08-24-2016, 04:42 PM | #1 |
How much punishment can an outboard take?
At the east side of Ragged Island today and slightly tapped a rock with the bullet part of the outboard (in front of the prop) at floating speed, i.e. barely moving, but it got me thinking: how much banging around can am outboard motor take?
08-24-2016, 09:50 PM | #2 |
Well...it depends
I have never broken a gear case on any of my stern drive boats. I have taken a chunk out of a skeg and damaged about six props. I do not know how much of a tilt the out drive will do if hit hard. It seems that the large mass of the lower unit hitting a rock at speed could destroy it. My little 4 and 5hp Mercury outboards definately take a lickin' and keep on tickin'! The bullet end of the gear cases on those look like the surface of the moon. I've run them so shallow on gravel and stone that "roto-tiller" comes to mind. So...are you feeling lucky??? |
08-25-2016, 05:52 AM | #3 |
They can take quite a bit of abuse. There's a range of impact that will make them overwhelm the mechanism that keep the engine from tilting up in reverse, by design, but not break. Despite that, you can still break them if you are going fast enough.
If you hit something at low speed with the nose cone, and the entire engine did not pop up, you are fine. |
08-25-2016, 07:43 AM | #4 |
I bumped the bullet of my Yamaha 350 this year against a rock going headway speed. Gouged and scratched it and also dented the bottom of my center toon. Called my insurance company (Progressive) as I wanted to file a claim just in case something happens down the road. The rep came to the Glendale docks took one look at it and said everything gets replaced! An entire new lower unit including gears on the 350 and a new center toon. I asked why they were replacing everything and he stated they don't take chances as the dent was near a baffle weld in the pontoon and the weld could be compromised internally. The bullet because the aluminum was gouged gets replaced and its cheaper to purchase a whole new lower unit than to pay labor to switch internal gears from one case to another....Estimate for repair was $14,000.00! Had check two days after rep looked at it. Having the work done over the winter...
08-25-2016, 08:02 AM | #5 | |
08-25-2016, 08:27 AM | #6 |
08-25-2016, 08:34 AM | #7 |
Inertia!
In simple terms.... it depends on what you are driving.
It is all about the inertia of the object.... a 400lb rowboat has exponentially less inertia at 3MPH than say a 3500lb small runabout does. So when the outboard torpedo strikes a rock, the force transmitted in the strike varies due to the mass of the object the outboard is powering. Woodsy
08-25-2016, 08:42 AM | #8 |
Look close
Do a close visual inspection after a hit. I recall going on a service call because the engine "didn't shift properly". Prop looked OK and they had driven the boat home and everything operated OK. When I looked at it, there was a crack in the lower unit, and all the gear case lube had leaked out.
08-25-2016, 11:30 AM | #9 | |
PS The frustrating part is that had I jumped off the front and pushed back immediately instead of going back to look over, I'm not even sure I would've got the chip as I think it was my weight in the back. Grrr... Sent from my XT1528 using Tapatalk |
08-25-2016, 12:31 PM | #10 |
I have to confess that I touch the bottom more often than I probably should with my boat's lower gear case/skeg/props. I like to "gunkhole" and it comes with the territory. Always at low speed and with no meaningful damage The only time I did any damage hitting the bottom with my current boat was backing off my trailer and backed directly into a rock. That hit broke my gimbal ring and was an an insurance claim.
08-25-2016, 02:52 PM | #11 | |
Something to think about... |
08-25-2016, 03:12 PM | #12 | |
08-25-2016, 05:43 PM | #13 |
I got one on my stern drive, was there when I bought my boat (used). Looking at it seems as though if that does get hit hard enough it'll more than likely break the entire skeg off since it has far less give to it than plain aluminum.
I do think for minor low speed incidental contact it'll provide good protection and they do look pretty cool. Not sure I'd throw down a c-note for one but I've also never kissed the bottom either. I'm sure my day will come it happens to everyone sooner or later. |
08-27-2016, 07:05 PM | #14 |
Here's a pic--chip looks so perfect, it looks factory! What would y'all do with this? Let it be, get it fixed?
08-27-2016, 09:42 PM | #15 |
Well...
I wouldn't fix that, your spedometer will stop working! If I am looking in the right place, that perfect notch in the leading edge of your outdrive is where water pressurizes the tube leading to the speedometer. |
08-28-2016, 06:12 AM | #16 | |
08-28-2016, 06:43 AM | #17 |
Have you run it wide open after the ding? I would think you're fine, As long as there's no vibration at speed. If you're worried though, lower unit is easy (or cheap) to take apart. There pretty tough as I learned when I back up my driveway with the motor down. Dug right into the tar, scraped up and slightly bent the skeg. No more 42mph, will only hit 39 now.
08-28-2016, 07:54 AM | #18 |
Yes, I am referring to the notch pointed to by the arrow.
Here is a picture that should relieve your worries: |
08-28-2016, 07:58 AM | #19 |
Here's a photo of the speedo pitot:
08-28-2016, 08:03 AM | #20 |
Ha! That's great news! I was wondering how I would've done that. The only thing, then, is a light scratch on the bottom of the skeg, which shouldn't be an issue. Thanks!
08-28-2016, 08:13 AM | #21 |
Ya but,
The rock's attorney called... |
thinkxingu (08-28-2016) |
08-28-2016, 08:41 AM | #22 |
Bullet Damage
Here's the gouges on my 350 bullet that they are repacing completely....
08-28-2016, 08:43 AM | #23 |
Toon Damage
Here's the center toon damage. That is being replaced as well.....
08-28-2016, 09:19 AM | #24 |
08-28-2016, 09:21 AM | #25 |
^^ Ouch, Is that the elliptical? What do you think of the performance compared to the (was it) Premier? sorry about the hijack question.
08-28-2016, 09:30 AM | #26 | |
Braun Bay
08-28-2016, 09:35 AM | #27 |
08-28-2016, 09:36 AM | #28 | |
noreast (08-28-2016) |
08-28-2016, 09:38 AM | #29 | |
08-28-2016, 09:54 AM | #30 | |
