05-16-2012, 09:33 AM | #1 |
Boat Whips vs Boat Lift
Hi...Not sure if general discussion is place I should post this...newbie to this site and to lakehouse ownership. We purchased a home in Meredith Bay and have a 26' Chapparell boat. We are quickly realizing the water is very rough there on weekends with boat traffic! We have had whips installed that should handle 10,000 pounds (our boat weighs 5200 lbs). Two weekends ago one of the ropes on the whip broke. Last weekend the whip itself actually snapped in two. Our dock is the aluminum kind that is raised in winter and lowered in summer. Is an expensive boat lift in our near future or is there another option? I understand it takes four weeks for a mooring permit to be processed (if it is approved). Is that our best option? Suggestions welcome! J
05-16-2012, 10:20 AM | #2 |
Mooring applications go pretty quick, you'd be surprised. Getting it off the dock would be the best solution. I have never been a fan of whips. If you have over 150 feet of frontage you could install a second dock finger and 4 way tie between the two.
A boat lift would be great, but it will cost you to purchase, plus annual install/remove charges (probably $400 each time they touch it). Depth is important with a lift such as a Sunstream. Typically you need 3-4' of water at the helm of the boat when parked at seasonal low water level for a cantilever lift to work. A Sunlift will probably run $8-10k easily. Sometimes used ones are available. |
The Following User Says Thank You to codeman671 For This Useful Post: | ||
diprna (05-17-2012) |
05-16-2012, 12:21 PM | #3 |
Meredith Bay
I also live on Meredith Bay. It gets very rough on Saturdays and the mail boats throw the biggest wake on the lake. I have both a dock and mooring. The boats takes a lot less of a beating on the mooring. (I use double lines) On the dock, I have six 1/2 inch lines with rubber snubbers. I usually break 2 lines each year. A lift seems like it would be the best overall solution although expensive.
The Following User Says Thank You to boat_guy64 For This Useful Post: | ||
05-16-2012, 12:54 PM | #4 |
Hard to imagine you actually broke the whip. I suspect you had too much pressure on the pole. Our dock takes a beating in n/w blow and boats are parked broadside too the wind. I never seen a whip break. My boat is also 5200lbs and my whips are 13 years old. I would love a lift but they cost good money, require a permit and are supposed to come out every winter.
05-16-2012, 01:09 PM | #5 |
diprna, I just noticed that you are fairly new to the forum and glad you have joined us. Have fun and enjoy the Winni Forum while making many new friends. I’m sure you will get the correct scoop on this site along with many good suggestions. Best of luck with your endeavors.
The Following User Says Thank You to RLW For This Useful Post: | ||
05-17-2012, 01:31 PM | #6 |
Is your boat 5200lbs dry, or with full fuel? There is a Sunlift in the classifieds today that is a 6000lb lift. If 5200lbs is a wet weight the lift would work, if without fuel you would need a heavier lift capacity.
diprna (05-20-2012) |
05-17-2012, 01:36 PM | #7 |
Boat Lift
I think I saw a used one bundled up for sale off White Oaks Road in Laconia. You may want to check it out.
05-17-2012, 04:04 PM | #8 |
As someone already said here I find it hard to believe that you broke a whip if everything was done correctly. I know people that use whips and have for years with very little problem, and in some very busy parts of the lake.
3 of which live have places with short front on the broads. During last years hurricane my whips did an excellent job with my boat. When I see whips break it is generally because along with bending they are twisting. Which means the boat is being allowed to move along the dock to far. All that said, a lift is the safest. However as mentioned you will not only have the cost of the lift, but it must be put in and out every year. A mooring is the next best option, there will be some up front cost but yearly maintenance isn't that bad. Make sure you put in a mooring that will accommodate your future boat ambitions. Whips are going to be the cheapest route. You might also want to incorporate some snubers in the set up as well. As always ask for help, plenty is always given on the forum...
05-17-2012, 04:22 PM | #9 |
Use a kedge.
A way to deal with this is to use a kedgeing anchor.
A kedge is an anchor (either a regular anchor or a mooring block) attached to the outboard side of the boat. Our set up... About 15 feet outboard of our boats we plant a mooring block. Attached to the block is about 6 feet of heavy chain. Attached to the chain is enough nylon (1/2 inch is good) line to reach a conveniant place on your dock. You tie up the boat to the dock in the regular way only a bit looser. You then take the kedging line and secure it to your outboard, midships cleat. With the loose dock lines the kedging line will pull the boat away from the dock. Adjust your docking lines so that the boat is about a foot from the rubbing posts. The weight of the chain running along the bottom will lift and drop as the boat moves up and down and will act as a shock absorber. It is cheap and easy on the boat and no permit required. Good luck! Misty Blue. |
The Following 4 Users Say Thank You to Misty Blue For This Useful Post: | ||
05-17-2012, 06:59 PM | #10 |
We have used the same pair of over sized whips on the broads for 10 years. We have always used the collapsing triangle method as shown here. The triangle prevents the twisting force.
05-17-2012, 07:34 PM | #11 |
Do you use bumpers too?
05-18-2012, 07:38 AM | #13 |
I've had great luck with mooring whips....secret is...go oversize for your boat or make sure they are heavy duty and they should handle most anything. Misty Blue has a good idea too. If you place a well anchored mooring ball for the bow, you can tie the stern to your dock and still have easy access to your boat. Not too difficult, just takes a little experimenting.
Boat lifts are fine in salt water since you need to wash your boat and flush your engine after use but for fresh water, that's a lot of money to spend when there are lots of cheaper options. Good luck. |
05-18-2012, 08:45 AM | #14 |
Whips
Done it both ways--I have had oversize whips for about 15 years and have had good luck. My shore station sits on Rattlesnake looking for a new home. Sorry it's only rated for 3600# It really became a pain to take out and put in!
05-18-2012, 10:47 AM | #15 |
i would suggest contacting the folks at Mooring Products International. they are the inventors of the mooring whips and their whips are top notch. i would never trust my boat to anything other than these whips...period...end of story. they are out of florida...call them up and don't be suprised if you speak with the owner/president.
05-18-2012, 09:05 PM | #16 |
RG has become an expert at tying lines to the dock post in a way that the lines do not wear from rubbing. Probably common to many on here but she wraps it so the line exist from between two other wraps and can't rub on the wood.
05-20-2012, 06:56 AM | #17 | |
My rig was set up with chain to the anchor and a loop of line toward the boat. This made it easier to snag if laid on the bottom, or accidentally dropped. Good luck! |
05-21-2012, 08:26 PM | #18 |
Thank you!
Thank you all so much for taking the time to respond. My husband and I have learned so much already! We are feeling more confident giving the whips another shot (this time increasing to 20000 lb wt). Yesterday we bought and installed snubbers. Hopefully the new whips will do the trick. Maybe someday we will end up with a lift but we really would prefer not......the hassle of taking in and out and even storage (we have no flat land!) would be nice to avoid. Lastly, the water is too shallow at our dock so in order to use a lift, we would need to extend the dock....real snowball effect which hits the checkbook hard. Thanks again for all the great advice and comments. Joyce
05-21-2012, 08:28 PM | #19 |
Ps....
We are planning to apply for the mooring permit. It would be nice to have the option on the really rough days.
05-22-2012, 06:24 AM | #20 |
Where to Purchase Whips?
My wife and I want to purchase whips (sounds funny, right). Where to buy here at the lake?
05-22-2012, 08:01 AM | #21 |
Wicked Wanda's Winnipesaukee Whips Wolfeboro.
05-22-2012, 02:36 PM | #22 | |
I personally use Center Harbor dock and Pier.... you can also find them online at Overtons and Last take a peak on craigs list... I fond Whips for my jetski there, for cheap money.
05-22-2012, 02:52 PM | #23 |
boat whips ...
Considering that fact that you are going to use these whip to secure a major asset in your life, don't buy used, and don't skimp on quality. I would suggest buying from a reputable, local dealer, and making sure that they are installed exactly according to directions, right down to the last nut! If you should experience problems, by buying locally and installing them correctly, you will have the best chance for a satisfactory resolution to your problems.
I bought whips locally, installed them according to the directions, and they worked well while I still had my boat. |
05-22-2012, 06:28 PM | #24 |
Amen on the careful installation. Bear in mind that the downward pull by the boat at the end of the whip as it pitches in waves produces a tremendous torque at the point of attachment to the dock. You ought to check how the deck is attached to the frame, particularly on the opposite side of the dock from where the whip base is affixed, which must resist the torque of the whip. You may need some reinforcement at both sides of the dock. Even the side where the whip is affixed will see a fair amount of sideways torque, which happens when the attachment of the line to the boat is not straight out from where the whip base is on the dock, but toward the inner or outer end of the dock.
