Old 05-09-2018, 09:32 AM   #1
Water Camper
Default Skeg Repair
Can anyone recommend who does skeg repair ?
Thanks,
Bill
Old 05-09-2018, 01:08 PM   #2
DBreskin
Thanks,
Bill
I had my OMC Cobra skeg repaired at East Coast Welding in Gilford. They had at least six Mercruiser drives to repair as well. I was very happy with the price, quality and speed of the repair.
Old 05-09-2018, 01:45 PM   #3
Depending on how bad it is, you can buy a skeg repair kit to go over the old one. It's kind of like capping a tooth. All the skeg really does is protect the prop and not very well I might add. Of course if it's completely destroyed then you would have it replaced.
Old 05-10-2018, 09:39 AM   #4
Water Camper
Default skeg repair
The tip of the skeg is broken off, the rest is just pretty brittle due to oxidation. Don't want to put a lot into this outdrive as it may be time to look at replacement. Over 1,700 hours on it.
Thanks,
Bill
Old 05-10-2018, 10:14 AM   #5
Thanks,
Bill
If its just the very tip, you may not want to do anything except file it smooth.
Old 05-10-2018, 11:15 AM   #6
John Spooner at Diamond Shine does this work.
Old 05-10-2018, 11:26 AM   #7
Hillcountry
Hillcountry's Avatar
I put one on a Volvo penta skeg on a bowrider I owned and it worked as advertised.
https://skeggard.com
Old 05-10-2018, 11:34 AM   #8
Got one of these in Florida.......cheap and easy fix and looks good
Old 05-10-2018, 11:38 AM   #9
Thanks,
Bill
Just go on line and order a stainless skeg repair kit. It just goes right over the old skeg. You may just have to file it down a little if it's bent or there are any jagged edges. It won't look pretty but it will work fine. You'll just have to hide your head in shame when taking the boat out of the water.
Old 05-13-2018, 11:20 AM   #10
Hillcountry
Not necessarily. I put a Skeggard on a perfectly good skeg to protect it from Winni's notorious rocks and it did it's job when I did make slight contact with one while traversing a narrow area between islands.
Old 05-13-2018, 11:32 AM   #11
John has fixed mine in the past. He did quickly and very reasonably!
Old 05-14-2018, 02:16 PM   #12
I ordered a new TIG welder recently to fix a skeg on an extra bravo 3 drive that I'm building from spare parts, but the welder has not arrived yet. If you can wait, and have trouble finding someone to repair it, ping me. I have plenty of scrap aluminum to use and should be up and running with the TIG before the end of the month.
VitaBene (05-14-2018)
Old 05-31-2018, 10:40 AM   #13
Water Camper
Default Skeg Repair
As I mentioned earlier, it was just the tip of the skeg that broke off. I have put the boat in the water, does not seem to have an impact on handling. I will probably leave as is for the summer. Thanks for everyone's input.
Bill
Old 05-31-2018, 12:55 PM   #14
Bill
Smart move! If it’s just the tip file it smooth when you have a chance and be done with it.
Happy boating!!
This page was generated in 0.09563 seconds
