Old Today, 10:56 AM   #1
Default Thoughts on Pontoon Vinyl Repair
This is the side of my pontoon's rear storage cover. Thoughts on how best to repair it?
Sent from my SM-S931U using Tapatalk
Old Today, 12:04 PM   #2
DesertDweller
I have used those vinyl repair kits before with mixed results. I assume the cover has a zipper so you can remove the foam padding and attack it from the inside as well. If that's the case you have a much better shot of it working well. If nothing else, get some tape on the inside of the cover behind the crack/tear to prevent further cracking/tearing until you can deal with it. Doesn't look that big so I wouldn't loose too much sleep over it.
Old Today, 12:06 PM   #3
georgetkingiv
Post
https://www.perplexity.ai/search/d2a...2-15212e30da18
georgetkingiv is offline   Reply With Quote
Old Today, 07:03 PM   #4
brk-lnt
brk-lnt's Avatar
If you can get to the back of it you can add some repair tape for reinforcement, and then use a color-match vinyl patch kit to patch the front.
If you can't get to the back of it, then just about any DIY repair is going to be a hack with an indeterminate lifespan. I've done a lot of vinyl repairs, wouldn't consider myself an expert, but the cheap products all tend to have tradeoffs and the issues come back after a season or two.
[insert witty phrase here]
This page was generated in 0.12217 seconds
