Old 12-01-2009, 09:47 AM   #12
Bear Islander
Bear Islander's Avatar
[QUOTE=WINNOCTURN;113292]
Now that it is almost time for the ice to start coming in, I thought I would start an ice safety thread.
We in Moultonboro have lock on 2 of the Best spots for Skimming.
We start at Greens Basin. Heading down out of the Basin the first Skimming spot is between Greens Basin, Goodwin Island and Hanson Cove. Most years the area is always open.
Probably the most notorious open water area is just down from the Basin at Marker 52 between Bryant's Point and Richardson Shores. Usually there is around 150' of open water. There have been numerous sinking's there with a fatality back in January of 2006 which was recorded by a home owner from his deck with a video camera. This was a deliberate attempt by several riders to skim the open water. Unfortunately this one fellow did not make it.
The other problem that happens in both of these areas is riders late at night following tracks in the snow, they realizing too late that they are now facing open water.
There was an incident several years ago at Bryant's Point where a group of three or four riders went into the water. All were able to get out safely, make a call to the police and rescue services. Paramedics check them and all went home.
An hour later another group of riders followed the same set of tracks and met the same fate. Fortunately they were also rescued.
We used to have a map of all the "HOT SPOTS" around the Lake where in most winters would never ice over. With all of the litigation today were are forced to discontinue distributing the maps and to make a broad general statement that basically says you are on your own when riding on ice covered bodies of water.
Your post is talking about the "Best spots for Skimming" and Moultonboro having the "Best" two.
If your intent was to condemn skimming, then you chose your words poorly.
The Following User Says Thank You to Bear Islander For This Useful Post:
WINNOCTURN (12-01-2009)
This page was generated in 0.95634 seconds
