Your battery is no good.
The voltage you are reading just shows a surface charge. The battery does not have enough cranking amps to engage the starter. Assuming it is a 12v system, jump the battery with your car. In the spring get a new battery at WalMart. Bring the old one to avoid a core charge. |
When you get the new battery get on with the most CCA available that will fit in your tractor. I replaced my battery last month with one from Lowe's. Magna something. It cranks so fast there is no starting sound, just the engine running.
Every home owner tool box needs at the minimum a battery load tester.
I have a CA/CCA tester as shown in the attached video. http://youtu.be/FUgWNpz34-g
#4 | |
And FWIW, I agree with the other posters that your battery is likely nearing its end of life.
Getting ready for winter! |
