Old 09-29-2023, 04:51 PM   #29
Originally Posted by Sue Doe-Nym View Post
There are some really great suggestions here….much appreciated, that’s for sure. I really like the one using RV anti freeze…maybe that will work here. You just can’t be too careful with our frigid climate. With all the suggestions here, I hope that these are helpful to many of you. Happy winter 🥶!
Sue, if you have a washing machine, you really have no choice but to use RV Antifreeze. There is no easy way to drain a washing machine fully. Below is a video I cut and pasted for you to show you how easy it is. The only thing I would do differently than the video is to use a full gallon of antifreeze and not a quart as they say. Also if you do blow out your lines there is no reason to remove the water lines from the back of your washer…
https://youtu.be/jp-zbirc_JI?feature=shared
Biggd (09-30-2023), Sue Doe-Nym (09-29-2023), upthesaukee (09-29-2023)
This page was generated in 0.13513 seconds
