Old 04-26-2025, 10:37 AM   #1
map
Default Dryer Vent Cleaning
In search of a company that does dryer vent cleaning. Located in the Weirs.
Old 04-26-2025, 12:40 PM   #2
Dryer vent cleaning can be a fairly simple DIY. Last year I bought a kit online, consisting of a brush and enough 3 ft rods for the brush to reach from outside to the bend in the duct just below the floor opening below the back of the dryer. The brush screws onto the first rod, and additional rods screw together as needed during the brushing. The end-most rod is driven by your own electric drill (variable speed preferred), in "forward" direction only. If the drill is run in reverse, the threaded connections come apart, and you lose brush and rods within the duct! With the dryer running on low heat (or air-only if the dryer has that), you feed the brush into the duct, drill running. Depending on how long the duct has been accumulating lint, you may get great gobs of lint blowing out the duct, so don't have your head in the exhaust stream.
Inside the house, after brushing out as much of the duct as can be done from outside, you can take take the duct off the dryer, brush the inside end of the duct, and then brush the duct inside the dryer from the exit end, but I wouldn't want the dryer blowing air out for that part. In my case, I got a fair amount of lint out of just the dryer. I also fished out an expired credit card (my son's), and a $10 Subway sandwich shop card. I have no idea if the Subway card is still valid.
Old 04-26-2025, 01:21 PM   #3
map
Thanks. Something to consider. Thing is our washer and dryer are tightly inside a closet with bifold doors and we can’t slide them out without taking off the doors and it’s become a big hassle as we are older now.
We do have a ranch house so we were hoping that this could be done just from the outside.
Old 04-26-2025, 05:21 PM   #4
TomC
TomC's Avatar
Rowell's Services says they do duct cleaning.. essentially the same thing.
https://www.rowellservices.com/cooling/duct-cleaning/
Old 04-26-2025, 06:55 PM   #5
map
I called them and the guy who answered said they don’t do dryer vents.
Old 04-26-2025, 08:49 PM   #6
I.C.Isles
I.C.Isles's Avatar
I have used
DUCTZ of Rockingham County
603.969.2202
He did a good job
I.C.Isles is offline   Reply With Quote
The Following User Says Thank You to I.C.Isles For This Useful Post:
map (04-28-2025)
Old 04-27-2025, 07:12 AM   #7
smith point boater
Default Chimney Sweep
Most Chimney Sweeps in the area do dryer vent cleaning. I didn't even know until they asked me if I wanted it done on a chimney cleaning visit. Now every time!! We use Dan - out of Wolfeboro 1-603-569-6498
smith point boater is offline   Reply With Quote
The Following User Says Thank You to smith point boater For This Useful Post:
map (04-28-2025)
Old 05-01-2025, 12:02 PM   #8
map
Thanks. I’ve scheduled him for next week.
The Following User Says Thank You to map For This Useful Post:
smith point boater (05-02-2025)
This page was generated in 0.08102 seconds
