Old 12-09-2009, 11:08 AM   #19
jmen24
My .02...
You didnt say what make/model sled.... call the dealer and see if you need tthe aformentioned tunnel protectors.... no need to hit a big bump and rip out your heat exchangers! OUCH!!
1. 1/4" longer than the track height is perfect.
2. Go buy the template and the drill tool.... it makes life ALOT easier!
3. Get the aluminum backing plates... the steel ones are very heavy.
4. Disconnect your drive belt, and tip your sled on its side so you have easy access to the track. If you have access to an impact wrench it will make tightening the studs quicker and easier.
Woodsy
Just one more to add to the list.
4a. Clamp to fuel line and vent tube to prevent a big clean-up when you are done.
This page was generated in 0.15977 seconds
