Old 07-13-2014, 04:48 PM   #1
NickNH
Default Caloric Gas Oven problem
Sorry if there's already a thread on this subject. We have a Caloric Gas range and the oven has stopped working. The stovetop works fine so my husband thinks the electric thing that tells the oven to light needs to be replaced. Who should we call for this? We're in Moultonborough. A bit on the desperate side as this just happened and we have a big family reunion coming up in a week.
Thanks for any recommendations!
NickNH is offline   Reply With Quote
Old 07-13-2014, 06:01 PM   #2
Well, you can always call for service from some place like Crown Appliance in Center Harbor (http://www.crownappliance.net/).
If it were me, I'd first suspect the igniter. A quick search on "replace caloric gas range igniter" turns up a lot of links, including this one from Sears: http://www.sears.com/caloric-gas-ran...-SPM6616930903
If you have the documentation that came with the range, it may well have a diagram of the internals, with a parts list. You may be able to figure out how to get at the igniter to inspect it for a crack that would indicate failure. Hopefully someone will post here how to locate the igniter. You probably could find out that info online. This sort of thing happens all the time all over the place, and replacement of a failed igniter easily falls into the DIY category. This link is the sort of thing you'll find easily: http://www.applianceaid.com/gas-igniter-replacement.php
Look at several such explanations, perhaps even a video to see if it's the sort of thing you want to tackle. Of course, if the igniter seems intact, with no visible crack indicating failure, the problem could be in the sensor that detects a hot igniter; that detection has to occur to signal the gas valve that it's ok to open. But even that part would be available online.
Old 07-13-2014, 06:03 PM   #3
TheProfessor
Prompt and courteous service gas appliances and all appliances.
S V APPLIANCE REPAIR
70 Durgin rd
CENTER TUFTONBORO, NH 03816
service 603-724-0545
svarepair@svarepair.com
I have no connection with this company or people other then they repaired my gas oven.
Old 07-15-2014, 05:15 PM   #4
NickNH
Thanks to you both...Crown Appliance is coming to fix the oven this week...
Old 07-15-2014, 06:51 PM   #5
Nick, post a final entry after the fix to let us know what it was, to satisfy the curious.
This page was generated in 1.19766 seconds
