I will be purchasing a used (almost new) wood-burning, "fireplace Insert", and will need installation services.
Can someone recommned a good 'mason', who is familair with this type of installation. Flue damper will have to be removed, and a adapter flue extension installed to top of wood insert. I am told that this is a custom fit for the wood insert being installed, and that every 'insert' is different ? You would think this would be a universal fit for the most common fireplace dimensions? If anyone has had a fireplace insert installed, I'd like to hear about your experiences. Thanks, Bigdog |
I installed my own but never connected it properly liked you are going to. It worked fine I probably should have done it right. I don't use it anymore so I lost interest. Mine is a double wall with a fan and boy does it put some heat. Good luck.
SIKSUKR |
There are two or three generations of the Houston family in the north part of lake. Any one of these guys does an excellent job.
| The Following User Says Thank You to songkrai For This Useful Post: | ||
bigdog (12-30-2011) | ||
I personally have not use Fire & Stone but have heard good things about them.Here is a link, let us know what the cost was if you don't mined.
http://www.firenstone.net/index.html
#5 | |
would be my first choice. Located in Wolfeboro.
