is unsafe but not because of my speed but because they are clogging up the entire channel. There is no need for it. By your rational Evenstar I should be able to drop my speed boat in any lake and drive it up to any posted speed limit. There are lakes that restrict our ability to go on them. So why is it so unfair for us to be able to safely use lake Winni?
As the poster above staited when some one drives a boat at a high rate of speed their attention goes to what they are doing. I can not tell you how many times that I have seen sail boats collide especially around race courses. People are just way to anxious to legislate us trying to make it so that no one can ever get hurt/die. You can not do that. Live Free or die..... not any more I guess.... ![]() |
#196 | |
#197 | |
![]() ![]() ![]() ![]() ![]() ![]() Evanstar you are so far gone down the Self Centered highway you can't even see how Self Centered you are. I do Kayak, actually I do it often. I also powerboat often. My point was that the lake is such a large resource that there is enough room for everyone. But you are so blinded and narrow minded you fail to yield the point that you could keep to the shores and allow power boaters their space. Just as I don't tear around coves when people are water skiing. I also steer well clear of sailboats, whether in groups or alone. All I'm saying is that this lake is unique in that it offers recreation for all. You can't handle that though, you want want want. You also think you will be all of a sudden magically safer after the speed limit. I continue to stand by my post that it is dumb to kayak in the broads speed limit or no speed limit. And you're right about that I make zero apologies about that statement. As for me being a power boat snob, laughable. I love canoing and kayaking, there is no better way to see the lake. I just do it safely, for my safety and that of the power boaters. You are a power boat hater so you think your rights trump everyone else's. Just a bit of advice Mr He-man Smartypants, there will always be someone who is smarter, stronger, faster than you. That attitude will get you in some pretty big trouble some day. You know nothing about most of these posters and I've seen you insult them regularly, most recently: ... so I’m probably in better shape that most of you. and I’m likely smarter than you, All that sounds like is that you still live at home and have a lot to learn. ![]() |
#198 | |||||
I have the right to kayak on the entire lake, but that doesn’t mean that I feel that I have the right to get in the way of other vessels. I pay very close attention to where powerboats are heading and give them plenty of room. I also kayak on the ocean and supervise kayak use at my university’s waterfront. Students are never permitted to kayak out into the shipping lanes. Quote:
As far as the sailboat colliding part, have you ever raced a sailboat? I’m a collegiate sailor and a member of the Intercollegiate Sailing Association. My university team is one of the top-rated teams in North America. When you race sailboats, it is totally different than recreational sailing. We are constantly “on edge” and push ourselves and our boats to the limit (and sometimes over) – that’s the only way that you can win races. We have an entire book of rules that we must follow, but we race within inches of other boats. And when the wind shifts, or when someone doesn’t sail perfectly, we collide. That’s because we are RACING. Quote:
Well, that’s not going to happen. We’ve already made enough compromises with this bill – it has been watered down with amendments for the benefit of powerboaters – it now will only applies to Winni (instead of to all NH lakes); and it now has a 2-year sunset clause. But that’s not good enough for you. I’m done compromising. Good luck with the Class Action lawsuit. That would be like trying to sue the state for having highway speed limits.
#199 |
Haselnut, the only question that you answered from my previous post was: "Haselnut, are you just on this forum to insult others?"
Apparently the answer is "yes." (based on your reply, since it served no other purpose here). #1) You insulted me by treating me like an idiot, just because I disagree with you - I was merely defending myself - but I was recruited by my university, and my tuition is mostly paid for by academic scholarships. #2) My "unsmart" physical activities do keep me fit, and I'm a collegiate athlete. Both are true statements. How many on this forum are currently in good enough shape to compete on a collegiate team? My statement that "I’m probably in better shape that most of you" is likely an accurate accessment. #3) I posted "SEA KAYAK" not kayak or canoe - "Have you even been in a sea kayak?" #4) An enforced speed limit will make any lake safer. It's not magic - it's a fact that, all else being equal, going slower is safer. #5) I don't hate powerboats - I just hate the attitudes of some powerboat owners. #6) I'm a She #7) I own my own home in Littleton. Just because I'm a full-time university student doesn't mean that I'm a kid. That's it! I'm done defending myself. Go harrass someone else.
#200 |
Isn't youth grand?
No comments on this one? http://www.upi.com/NewsTrack/Top_New...kayaking/7360/ Rescuers cite need to regulate kayaking Published: April 30, 2008 at 10:24 AM We just had a couple of overturned kayakers rescued this week, they were drunk. |
