10-31-2019, 08:52 AM | #1 |
Winterization question
Hello guys, I'm doing my own winterization and started it a couple weeks ago. I ran into a problem that I'd like to solve this weekend with the freezing nights coming soon. I have an 89 ebbtide with the 350 mag, one side of the motor winterized fine but the other side I couldn't get the antifreeze to run through. I went through about 4 gallons just on that side. The antifreeze kept coming out one of the lower ports on the thermostat but not the block drain. The block drain did drain all it's water prior, so it's not clogged. I'm thinking maybe because the boat was slightly uneven when I was doing this? Just trying to get some ideas before I attempt to finish it up this weekend. Thank you.
10-31-2019, 09:23 AM | #2 |
Double check that block drain by inserting a piece of wire or small finishing nail into it. I know you said it drained all the water prior, just trying to eliminate all possibilities. I have had a piece of rust lodge in mine from time to time preventing flow. Good luck.
10-31-2019, 09:37 AM | #3 |
Remove the thermostat round plate which is easy to do, otherwise it will act like a closed valve to the flow of coolant/anti-freeze.
ApS (10-31-2019) |
10-31-2019, 10:09 AM | #4 |
All thermostats have a small bleeder bypass built into them usually on the housing which allows some fluid and also air to pass through whether open or closed. The purpose of that is to prevent pressure buildup unequally on either side that may prevent it from opening up or burp the system so the thermostat is not sitting in a pocket of air. In other words the thermostat does not completely cut off flow, only restrict it until sufficient operating temperature has been reached. At least that is the way mechanical thermostats work.
10-31-2019, 10:47 AM | #5 |
Thanks for the ideas. It definitely isnt blocked. Hopefully more chime in. I'm thinking either to park it leaning more towards the port side since it was leaning starboard last time, and also to put the hose back on the t-stat port where it was flowing out before. I believe it was the bottom left port. Just don't want to waste so much antifreeze trying to get this right.
10-31-2019, 03:21 PM | #6 |
I've always poured the AF into the block by removing the hose after the thermostat and pouring the AF into the block there. My experience is limited to inboards with GM blocks. I also believe you don't "need" to fill the block with AF, as long as you drain the block and manifolds properly.
10-31-2019, 03:47 PM | #7 | |
I know somebody that just drains the block, risers and manifolds and leaves it as is. Never had a problem either. |
11-01-2019, 08:06 AM | #8 | |
11-01-2019, 08:46 AM | #9 |
My method uses a small, three gallon size plastic trash can, a piece of garden hose, a hose shut off valve and a set of earmuffs for the lower unit.
This set up allows the lower unit to draw antifreeze in and distribute it throughout the engine. First I run the motor on a different hose and earmuffs for long enough to get the thermostat to open and the water to come out of the engine quite hot. This may take fifteen minutes or so. Once the engine is hot enough I switch to my bucket rig. Starting with the bucket full of antifreeze, I run the engine and add more antifreeze as required until all the water coming out of the engine is bright pink. It usually take about four to six gallons of antifreeze to get to that point. As the last of the antifreeze is entering the engine I spray fogging oil into the carburetor throat until the engine stalls. Then I remove all the blue plastic drain plugs from the engine. I hope that helps! YMMV |
11-01-2019, 12:39 PM | #10 |
My boat (Volvo Penta I/O Chevy engine) is now on its 22nd winter. Never done anything but drain it. Hope I'm not jinx'in myself now!
11-01-2019, 12:57 PM | #11 |
When living on Cape Cod we had a 200 hp Merc outboard. In winter all I did was pull in December and cover everything. Never had a problem in the 20 years we had this engine.
Maybe I was just extremely lucky? _________________________________________________ I am a retired workaholic and continuing aquaholic |
11-01-2019, 02:38 PM | #12 | |
11-01-2019, 02:53 PM | #13 | |
Hose #1 goes to the water pump and block. Hose #2 goes to the stern drive and backfills the impeller housing Hoses #3 and #4 go to the risers. I disconnect all of them and start backfilling #1 till it starts to come out the housing where it was connected (takes about 1.5 gallons). Reattach hose and move on to #2 fill that till it starts dumping out the intake on the stern drive (takes about another 1/2 to 3/4 gallon). Reattach and backfill #3 and #4. Split what is left between the two. Any extra will dump out the exhaust ports in the stern drive housing. Again I leave the antifreeze in the engine as it supposedly has rust inhibitors. In the spring roll the boat into the driveway put the muffs on and fire it up. |
11-01-2019, 06:59 PM | #14 |
I have a mercruiser 350 magnum. I winterize my engine through the earmuffs because I figure it is going to get antifreeze everywhere there was water... I run the engine up to running temp to get the thermostat open on the garden hose. I then drain the riser's and the block of all the (hot) water. Then I put the plugs back in the riser's and the block, and I have a 5 gallon jug that has it's own set of engine ears. I then start the motor back up while running on the engine ears connected to the 5 gallon jug of RV antifreeze. It is gravity fed. I run about 15 gallons through the system, making sure that all I see is "pink" coming out of the exhaust, and just before I run out of antifreeze, I fog it, and stall it out on the fogging oil. I then leave it just like that for the winter. I leave the antifreeze in it. After the motor cools down, I spray it down completely with wd40 silicone to preserve plastic and rubber, and helps to keep critters away. I also dump about a half gallon of antifreeze down the bilge just to mix it with any standing water. I also put a couple of the little buckets of scented "damp rid" in the boat. One in the cockpit area, and one on the floor of the cuddy cabin. That is my annual ritual, as well as changing the gear oil in the outdrive. It is now ready for shrink wrap...
11-02-2019, 03:38 PM | #15 |
hey guys thanks for all the tips and advice. I think I got it sorted today. I might have been using the riser hose instead of the manifold hose last week. I also back the trailer up onto a ramp on one side to get the motor to tilt the opposite way. I also made sure to run coolant through the lower unit pickup hose! Thanks all. Now i have another problem/question I'll be creating another thread for.
11-02-2019, 07:08 PM | #16 |
11-02-2019, 07:15 PM | #17 |
Why don’t you just remove the 4 drain plugs and call it good? Engine is drained once you do that.
I have the same year motor, do it every year without issue. Coolant is a waste of time and money. |
11-02-2019, 07:36 PM | #18 |
So you're one of those huh lol. Idk rather just be safe once we're in the dead of winter and it's below 32 for weeks at a time.
11-02-2019, 08:43 PM | #19 |
No you're not fully drained... there are 5 plugs not 4. At least on a V6 or V8. I believe the 4 cylinder has 2
11-02-2019, 10:01 PM | #20 |
11-03-2019, 06:37 AM | #21 |
11-03-2019, 08:55 AM | #22 |
Where are you located? I can come help if you want.
We are talking a 1989 boat here correct? 2 plugs on each side of mine, one on the bottom of the exhaust manifold and one on the block . Total of 4 plugs. Where is the 5th plug? |
11-03-2019, 09:41 AM | #23 | |
Using antifreeze is a relatively new idea to me. Maybe 20 years ago my marina started putting AF into the block and then reinstalling the drain plugs. The idea was that everything was all set for the winter, and in the spring there was no need to pay/hire a mechanic to reinstall the plugs. Just connect the battery, start and go. The cost of AF was cheaper than the second hour for the mechanic, and the spring scheduling was quicker. |
11-03-2019, 10:23 AM | #24 | |
11-03-2019, 02:10 PM | #25 |
Antifreeze has anti rust inhibitors in it, and gives me more peace of mind knowing it's inside my motor than it being "dry" in there. And I also believe that just draining the water out is never going to get it all out, so running antifreeze through it will at the very least, dilute any water left in it, if not push it out completely. Just my .02 cents.
11-03-2019, 02:12 PM | #26 |
One on each side of the block, one on the bottom of each intake manifold, one that is located on the hose that is attached to the water pump, at the lowest point there is an inline plastic elbow with a drain plug in it. 5 total. If you do not have that elbow with the drain in it then that low spot will not drain. Now one of two things is possible, this elbow insert was an adaptation that was added by the MFG to all later models or somebody replaced the entire thing with a single hose that may or may not drain completely.
Either way - I'd make darn sure there was no water sitting in that over the winter if there is no drain present. Easy enough to just pop that hose and drain it. The only reason why I would favor backfilling with antifreeze is to remedy any areas that do not completely drain using this as a prime example. |
11-03-2019, 02:13 PM | #27 |
(A lot) cheaper than a new motor. I wasn't aware of any "shortage" of anti freeze. Didn't know I was supposed to be "conserving" it. I like to run it for a few minutes on antifreeze to ensure the thermostat opens completely for maximum circulation, and more importantly, peace of mind knowing that the antifreeze gets to every crack and crevice where there was water...
11-03-2019, 03:34 PM | #28 |
I helped a friend do his this morning, he used a 30 gallon drum and plopped the outdrive right into it, ran it until it was up to temp and the mixture in the drum was warm, fogged it and put it to bed. The drum gets covered so nothing gets into it and is reused the next year. Works for him.
11-03-2019, 03:57 PM | #29 |
Boats are like women, hence, the use of feminine pronouns, in that no two are alike, and what works for one may not work for another. I rest my case.
11-03-2019, 05:40 PM | #30 | |
11-03-2019, 08:19 PM | #31 |
On the other side right next to the fuel\water separator. Pretty hard to miss IF it's there. I would be very concerned that if it isn't the water pump housing would not fully be evacuated of water and the bottom of that hose would have a pocket of water that will freeze and damage the hose. It's in the largest diameter hose.
Below vid shows where they all are. I am fairly certain these are in the same locations on the V8 as well as the V6. Shown in the video is the V6. https://www.youtube.com/watch?v=tVyOG0Fw7AA |
11-04-2019, 08:24 AM | #32 | |
11-04-2019, 09:33 AM | #33 | |
FYI this is a 2003 4.3L V6 Does that help better illustrate the location? It's a little embarrassing - my bilge is not as clean as it should be - I need to clean it! |
11-04-2019, 11:00 AM | #34 | |
11-04-2019, 05:13 PM | #35 |
Ya good call - to me having antifreeze sitting in the engine block over the winter just makes me sleep better at night. Cheap insurance is what I say.
