Old 05-28-2015, 08:25 AM   #1
Cal
Cal's Avatar
Best answer yet AC2717!
You may also try removing the outer case and stuffing the excess cord inside without cutting anything. There is usually some room.
The Following User Says Thank You to Cal For This Useful Post:
jetlag100 (05-28-2015)
Old 05-28-2015, 11:23 AM   #2
Hire an electrician to cut a cord and put a new plug on the end? Hmm... this takes about 5 minutes to do, there are a whopping three wires to connect to the new plug end and you'd really have to be a complete moron to screw it up if you can read simple directions (usually included with the new plug end).
https://www.youtube.com/watch?v=9OfdIfX-PwI
The Following 2 Users Say Thank You to MAXUM For This Useful Post:
ishoot308 (05-28-2015), jetlag100 (05-28-2015)
Old 05-28-2015, 04:39 PM   #3
jetlag100
Tried that, buts there's not enough room....
jetlag100 is offline   Reply With Quote
Old 05-31-2015, 08:31 AM   #4
Cal
Cal's Avatar
Oops, I did this with older units a while back. Guess newer ones are more compact
Old 05-31-2015, 12:00 PM   #5
camp guy
camp guy's Avatar
Default Excess AC cord
The plug at the end of the cord on my AC units has a built in circuit breaker, something that probably could not be duplicated by a homeowner.
I think the prevailing wisdom involves consulting with an electrician.
Old 05-31-2015, 12:46 PM   #6
brk-lnt
brk-lnt's Avatar
Are you sure it's not a GFCI?
[insert witty phrase here]
Old 05-31-2015, 07:47 PM   #7
kauriel
We had same issue and got lucky that wrapping the cord around the frame for the AC once made it pretty close to the correct length.
kauriel is offline   Reply With Quote
Old 06-01-2015, 06:33 AM   #8
Stop staring at it and don't worry about it before you know it you'll be raking leaves again.
ITD (06-01-2015)
This page was generated in 0.32970 seconds
