I wonder if this new law is applicable to inland waters in NH?
https://uscgboating.org/recreational...ff-devices.php |
I don't believe so. This has to do with USCG regulated waters. However, its a safe bet that NH will adopt similar regulations where the marine patrol has jurisdiction in the near future.
So this new rule doesn't apply to the Honda 2.3-hp outboard commonly used on small sailboats because it is smaller than 3-hp. Maybe the Coast Guard should change the rule to include the 2-hp engine.
New April 1, 2021 safety lanyard wearing rule applies to 3-hp and larger engines on boats up to 25' 11" in all the 50 states, inland waters and coastal ocean waters. It applies to all U.S. navigable waters. Does this new rule apply to Lake Winnipesaukee? The smart money say that YES, it does! So, while N.H. does not have a required seat belt law for driving a car, it now has a required safety lanyard use rule for driving a boat, effective April 1, 2021. You know that here in N.H., truck drivers are required to use seat belts by federal rule, while car drivers have a choice on seat belts under N.H. state law.
#4 | |
I think Cow Man is correct. It’s only waters that are managed by USCG. But state laws will likely adopt it.
https://www.wakeboardingmag.com/stor...-off-switches/ |
| The Following User Says Thank You to mswlogo For This Useful Post: | ||
Cow Man (04-04-2021) | ||
The key in my opinion is that this rule applies specifically to "Navigable waters."
The Coast Guard defines navigable waters as, "Navigable waters of the United States are those waters that are subject to the ebb and flow of the tide and/or are presently used, or have been used in the past, or may be susceptible for use to transport interstate or foreign commerce." - 33 CFR Part 329 New Hampshire went to a lot of trouble a few years back arguing successfully that NH lakes are not navigable waters and consequently not under coastguard jurisdiction. That said, it would be wise to use the lanyard if you have one. |
| The Following User Says Thank You to Cow Man For This Useful Post: | ||
CooperS7777 (04-04-2021) | ||
Does this mean, if the lanyard is not attached to you or your life jacket, you will be ticketed?
#8 | |
Tough to enforce as a "primary stop" since nobody can see the lanyard. If you get stopped for some other reason, stand up to get your wallet/registration, it may be obvious, but not if you have it on your wrist as described above.
This is probably a good idea, especially if you like "Nanny laws", but like seat belts and M/C helmets, no special law will change much. Eventually, mfg's will put a pressure switch in the seat as an ECOS, just like my lawnmower. Recall, not so many years ago, a single operator was ejected when his steering failed and the boat turned suddenly. The boat kept running in circles, but it was some time before the operator was found. No PFD! When you're alone, where a self-inflating PFD. |
For sail boaters, it should be required a handcuff be used to attach sailor's wrist to the tiller handle. This will encourage sailor to keep from flipp'n sailboat with himself handcuffed to tiller handle. ...... whoopsie ....... just a thought! ....
The first time many people become aware of the kill switch lanyard is when the clip falls off the switch and they can't figure out why the boat won't start.
| The Following User Says Thank You to TiltonBB For This Useful Post: | ||
jst_4_kiks (04-05-2021) | ||
#12 | |
I have seen that more than once and in at least one situation where it was dangerous, in the Merrimack river and current was moving fast due to the tide change. There is value to lanyard kill switches, but I dont agree they are always needed, and a seat switch (like on a lawn mower) would be a huge problem in some boats where you stand more than you sit during operation. I dont see a perfect perfect solution to the concern some have about out of control boats. |
| The Following User Says Thank You to XCR-700 For This Useful Post: | ||
Descant (04-05-2021) | ||
#13 | |
The perfect perfect solution is to pin the oars with a ss 10-24 x 3" round head screw that mounts the oar within the oar lock ....... that was too easy! .....
#14 | |
Now I have seen row boats where the oar locks were not secured at the bottom (into the socket) and depending on the angle they were mounted, you could have a problem with the oar lock trying to ride up and out. But then none of that has anything to do with this thread. So I propose we discuss loose change falling out of boat operators pockets and options to prevent such. Its as relevant to the new lanyard law as row boat oars and possibly more so, as an operator attempting to retrieve his/her lost change might twist/move in such a way as to unintentionally pull on the lanyard and shutdown the vessel. Would this be a helpful or dangerous application of the kill switch? |
CooperS7777 (04-05-2021) | ||
The concept of a cutoff is fine I get it, having manufacturers put them on vessels under a certain size, great idea. Making it mandatory to use them is stupid. The only application of mandatory use that makes sense to me is a jet ski because of the very high likelihood you're going to get separated from the vehicle while in use.
The rest of this is just feel good nonsense. If a boat is being operated in a responsible manner a lanyard should never be needed. In fact I would argue that an unexpected engine cut out at a good say 30-35 MPH has the potential to be even more dangerous as passengers may not be prepared for that and get thrown all over the place. Even better for a wake surfer who is literally feet off the back of the boat. Bet that transom will taste good. I bet this causes more injuries than it is supposed to avoid. |
| The Following User Says Thank You to MAXUM For This Useful Post: | ||
8gv (04-05-2021) | ||
#17 | |
https://www.nytimes.com/1976/04/18/a...%2C%20Reprs%20 |
#19 |
You know that truck drivers are required to wear seat belts in N.H. while it is a choice for car drivers.
For this new boat lanyard rule it will be an unanswered, open question, until it gets a public response from the State of N.H.
#20 |
Commercial drivers come under DOT
#21 |
Perfect, new content for North Woods Law.
#22 | |
#23 | |
Damn rules for everything, what happened to Live Free or Die??? Bet all the Mass transplants get that slogan changed soon! |
#24 |
#25 | |
There are many situations in which proper use of a lanyard may lead to a totally different outcome at the end of the day, even in cases where the boat is being operated responsibly; steering failure, collision with debris in the water or unmarked hazards, medical emergency, mechanical failure etc. Add on top of that the number of OTHER people on the water (many of which do not operate their boats responsibly), and the potential interactions your likely to have with them while on the lake, and the possibilities are endless. Thats almost like saying if everyone on the road operated their vehicles in accordance with laws, no one would need to wear a seat-belt. Lastly, in MOST boats, the transition from cruise to dead stop via way of chopping the throttle or killing the engine is not typically very violent. There are times when its more abrupt than others, such as transitioning off plane, and yes, it is absolutely more abrupt than simply throttling back, but if passengers are standing and holding on, or properly seated, no one should be thrown anywhere. |
#26 | |
![]() Sorry. could not resist. I love the lakes region and the mountains. |
#27 | |
But this has nothing to do with lanyards, unless I pull mine out while eating Sawyers in the boat. Does mine have lanyard??? Guess I better check when PBM starts valet service,,, TICK, Tick, tick,,, |
#28 |
Here's a more in-depth look at http://www.propellersafety.com/15702...itch-lanyards/ ... from January 16, 2021.
Just have to wait and see what happens with it here in NH? What this says is first offense-$100, second offense-$250, additional offenses-$500 so will it get enforced by the NH Marine Patrol and NH Fish & Game? Probably, NH will decide what it will or will not do with new federal law and does it apply to NH waters? For kayak it requires a safety line be attached to the paddle, so's you do not lose your paddle, and be up the creek without a paddle ...... ha-ha-ha ..... ho-ho-ho ....... just kidding about the paddle safety line ....... sorry. ... ![]() USCG news release, March 10, 2021: http://www.propellersafety.com/15880...-news-release/
#29 |
#30 |
We go EVERY opportunity, for me since the early 1960's. Though back then (for my family) it was in competition with Dots in Alton.
Only on special occasions did we go to Harts or maybe even Baileys,,, NONE of which required safety lanyards to be served. Actually dont recall seeing safety lanyards on boats until maybe the 90's. Seems like they serve a purpose in rough water, but rarely a benefit to the masses. I guess its like everything these days, we seem to almost completely ignore the major issues and focus on problems that impact very few. Five times as many people die in the US from food poisoning than in boats, but we see little progress in that industry. But lanyards in boats, thats important enough to be a requirement. Maybe so, but how we got to that before other items makes me scratch my head. I can see a number of potential requirements long before lanyards. How about automatic bilge blowers for starters,,, Never mind, this will only start more arguments. |
CooperS7777 (04-06-2021) | ||
#31 |
It'll take somebody getting killed or seriously injured before this is re-thought. Just give it time......
What it won't do is fix stupid. |
#32 | |
https://www.bing.com/imagePBMs/searc...u6fWW2ijKrK5vw
#33 |
#34 |
On December 20, 2019 the President signed the legislation raising the federal minimum age of sale of tobacco products from 18 to 21-years.
Seven months later, on July 29, 2020 Governor Chris Sununu signed House Bill 1245 which increased the age from 19 to 21 to purchase, sell or possess tobacco products here In New Hampshire. So, what will happen with the new federal safety lanyard law? I don't think the NH house or senate majority will see a need for it and will ignore it similar to how NH treats the federal seat belt law for cars. New Hampshire loses out on maybe 5-million dollars in federal highway funds every year by not having a seat belt law, and could also lose out on federal funding for boating and water safety by ignoring this new safety lanyard law. We don't need the feds telling us to go wear a seat belt or go wear a motor boat lanyard ...... live free or die! .... bah humbug! .... ![]() After all, it is the principal and not the money that really and truly matters! ..... live free or die! ... bah humbug! .... ... blah-blah-blah!
#35 | |
Gotta love the aircraft of that era. We have nothing like them today. Kudos to the men and women who built and supported and piloted them. And while the war was a horrific and unimaginable event, the post-war period up to maybe 1980 may have been Americas best for quality of life for the masses of middle class Americans. Not perfect by any means, but for me personally, far better than what we have today. And I'll bet the only lanyards the PBM pilots had were attached to 1911's ;-) Live Free or Die! ATB |
ApS (04-13-2021) | ||
#36 | |
Better to roll back funding and revert to wilderness. Ban houses from being withing a mile of lake, and put a fence around it with a gate only wide enough to carry a row boat through. Limit the number of row boats to 1 at a time. No need to live free, you can become Taxichussetts North, add some excise taxes, income taxes, some sales tax. Make NH a sanctuary state and you folks can pay the tab for all the people that they can ship to live in your hotels. Maybe adopt some of Bloombergs ideas like bailing our convicted criminals to go vote, banning big gulps to ensure no one ever gets past a government mandated weight, spread your wealth to others, and so on. Isnt that much better than what you have today. Its easy, just drink all the kool-aid the politicians and the media offer, and soon you will be mixing the kool-aid and serving it yourself. Forget about Live free or Die,,, NH can become the next Bronx or Brockton or Watts. Isnt that much better than actually adhering to the concept of Live free or Die,,, Edit - addition; Just to be clear, please dont take any of this as in anger from me or hostile. This is just a forum, real life happens off the keyboard. And as opposed to some perspectives I LOVE visiting Winnipesaukee, and the various waterfront towns and hope to see people there with their boats and families and shopping and eating at Sawyers and such and enjoying themselves. And if I could, I would happily turn the clock back to 1960/70 something and the days of 20' runabouts with 2 cycle outboards or Jet drives with rooster-tails and above the waterline exhaust - and pinball arcades and so on. We are here now and must live with progress. But I dont have to agree with progress or like someone elses vision of a perfect Winnipesaukee. We all have our preferences and we all struggle to hang onto what we enjoy. Hopefully what we enjoy doesnt clash too much with someone elses preferences, and where it does, I hope we can find a way to avoid too much heartburn over it. Oh, and I dont like lanyards, but I dont oppose them being installed at the factory ;-) ATB Last edited by XCR-700; 04-07-2021 at 12:38 PM. Reason: Enjoying the rant too much |
#37 | |
#38 | |
| The Following User Says Thank You to swnoel For This Useful Post: | ||
stingray (04-07-2021) | ||
#39 |
#40 | |
![]() The erosive effects on shorelines can be invisible for years. https://www.kenoshanews.com/news/no-...2819b4a19.html |
#41 | |
You will benefit or suffer depending on what government services you want and how much you want to pay in taxes. The choice is your, exercise it or someone else will. |
#42 |
#43 |
Fay's news letter "AT THE HELM" says
(verbatim) The recent passage of the amendment to 46 USC 4312 requires all operators of boats use/wear the boat's Engine Cut0-off switches (ECOS) when operating above headway....... https://faysboatyard.com/fays-boatya...rd-newsletter/ I thought this new regulation was not applicable to the lakes. |
#44 |
Thanks for posting the newsletter.
Within that newsletter under the Exceptions section: In NH, federal agencies can enforce this on the coastal waters and those under the jurisdiction of the Army Corps of Engineers. NH does not yet require mandatory ECOS wear. As a result, Marine Patrol Officers will not be enforcing this federal requirement. Enjoy this beautiful day! |
| The Following User Says Thank You to Bernie Girl For This Useful Post: | ||
MotorHead (04-10-2021) | ||
#45 | |
"NH does not yet require mandatory ECOS wear. As a result, Marine Patrol Officers will not be enforcing this federal requirement." |
| The Following 2 Users Say Thank You to Descant For This Useful Post: | ||
codeman671 (04-11-2021), MotorHead (04-10-2021) | ||
#46 | |
If you were to enact legislation now to prevent any future development it would severely devalue the property it affected. I would think the the land owners would have a cause of action to recover the amount of the diminished value. If a family held a mountainside plot of land for the last 100 years, intending to develop it at some point, how do you take their dream away? I have no skin in the game but even if the majority was to want development curtailed I think it is too late to prevent future building on view lots. |
#47 |
Don't forget "Speaker of the House". Not only do you not have to read a bill, you actually have to pass it to find out what's in it.
#48 |
I've always thought that the ideal lake house is one with a great view of the lake but can't be seen from the lake. The same can be said of a mountainside home. This is impossible to achieve totally, but there are some things that can be done to have a good compromise. I for one had no wish to build a monument to myself for others to see.
#49 |
I would definitely prefer to see (and keep) the natural landscape mother nature provided, however, I would rather see a FEW houses, than windmills. JMHO
#50 |
No just the opposite I see this new law as causing more injuries. I'd love to see the statistics on the number of boating accidents that occur on an annual basis where it has been determined that use of a cutoff would have prevented them. It seems as though every time I read of an accident, it is always the same combination of reasons, inexperience, operating outside safe parameters for the conditions or congestion, operating under the influence or some other operator error. I've never gotten the impression that the majority would have been avoided with a safety lanyard in use.
I guess it just begs the question what's the intended purpose of this cause I don't see it. I do however see having an engine cut out unexpectedly being a huge safety problem. It doesn't take much for them to pop out and flip the switch. I sometimes wonder who thinks this stuff up. It seems that every time something tragic happens the knee jerk reaction is to pass some new law. |
Top-Water (04-12-2021) | ||
#51 | |
If you want to complain about the lack of a seat belt law let's not forget about all the democrats that had years to do something and did nothing. Funny how you just conveniently forget about that. Love the selective outrage. You may want to take a basic civics lesson on the difference between federal and state law. If a federal law is passed it is effective in all 50 states and supersedes state law. There is no such thing as a federal law that is passed then the states decide if they like it or not - it doesn't work that way. There is NO federal seat belt law that requires use, the only federal law on the subject was passed in the late 60's that requires all vehicles to be manufactured with them. Any mandatory use laws are set at the state level. The feds have tied a consolation prize of access to strings attached federal funding if they happen to have a mandatory seat belt law in place. It's NOT free money to be spent on whatever and however the state wants to. Far as the lanyard law goes, again FEDERAL law, state has no say in this, it is only applicable to federally regulated waterways under USCG jurisdiction. The lake is not federally regulated thus it is not applicable here. |
Top-Water (04-11-2021) | ||
#52 |
I bought one of these a few years back. I must say it's very handy; it's nice not having to wear the lanyard. If I happen to go overboard, the engine cuts. It has about a 60-foot range when it will also trip. To some degree they were problematic plus they were expensive. That combination plus limited funds and low sales volume equaled a very short production period before they went out of business. Now FELL Marine offers one, however, it needs to be hard-wired to the ignition.
I'd rather be relax'n at Winnipesaukee |
| The Following User Says Thank You to salty dog For This Useful Post: | ||
XCR-700 (04-11-2021) | ||
#53 | ||
#54 | |
I have not seen anything like this and always find it interesting to learn of new technology even if I dont desire it myself. Thanks! Last edited by XCR-700; 04-11-2021 at 09:58 PM. |
#55 |
Could Gov Chris Sununu issue an executive order giving the Marine Patrol discretion to enforce this new federal wear-your-boat-lanyard rule or would it require a new state law passed by the legislature and signed by the governor?
#56 | |
#57 |
In NH the state police and all local police will cite a truck driver for not wearing their seat belt and a seat belt violation costs about $125 and stays on their driving history record for a long 15-years time.
So, until the Governor issues an executive order, for now the Marine Patrol has discretion to cite a 20-year old boat driver for possession of tobacco but not for NOT wearing the safety lanyard. This seems like a very unusual law enforcement situation? So, having a single cigarette in your pocket IS a violation. Driving a 16' aluminum Alumacraft with a 60-hp two-stroke outboard at 40-mph while NOT wearing the safety lanyard is NOT a violation. If the boat hits a wake or something and the driver gets bounced away from the steering wheel and throttle, the boat will continue to go places at 40-mph with no one at the steering/speed controls.
#58 | |
The use of executive orders are not intended to circumvent the legislature and take legislative action. Obviously there are under extreme circumstances some aspects of emergency power that come into play but that is an entirely different subject not applicable here. Executive orders have been abused as of late to the point where the intended purpose of executive action and the constitutional limitations placed on them has strayed well beyond it's purpose. The governor and for that matter the President are not absolute rulers otherwise there would be no reason to have a legislature in the first place. |
| The Following 2 Users Say Thank You to MAXUM For This Useful Post: | ||
ApS (04-12-2021), CooperS7777 (04-12-2021) | ||
#59 | |
#60 | |
The commercial world is completely different. |
#61 |
#62 |
