#1 | |
For the same reasons, be careful about using LED lights anywhere on your boat. The cheap ones can really interfere with a lot of electronics from the RF noise they put out. In particular VHFs, which aren't as common on Winni, but still worth being aware of. (posting this as a general comment, not just directed only at you ![]()
[insert witty phrase here] |
ishoot308 (08-10-2023) |
Before LEDs, you could buy virtually any incandescent bulb and it would work fine. Over the last year, I've converted our homes in CT and in NH to almost all LED. I learned that in some cases, it takes trial-and-error. For example, recessed high hats didn't always work well with the standard Home Depot brand, flickering constantly in some situations or poor control with our many dimmers. We swapped those out with (I believe a Phillips brand) and the flickering stopped. We have two fixtures that require candelabra bulbs - 24 in total. Found some LED ones on Amazon, installed them only to have most of them fail after about two months. Got a refund and invested in another brand. Haven't lost one bulb after about six months of heavy usage.
The trial-and-error process is a pain but once you work through it, what's not to like? LED's save money and their cost is so much cheaper than just a few years ago. What I like most about them is they give off very little heat. I appreciate that in the summer especially. Guess my biggest worry is that they won't last as long as they say they will. It's not like I'm tracking that and I'm pretty sure quite a few bulbs I purchased in the past only lasted a few years. I chalk that up to the industry still being in a learning curve. |
The Following User Says Thank You to Winilyme For This Useful Post: | ||
FlyingScot (08-11-2023) |
If you have a string of LED lights and they suffer from flickering the problem can often be cured by replacing just one of the bulbs with an incandescent. LEDs are voltage driven whereas incandescents are much more heavily amperage driven and the increase in the current draw will stabilize the wattage flow in the string.
#4 | |
I get it—I had my fair share of LED frustrations, too. The harsh light and flickering drove me nuts. I finally stumbled upon the SURNIE LED Neon Lights—game-changer. It's like finding a needle in a haystack. I needed them to add more colour to my living room, and they are perfect. I even saw them on this cool website called Leds; they have all types of LED lights and bulbs. If you ever need more lights, you can find more information about them here, and the best part is that they describe their products so well that it's easy to understand if they are an excellent fit for you.
