Old 12-19-2024, 08:49 AM   #1
bobkatfly
Default Garage install
Any recommendations for garage installs from local builders?
I'm currently looking at LaValley's and mostly interested in established designs (including slab) as they have. Also, want install.
Mindset is that established designs should be less expensive because of existing manufacturing processes, tooling, etc.
Any other manufacturers around with similar capabilities? An online search only came up with customer install garage kits. I'd prefer to work with one supplier rather than be a G.C.
Bob F
Old 12-19-2024, 09:11 AM   #2
John Mercier
The LaValley's sales person can provide you a breakdown cost of modifications to a plan that you might want.
Usually the upgrade of doors to certain styles is the dramatic increases.
bobkatfly (12-19-2024)
Old 12-19-2024, 09:36 AM   #3
Default Prefab garages
LaValley can tell you all about them. You can even customize the garage to your taste. They even do site work and project management if you choose.
Best of all there is a warranty on materials and labor. And the prefab manufacturer will be around. A stick-built cannot offer.
Old 12-19-2024, 09:39 AM   #4
bobkatfly
Thanks John.
Right now I'm planning on leaving the doors standard. Will upgrade to 2 x 6 walls and fixed stairs to attic. Also, vinyl siding. Meeting with Craig (Greg?) In Middleton tomorrow.
Bob F
Old 12-19-2024, 09:42 AM   #5
You might look at Morton metal buildings. You may think metal buildings are ugly, but they've come a long way. They can make them match you home and you would never know from the outside that it was a metal building.
Old 12-19-2024, 09:56 AM   #6
Post Woodworking has moved beyond just sheds and are now doing prefab garages. Many of the shed companies are.
My experiences with Middleton/Lavalleys on warranty issues for other projects has been less than stellar, still dealing with a flooring debacle now. I'd find someone that does garages and avoid having a lumber yard build it.
There are a fair number of companies around on Facebook that you could call. I can dig up a few if you aren't having any luck.
Old 12-19-2024, 10:16 AM   #7
NH.Solar
NH.Solar's Avatar
Bobkatfly, Have you considered building using ICF walls? The advantages are numerous and the upgrade cost is relatively cheap ...especially if you DIY.
If you are planning on a truss roof I'd suggest considering upgrading to attic trusses rather than a basic truss as again the upgrade cost is relatively minor when compared to the advantages of the extra storage possibilities.
The photo is of a storage barn that a buddy & I built last year using two shipping containers decked with arched trusses. Its probably way more than you need, but it is a very cool idea and I'll bet he doesn't have $30K in it.
Check with your fire chief before going too far in considering a Morton building. I had one that was used as a cold storage warehouse at a business I ran in Concord and it collapsed during an extremely heavy spring snowstorm. The fire department wouldn't allow it to be replaced because they considered the wooden framing inside a steel shell to be an extreme fire hazard.
Finally, whatever dimension you have settled on, in the future you'll wish you had built it larger...
Peter
NH Solar
NH.Solar is online now   Reply With Quote
secondcurve (12-19-2024)
Old 12-19-2024, 05:44 PM   #8
TheProfessor
You have to do your own concrete, cement, etc. yourself.
Old 12-19-2024, 05:47 PM   #9
Morton buildings are pole barns- mostly wood. Mine is metal clad but you could finish with asphalt shingles and clapboard if you choose.
Biggd (12-19-2024)
Old 12-19-2024, 05:50 PM   #10
Yes! and those add up quickly! We are in the middle of permitting for a 55X60 building to include an ADU for my son. We are working with Middleton (Bill Gilson) via my contractor buddy that will be framing/ building it. If it were storage/ garage only, I would have done another Morton building.
The Following 2 Users Say Thank You to VitaBene For This Useful Post:
Biggd (12-19-2024), GusMan (12-19-2024)
Old 12-19-2024, 06:17 PM   #11
John Mercier
The basic specifications include a reinforced concrete slab.
If you need to enhance it with something like a frost wall or thicker slab, those are modifications with additional costs.
Old 12-20-2024, 07:31 AM   #12
bobkatfly
Yes, LaValley's includes a reinforced slab but i'll probably ask them to quote with/without it and possibly have it done myself.
Does Mortons handle the slab as well? I plan on contacting them in Auburn. I like their designs. I imagine Mortons will be more expensive but we'll see.
Bob F
Old 12-20-2024, 09:07 AM   #13
TheProfessor
Have things changed ?
Was advised that they DO NOT do any concrete work.
Old 12-20-2024, 09:34 AM   #14
bobkatfly
According to their website they include a reinforced slab but as John mentioned, frost wall will probably be extra. I assume the slab would be 4 inch but is probably less when finished. I'll have more details to share after I meet with them today.
Bob F
Old 12-20-2024, 09:38 AM   #15
bobkatfly
Was your issue with a floor on slab or attic floor? Would you share details?
Bob F
Old 12-20-2024, 10:23 AM   #16
I have an ongoing issue with them regarding LVP flooring. We purchased almost 5000 square feet of a high-end brand with a lifetime warranty for our home. We have had some issues with the material. The first time it happened they were able to replace the affected pieces. Now it is happening again, and they are telling us the product has been discontinued and replaced with a wider plank, and we would have to rip out another room and use that material to repair the bad area while replacing it with the new wider product. This leaves is with a mismatched room. We purposely used the same material throughout as we didn't want a home with mixed products and went with it because of the warranty and Middleton's promises. Keep in mind this is within a 2-year timeframe. The product distributor even came out to inspect and found no issues with the use, the humidity in the home, cleaning products used, or anything else that can be pinned back on us.
What kind of lifetime is this? How many people will experience the same problem? The manufacturer has lots of blame, but Middleton sold it and warrantied it and their solution is not great. Also there have been multiple attempts to push blame back on us.
My other issue was with a countertop install, their subcontractor drilled an extra soap dispenser hole in a 14' quartz countertop, plus we have marks on the top from the vacuum system used to pull the seams together that cannot be removed. No follow up after multiple attempts. We ended up putting in a second soap dispenser to fill the hole, and the squares are still visible. I think they didn't clean it well enough before sealing.
Old 12-20-2024, 01:26 PM   #17
bobkatfly
That's a tough situation with no reasonable solution. Is there a clause in the lifetime warranty regarding product unavailability?
Bob F
Old 12-21-2024, 10:20 AM   #18
bobkatfly
Well it turns out LaValley's doesn't do the slab for the size I'm interested in (26 x 26). Submitted our requirements and waiting to hear back on quote. I visited a friend that had one of their garages installed a few years ago (28 x 28) and was impressed with the build. Again, he did his own slab.
I'm on the fence with Morton. Not sure a pole barn style will fit my interior finishing needs without spending a lot more. Still going to talk to them though.
Going to look at a couple of local builders that did work in the neighborhood as well.
Bob F
Old 12-21-2024, 02:14 PM   #19
John Mercier
Not a specialist in the garages, but I have never heard that a standard size doesn't have a slab as part of the package. Sales person would know better than I though.
Old 12-21-2024, 04:42 PM   #20
bobkatfly
Yeah, I was surprised. Apparently, in the past they relied on customer site prep and had issues after they poured because of poor prep. Seems weird that they wouldn't inspect the prep beforehand. Either way they should revise their website as it clearly indicates an included slab.
Bob F
Old 12-22-2024, 10:14 AM   #21
sky's
unfortunetly at your expense (sorry) this is a prime example of staying in your wheel house. Middleton shouldn't be offering installations that WRONG. honestly with 20+ years i always buy my lvp at Lowes. leave 3/8" gap around the room and game over. Smart core and Perrgo are still offering great products. Another example of this being so wrong like Middletons part is take a look at the landscapers around here doing remodels and building. WRONG AGAIN i personally know of a project that happening on West Point that a landscape company is doing and the homeowner is bull****. long and short stay in your wheel house. Greed and big egos will not last. sorry for your experience.
Old 12-22-2024, 11:15 AM   #22
John Mercier
I seriously doubt they did the install. Even on the garage packages, it is a third-party local contractor; usually a group of them that specialize in foundation work, general carpentry, and garage door installs.
The problem seems to be the of the 5000SF of LVP... which even Lowes buys from a manufacturer... failed.
The manufacturer wants to only warranty the portion that failed... which would be fine with Codeman if they could replace it with the same material.
Since they can't... they no longer manufacturer that specific color in that format... regardless of where it comes from would be an issue.
Old 12-22-2024, 11:29 AM   #23
Most warrantees today are just lip service.
Old 12-22-2024, 12:59 PM   #24
bobkatfly
In general I've had bad experiences working with contractors and try to do most things myself but at my current age and skill level, this would be far outside of my capabilities.
I'll have 3 or 4 quotes including LaValley and 3 of them have done work I've already looked at (including LaValley). I was lucky to come across a few neighbors I'd yet to meet that allowed me to check some work. We'll see.....
Bob F
Old 12-22-2024, 01:03 PM   #25
John Mercier
It is the specifics of the warranty.
If the manufacturer had offered to replace all 5000SF with the wide plank, that would be great. But the warranty is probably only for the failed material; and probably doesn't cover any labor.
Old 12-22-2024, 09:24 PM   #26
tummyman
Codeman, I'd look for a solid legal litigator to review the warranty and determine your best course of action. A strong legal claim for damages might help. At least recoup your costs for the project. You shouldn't be expected to accept a different material. Sue the manufacturer, the installer, etc. etc. You used the product with an expectation of service. At least it would be worth the cost of a consult.
Old 12-23-2024, 08:52 AM   #27
WOW! I have had nothing but bad luck dealing with big-box Lowes. I bought a shed and had them install it in Plymouth, New Hampshire. The roof collapsed within the warranty period. Lowes claims that the warranty is with the mfg. Mfg, claims it is with Lowes as it is the installer problem. The installer claims it is with Lowes as they installed it within the statement of work. Vicious cycle. The lawyer says it is not worth it. I ended up rebuilding it myself. Not only the workmanship is at fault, but the design work and materials were subpar. After that fiasco, I switched to Home Depot and had great luck. Lowes and Home Depot building materials are terrible, I switch to Gilford Home Center where all the pros purchased.
Old 12-23-2024, 09:10 AM   #28
John Mercier
I did sell sheds at HD, though a long time ago.
American Shed would just get the material from us.
It got placed on several different pallets in specified pattern to make it easier to build and delivered to the site for them to erect.
I didn't know that Lowes had a third-party manufacturer for the sheds. Must be the trusses?
Old 12-23-2024, 09:29 AM   #29
bobkatfly
I had quite the surprise this past summer. I needed over 100 2x4x8's for a framing project. I typically cherry pick small quantities from HD but had to order for this quantity and went with Hancock in Wolfeboro. When it was known as Winnipesaukee lumber I always got premium boards (premium price) with very little twist, bow, etc. This delivery looked like it came from the discarded pile at HD, still with the premium price). I ended up returning about 20% and cherry picked the replacements. Not sure if it was due to the Hancock name but very disappointing for a lumber yard.
Who ever I end up with for this garage, I'll have to pay attention to who they use for lumber.
Bob F
Old 12-23-2024, 10:22 AM   #30
John Mercier
Usually a garage kit would be factory (or what we call the shop).
The walls and trusses come prefab, and the carpenters finish up on-site with trim, roofing, etc.
Old 12-23-2024, 10:54 AM   #31
I built a screen porch a couple years ago and ordered all my PT from Middleton, had to return 25% of it and go to HD and pick out my own lumber to replace the crap that they sent me.
Old 12-23-2024, 02:36 PM   #32
bobkatfly
Seems we're getting more and more into the GMO era of building products.
Bob F
Old 12-23-2024, 03:20 PM   #33
I returned the bad boards, and they told me to go out and pick my own boards to replace them but everything in the piles were crap. So, I took the credit and went to Home Depot, which is a 30-mile round trip drive for me.
Old 12-23-2024, 03:57 PM   #34
John Mercier
The lumber yards all order from the mills.
PT comes from down south, where as most dimensional comes from up north, and the finish board comes from mills in New England.
So a lift comes in graded at a certain grade, but once picked through, what is mostly left is not decent quality.
Old 12-23-2024, 06:23 PM   #35
Winnipesaukee Lumber was very proud of their quality products and yes, paid for their quality particularly the doug fir, as did the contractor. But the contractors got good boards the first time, didn't have to waste time picking through, or returning or just throw away the junk. Every board could be used so they felt the premium price paid for itself.
ishoot308 (12-24-2024)
Old 12-23-2024, 06:26 PM   #36
bobkatfly
John, so do you think it's a case of timing to get decent quality from a mill? If so, "graded at a certain grade" for a lift doesn't apply to the whole lift. That becomes a QC/sales issue.
It must be difficult for the yards. From what I understand, boards these days start off with young trees grown fast, cut economically (for the mill), then dried fast so that they still have internal stresses from moisture continuing to evaporate. Contractors and consumers need to use them fast for framing.
Bob F
Old 12-23-2024, 11:42 PM   #37
John Mercier
It isn't timing from the mill.
If you go through six or seven lifts of material, some of it is going to be sub-par.
The yards/Big Boxes normally would cull this. But if that is all they have, and the sales person doesn't make a note, the load builders will generally just send what they have.
The more wood that a yard goes through, the quicker this material builds up... and without being culled... the sales person doesn't realize that is what is left when they enter it, because the computer just shows the amount, not the quality.
The grades only matter as to how much cull you may build.
HD/Lowes tend to buy #2 or Better Eastern in our area. While the smaller yards tend to buy #1. The #2 or Better will have many #1 in the lift, but not all.
You also have Western as a higher cost option sold by some yards. Western tends to be a better quality in any grade compared to Eastern.
But for PT, which is from SYP (Southern Yellow Pine), that is all just by grade. The lumber yards tend to carry #1, while the Big Boxes carry #2.
The quick cycle of harvesting shouldn't change the certified grading. But it does mean that more of the lower grade will end up in each lift.
So the timing is more about when new lifts come in, and whether the load builder is paying attention.
Years ago, I was trained not to put into a delivery something that I would not buy for myself. I would have to make a note to the sales person to contact the customer and let them make the decision.
The Following 2 Users Say Thank You to John Mercier For This Useful Post:
bobkatfly (12-24-2024), Hillcountry (12-24-2024)
Old 12-24-2024, 08:22 AM   #38
Then they shouldn't send the crap boards out on a load.
Old 12-24-2024, 10:22 AM   #39
The Real BigGuy
I think what you are seeing with lumber loads is no different than the malaise that seems to pervade our society in general. More emphasis is placed on speed than is placed on quality. Employees are told to get it done and get it done NOW! When faced with the decision between fast or right, fast is winning.
Old 12-24-2024, 10:31 AM   #40
John Mercier
But fast can actually be slower because things need to be done twice or worse.
The correct protocol was for the load builder to contact the yard supervisor, the yard supervisor contacts the sales person, and the sales person calls the customer to adjust.
Like, you place an order for twenty 12' long double v-groove boards.
They are all good, but we only have ten. The sales person calls, if they didn't during the sales process, to determine whether you want just the ten... or if you wish to alter the order maybe taking some longer lengths.
Other things can go wrong, for instance.
I once had an outside sales person order a bunch of cedar with me.
I coded it wrong into the system, and ended up with Select Pine in the delivery.
When they asked if I had read it back to the sales person, I admitted that I had. But I did not read it as the coding... 16RCD... I stated over the phone 1x6 Cedar... and coded it into the system as 16C.
So I was at fault and not the sales person or the yard.
Old 12-24-2024, 02:21 PM   #41
bobkatfly
Yes, that happens often. I'm a retired engineer and a company I worked for had most of their product base overseas. Our main product was in extremely high demand but also demanded extremely important testing before shipping. Needless to say some product went out without full testing with no change in contract terms. That kept an international service group running back and forth between standard installations and warranty issues after installs. Jumping on a plane in Germany, then to China and maybe a stop in Spain before arriving back in Germany. I don't know how they did it.
Anyway, were we talking about garages?
Bob F
Old 12-24-2024, 04:32 PM   #42
bobkatfly
NH Solar, I forgot to get back to you. After you mentioned it I investigated ICF blocks but I don't think they're for me. This will be an uninsulated garage and I just don't see the advantage of full or partial concrete walls, especially with the increase in cost. Also looked at SIP's like the ZIP system but again, I don't need the insulation. I looked at the Morton metal buildings but pole barn construction is out also. Even with being uninsulated, I still plan on doing some interior work that would be easier with stick built. I also don't like the idea of the poles in the ground. I'll end up with a frost wall/slab construction. I know the frost wall adds a lot of cost but in this neck of the woods I wouldn't sleep nights with just a slab. Besides, I think my code guy will require it.
My funds are tight on this and I appreciate everyone's input. I'm looking at 4 quotes after the holidays. Stay tuned
Bob F
The Following User Says Thank You to bobkatfly For This Useful Post:
NH.Solar (12-26-2024)
Old 12-24-2024, 06:10 PM   #43
John Mercier
Mine is a frost wall with floating slab also.
I only had one problem with it. Because it was T-111 siding and the trim around the doors was simply applied over the top of the siding and caulked.
Old 12-24-2024, 06:30 PM   #44
bobkatfly
John, was it a LaValley design and build?
Bob F
Old 12-25-2024, 10:11 AM   #45
You can put a Morton building on a regular foundation, you don't have to put it on poles. A metal building is a fraction of the weight of a stick-built building thus the poles are sufficient to support it, and obviously it's cheaper than a full foundation. Metal buildings aren't for everyone, but they are a great option, and I would think it would be cheaper than stick built.
Old 12-25-2024, 11:07 AM   #46
John Mercier
No. It was built way back... at that time Boulia-Gorrel was operating.
Basically, they built the walls and trusses.
A independent third-party was contracted by them as part of the package to do the foundation work.
They sent their truck with walls and trusses, set the back wall, then the sides and the front... finally put the trusses two feet on center up. Then another third-party contractor under the package finished the roof, trim, and installed the doors.
Other than the foundation, we could have pretty much done the rest, but having trusses set by BG was going to happen, so adding the cost of the panel walls was worth the little extra when the package price was considered.
We started our upgrades from there.
Old 12-26-2024, 07:30 AM   #47
TheProfessor
Doely noted. As stated above.
They do not do any concrete. Next.
Old 12-26-2024, 09:35 AM   #48
John Mercier
I have an email request into the shop supervisor to see if that is correct, or the website is correct.
He's on Holiday.
Old 12-26-2024, 11:21 AM   #49
John Mercier
Bob,
I PM'd the contact for the shop super.
They do the slabs, but have stopped pouring for this year.
He would be the most precise on the subject, as he has done this for decades.
Old 12-26-2024, 12:29 PM   #50
TheProfessor
Name names and post business telephone numbers.
I was told quite clearly that they do not do any concrete site work at any time of the year.
Old 12-26-2024, 12:32 PM   #51
John Mercier
Newport is listed on the website.
603 863 1050
Just ask for Jim Luppold.
His reply to me was they offered slab work, but have stopped pouring for this year.
Old 12-26-2024, 12:52 PM   #52
bobkatfly
603 863 1050
Interesting, when I met with Greg in Middleton, He said they don't do slab work over a certain square footage. I think he said 20 x 20 but I got the impression they prefer not at all.
Bob F
Old 12-26-2024, 01:22 PM   #53
John Mercier
And to be fair, I am not sure if that is the situation on that side of the State.
It is why I suggested contacting Jim through his email.
If you aren't looking to get in before spring, he may have some decent news for you.
Old 12-26-2024, 03:19 PM   #54
bobkatfly
I have a few quotes in the queue right now. Maybe I'll give Jim a call anyway just to get a feel for what he can offer.
Bob F
Old 12-28-2024, 09:43 AM   #55
sky's
by code over a certain sq. footage you need frost walls. if your in Moultonboro call the building inspector.
Old 12-30-2024, 09:10 AM   #56
Winni Lumber was the best!!
tis (12-30-2024)
Old 12-30-2024, 10:50 AM   #57
John Mercier
Hancock doesn't stock the same stuff?
Old 12-30-2024, 01:48 PM   #58
bobkatfly
They do stock the doug fir. To be clear, when I ordered that time it was #2 appearance grade spruce. Maybe my expectations were too high but it truly was ~20% junk and the rest was just okay. I just remember much better product when it was Winni lumber. I would pick it myself and very seldom put a board aside.
Bob F
This page was generated in 0.85510 seconds
