I'm have constant issues with the Boat to Trailer Tie Down straps.
These are the ratchet type, that connect from stern eye bolts to rear of trailer, I hate them ! There must be a better solution ? The ratchet type straps give me no problems tightening, but when I want to release them to remove before launching the boat, they ALWAYS give me issues, and don't ever seem to release easy ! Am I doing something wrong, or is there a better product. Thanks. Bigdog |
#2 | |
The narrow ones I have used were difficult to disengage. On ones a bit wider and the release handle is easier to grip and use.
Bass Pro Shops has some wide handle ones. They are not cheap. |
#4 | |
Bigdog, Are you opening them up all the way (180 degrees) when you are trying to loosen them? You need to pull up on the trigger on the handle and open them all they way up (where they will loock open) to make them freewheel. Then pull up on the same trigger to fold them back up and start the tightening process. If they are stiff, oil them.
http://www.overtons.com/modperl/prod...FZm6wAodCwENyQ
Get these. Or something of this style- these are probably the same ones from an above post. Rear tie downs are designed to keep the boat down on the trailer from moving- not so much from falling off- so you don't need to have them so tight they can't be removed. That's where your safety chain comes in. This style is what you need. |
Thanks for everyone's response, much appreciated !
#8 | |
#9 | |
I went to Parafunalia in Gilford and bought the same type straps, and very pleased with how easy these work, like night & day from ratchet type ! |
