Oil vs. Propane Heat for heating house.
I plan to move out of my townhouse condo and purchasing a residential home in the Lakes Region..... (keeping Townhouse for income). I would like to know the benefits and disadvantages between the two. Costs ? Maintenance ? Efficiency ? Thanks, Bigdog |
Below is current price comparison between heating fuels in NH
http://www.nh.gov/oep/energy/energy-...ices/index.htm If you can get natural gas, by all means use it! I have a condo heated with natural gas with the latest condensing boiler technology. I also replace my 60 gallon gas water heater with on demand. I save 30% on heating fuel from conventional to condensing technology, 70% from tank to on demand! Propane may be twice the price of oil per mmbtu, maintenance is a lot less and if you have an electric hot water heater, the conversion to gas on demand will save you a lot of money. Since the conversion my gas bill never went over $90 a month. Before my bill average $130 during the winter months. The condo was built in 1977 and is about 1200 sg feet. baseboard heated.
There exists on the web, a chart that compares the cost of heating by various fuels using a common unit of heat output. It might be BTU's or Therms (which could be the same thing).
On that chart propane was the second most expensive, only to be beaten by electric resistance heat. I have propane, forced hot air with a/c. My house has 2x6 walls and is well insulated having been built to 2010 codes. Coming from an electric heat house, I find it really inexpensive to heat and cool. The propane is negotiated en masse with my neighbors resulting in a really low price per gallon. I suspect oil would be cheaper to burn but lately I haven't seen oil used in forced hot air systems. Going with a baseboard system means additional ductwork for a/c. The mini-split systems can get a/c into a house without duct work. I suggest that you find the chart I have referenced. |
The chart posted above is similar to the one I referenced in my post.
It is interesting to note that the propane price used for their analysis was $3.40/gal This year I paid $1.48/gal I suspect that nobody within earshot paid more than $2.50/gal this year. The date of the analysis is March 2017 so it's current. If the oil cost per gallon was $2.42 as stated in the chart AND you bought propane at the price I paid, propane beats oil. |
Paying $.97 for propane through our group so that chart is not accurate
The Following User Says Thank You to SAMIAM For This Useful Post: | ||
Reilly (05-01-2017) |
New Hampshire Climate Audit has a cost compare web page.
http://www.nhclimateaudit.org/calculators.php One can input their own costs and efficiencies to provide an accurate comparison for your situation. My own propane group buy rate of 1.47 and a 90% efficient system yields propane cheaper than the tool's basic oil cost. That would change with a good group buy of oil, of course. |
Oil is cheaper. The past few years it's actually been cheaper than burning wood unless you are cutting and splitting it yourself.
#8 | |
I use propane with Minisplit. Works fantastic. If Natural Gas ever came by, I'd hook up to that in seconds! Also burn wood pellets in the basement, which is great, but not convinced it's cheaper in the long run with cleanings, maintenance etc. Easiest and favorite so far is the propane insert for the fireplace. Would recommend that to anyone! |
One thing you need to consider is the BTU rating of various fuels. #2 oil generates 138,000 BTU's per gallon, propane generates 91,600 BTU's. So all gallons are not equal. You need to consider this in any calculation. efficiencies on oil can range in the 85% range while gas can get into the mid 90's IF you buy a VERY EFFICIENT system. Otherwise, they are in the high 80's/low 90's. You can use the following formula to get the cost per million BTU's for comparison purposes. All costs need to be expressed in cost per million BTU's to make the comparisons equal. For example, 138,000BTU/1,000,000=0.1380..... You need to now plug in the efficiency of the unit and the cost per gallon of the fuel.
Oil (in medium efficiency central heating system) Heat Cost = $2.30 (price per gallon) ÷ [0.1380 × 0.85 (efficiency)] = $19.61 per million Btu. Propane (in medium efficiency central heating system) Heat Cost = $3.14 (price per gallon) ÷ [0.0916 × 0.85 (efficiency)] = $40.33 per million Btu. One other thing you can include as an extra is the cost of maintenance. Oil needs annual cleaning, cost approx. $125 -$150. For gas, not needed. Both types of systems are mechanical so maintenance for mechanical items can be assumed to be equal. Oil requires a chimney or power vent. Gas, if using a modern condensing boiler, can be vented using regular Schedule 40 PVC directly through wall. Hope this helps...... |
The Following User Says Thank You to tummyman For This Useful Post: | ||
bigdog (05-01-2017) |
I can't let this thread slide by without chiming in ...why even consider fossil fuel heating when air source heat pumps (ie, "mini-splits") and solar have made them somewhat obsolete?
Installing or replacing a furnace and the periperal circulation systems is generally more expensive than a whole house air pump with individual handlers. Plus the current super efficient breed of air source heat pumps have the ability to heat, AC, and filter your air. Talk to someone that has one! A matched solar system will provide the power to run a heat pump system and it only takes 5-8 years for the money saved in utility bills and/or fossil fuels to offset the cost of the solar system ...and from that point forward your power and heat will be coming to you virtually for free A solar system is nearly maintenance free and the expected life is generally thought to be fortyish years. Will your new home eventually be a retirement home? Wouldn't it be a wonderful thing if you didn't have to worry about the cost of hvac and electricity during your golden years? |
#11 | |
Propane is cleaner, no odor, can be used for fireplace, hot water, stove, grill, generator, etc. Oil can only be used to heat.
#13 | |
#14 | |
#15 | |
When I had to replace my boiler, I look into the Mistibushi split system for best all around use. The dealer determined because of the energy efficiency of the unit, I may need auxiliary heat source. Bear that in mind.
First off, if we're talking about new construction, building just "to code" is a wasted opportunity. Remember, from an energy and comfort point of view, a house built just to code is the worst house you can legally build. For perhaps 5% extra the house can be in the realm of "superinsulated," and thus easy to heat or cool and very comfortable year round. For such a house, an air-source heat pump makes a great deal of sense, as it will be smaller and the heat introduced in a couple of locations will distribute easily, with no cold spots. For a house like that, of about 3000 sqft living space, the design heat loss ought to be less than 20,000 BTU/hr. Most of the time, the heat pump(s) will be loafing.
ishoot308 (05-02-2017) |
#17 | |
Edited to add: I don't know why but you do lose some cooling efficiency with the hyper heat units over a standard unit. The standard units have unbelievable cooling efficiency. Dan
It's Always Sunny On Welch Island!! ![]() Last edited by ishoot308; 05-02-2017 at 07:22 PM. |
#18 | |
I heard that there are hot water tanks available that will heat your hot water using the same principle. I know of a home owner that ordered one on the internet but could not find someone to install it. He may need to hire a guy from Maine. Is the Mitsi split greener than a condensing boiler? I don't think so. NH electricity is produced mostly from natural gas. Because of loss of transporting the electricity, total efficiency is low.
ishoot308 (05-04-2017) |
#19 |
The debate here is endless.
Do a search to read other posts about oil versus propane. Endless debate. Me, I will never ever ever ever ever ever go with propane again for primary heat. |
