Old 09-09-2009, 09:59 PM   #1
NHskier
Default Remember to pay attention ...
... during that boating safety course
Name:  IMG_1399 adj1-2.JPG
Caught this one while out this evening passing between Eagle & Governor's Islands.
NHskier
Old 09-10-2009, 09:31 AM   #2
Mee-n-Mac
Mee-n-Mac's Avatar
Wink Seagull tipped bouy means what ?
Now when I see a buoy with a vulture sitting on it .... then I really pay attention !
Mee'n'Mac
Old 09-10-2009, 10:09 AM   #3
Its good to know that the markers not only have a primary purpose, but also serve a secondary purpose as a perch for wildlife...... They are even more valuable then we realize.....
Old 09-10-2009, 11:48 AM   #4
chipj29
chipj29's Avatar
With that bird sitting there, that red-tipped marker will soon become a white/green-tipped marker. Then what?
Getting ready for winter!
Old 09-10-2009, 12:04 PM   #5
caloway
Default clearly
Obviously that's a marker that you go south or west of depending on the location of it's companion black spar.
caloway is offline   Reply With Quote
Old 09-10-2009, 03:35 PM   #6
boat_guy64
boat_guy64's Avatar
Default why aren't the markers different
I've always wondered why the red or black markers aren't shaped differently so that you can tell the difference. This marker in particular is very difficult to see the color on a late afternoon with all of the sun glare as you are heading into Meredith. I've done it a thousand times and although I know the markers and know where to go, it is really difficult if you are new to the are because you can't see the color in the bright sunlite. They really need to add a triangle to the top of the red (or black) markers so that there really is a difference.
boat_guy64 is offline   Reply With Quote
Old 09-10-2009, 04:26 PM   #7
Jonas Pilot
Default Direction to go?
Doesn't it depend on which way the bird is facing?
Jonas Pilot is offline   Reply With Quote
Old 09-10-2009, 04:40 PM   #8
brk-lnt
brk-lnt's Avatar
Well, why did NH invent its own marker system instead of following the red/green nun/can buoy used used by the USCG?
[insert witty phrase here]
Old 09-10-2009, 08:58 PM   #9
Hey, here's a piece of usefull info if you ever find yourself out in the water somewhere without a pfd. The spar markers have enough buoyancy to support a swimmer. Just position the spar marker, which is a 4" diameter x 10' pvc pipe full of floatation foam, between your legs and sit on it horizntally sort of like a bicycle. It should keep your head and shoulders above the water. It requires a bit of a balancing act, so it gives you something to do while waiting to be rescued.
Good to know for the next time you fall off a boat late at night or something and get too tired to tread water. Probably does not work with the flashers....but does work with the black/red & white spars.
Old 09-11-2009, 07:13 PM   #10
NHskier
Dare we ask ... How is it you know this?
NHskier
Old 09-11-2009, 07:38 PM   #11
KTO
KTO's Avatar
Isn't it illegal to hang on markers? I mean I can understand if someone needed to be rescued...but that bird has no reason to be there!
KTO is offline   Reply With Quote
Old 09-11-2009, 07:46 PM   #12
Wink You're New, Here...
The short answer is "blang".
The long answer is this interesting thread:
http://www.winnipesaukee.com/forums/...ead.php?t=1096
This page was generated in 0.23997 seconds
