Old 06-20-2018, 07:29 PM   #1
radiocontester
radiocontester's Avatar
Default Stop itching!
Folks,
I thought I'd pass along a home remedy for itchy bug bites that I have had great success with.
A few years ago my wife and I traveled to Punta Cana for vacation and upon our return home we started itching like crazy from what seemed like hundreds of bites from no-see-ums. We tried several over-the-counter creams, ointments etc but they provided little relief. Out of options I started researching home remedies online and came across an interesting one involving a hair dryer. The remedy is to use the hair dryer to heat up the itchy bite to the point in which it starts to hurt (don't burn yourself!). Stop applying heat when it gets to the point where it begins to hurt. Note: While heating up the bite it may feel even itchier for a second, but as it continues to receive the heat the itchiness is replaced by a burning feel. Again, be careful not to burn yourself. After the heat is removed you will have instant relief that lasts for hours. I'm not kidding. Just the other day I had a bite that was so itchy I could barely sleep. I treated the itch using the hair dryer and it hasn't itched since.
Give it a try!
radiocontester is offline   Reply With Quote
The Following 3 Users Say Thank You to radiocontester For This Useful Post:
andy3519 (06-21-2018), Flylady (06-21-2018), KennyFromBoston (06-21-2018)
Old 06-20-2018, 08:48 PM   #2
MeredithMan
MeredithMan's Avatar
Default call me old fashioned, but--
...I prefer scratch it till it just about bleeds and then douse it with either After-Bite, Hydrogen Peroxide, or Rubbing Alcohol. Stings momentarily like a Mother
F_____, but it's a good pain.... My daughter the newly crowned RN gives me heck, but the itch goes away!
Old 06-21-2018, 07:14 AM   #3
Originally Posted by radiocontester View Post
Folks,
Give it a try!
I too have heard about using heat but actually it was hot water which also works very well!
Thanks for the tip!
Old 06-21-2018, 08:34 AM   #4
Dad sold the C * C
I use the hot water method for poison ivy. slowly increase the water temp on the affected area; it can hurt, but it's "good pain" the itching stops for a while. just make sure to blot it with paper towels as it will weep.
The Following User Says Thank You to Dad sold the C * C For This Useful Post:
VitaBene (06-22-2018)
Old 06-21-2018, 01:56 PM   #5
noreast
Yup, I go as hot as my skin can take without bubbling and hold the shower head in hand and put it all over the poison Ivy, The feeling is spectacular!
The Following User Says Thank You to noreast For This Useful Post:
Old 06-24-2018, 11:47 AM   #6
Tallyho
Tallyho's Avatar
Default itching
I've been using Witch Hazel since I was a little guy, and it's always worked well for me.
Tallyho is offline   Reply With Quote
Old 06-27-2018, 12:19 PM   #7
The hottest water you can stand is by far the best relief I've ever found for poison ivy.It lasts for quite a while.I would assume this would also apply for bug bite itching.
Old 07-01-2018, 06:49 AM   #8
Sinclair
We've recently started applying After-Bite to the kids (sans the scratching/bleeding) and it's been very successful.
Sinclair is offline   Reply With Quote
Old 07-01-2018, 07:12 AM   #9
After bite works great! I think it’s mostly ammonia but it does work excellent!
This page was generated in 0.25602 seconds
