Old 07-22-2018, 01:12 PM   #1
Default Electric Stove repair ?
Just moved into a new home (to me) in Gilford.
One of the burners on the electric stove (KitchenAid), does not work.
Stove is not that old, maybe 5 yrs old. I need to have someone come to repair.
I searched the Forum for appliance repair an came up with these recommendations:
Crown Appliance Repair out of Center Harbor.
RELIABLE" 800-900-.0428
Pilgrim Appliance Service (Joel Ducharme), (603) 522-3978.
Anyone else have electric stove issues ?
Thanks !
Old 07-22-2018, 01:53 PM   #2
Thanks !
Baron’s does repair on Kitchenaid appliances...
bigdog (07-22-2018)
Old 07-22-2018, 03:05 PM   #3
But doesn't Baron's use Reliable? They did for me when I bought a new dryer that had a door issue. I like Reliable.
Old 07-22-2018, 03:32 PM   #4
chasedawg
Default Reliable
We have had to use Reliable several times for electric stove, washer and dryer. They were very good and helpful. Helpful in getting warranty issues resolved as well as how to maintain and what to look for when buying appliances.
Old 07-22-2018, 04:16 PM   #5
You might be right Tis, they may sub out their repair work.
We have had Baron’s out to do repair a couple times on our appliances. Whoever came, was on time, professional and made all necessary repairs to our satisfaction.
Old 07-23-2018, 08:38 AM   #6
chasedawg
Default Barron's uses Reliable
Yes Tis...you are right. We bought all of our appliances from Barron's. When we needed service we called Barron's to report our issues and they contacted Reliable for us.
Old 07-23-2018, 08:49 AM   #7
I use to replace them myself. I had an brand new extra one that I just threw out recently because I remolded my kitchen and replaced all the appliances.
Old 07-23-2018, 10:07 AM   #8
Anvil
I've used Crowne a few times. They do good work and are reliable.
Anvil is offline   Reply With Quote
Old 07-23-2018, 10:36 AM   #9
In past years I have replaced burners on stoves many times. I do not know what the configuration of your stove is but the burners I replaced were very simple plug ins.
If that is your situation and there is another burner the same size just swap them to make sure it is the burner, not the switch. With the model number burners are easy to buy.
Two weeks ago I replaced the heating element in the oven in a rental apartment. Two screws, two wires. This is not rocket science, it's very simple.
Old 07-23-2018, 12:12 PM   #10
longislander
If the other burners are working, it just might be the burner, nothing else. You could pull-out the other same size-burner, first, place into "bad burner" slot, and see if it works to confirm it's the burner. Bring burnt-out/broken burner to Lowes/Home Depot with you, match what is on the shelf, and replace.
longislander is offline   Reply With Quote
Old 07-23-2018, 12:50 PM   #11
My stove is 'glass top' type.....
Is that easy to remove ?
Old 07-23-2018, 03:17 PM   #12
longislander
Didn't realize it was glass top, but the repair concept is the same. Not quite as simple as pulling off the element of a non-glass stove..
Here's a youtube flick showing replacing a glass top type. Still easy, but more steps, and caution for the glass top.
https://www.youtube.com/watch?v=vzlLHJiy5KE
This page was generated in 0.38433 seconds
