Old 06-24-2011, 07:44 AM   #1
challmec
Default Ragged Island marker
Good Morning
I have a question concerning the marker on the South side of Ragged Island. It is a red/white marker which indicated an obstruction in the area. Now when approaching it from the South shouldn't it be passed on the left ? It would seem so but I idled past it one day recently and observed a large boulder under the surface which when the Lake is lower may cause interference.
That being said the right side of the marker is clear and is the correct way into the dock area.
So shouldn't that marker be painted white /black?? What I am getting at is with the current configuration an approaching boat coming from the South should pass to the left (West) of the marker. This may cause contact with that boulder !!
Am I off here ? Can someone clarify for me?
Thanks in advance
challmec is offline   Reply With Quote
Old 06-24-2011, 08:33 AM   #2
Senter Cove Guy
Senter Cove Guy's Avatar
Default B&W Not Appropriate
You don't want boat traffic between the marker and the island, so a B&W is not appropriate. Perhaps the R&W was moved over the winter and should be relocated so the rock is on the east side.
The Following User Says Thank You to Senter Cove Guy For This Useful Post:
challmec (06-24-2011)
Old 06-24-2011, 10:22 PM   #3
jrc
Looking at my Bizer chart, the rock should be just north and west of the R/W marker. On a East/West course you should travel south of marker.
But as you note traveling North/South, if you follow the rules, you would travel west and then you hit the rock or the island.
This is another one of those limitations of the current marker system. That's why you always need the chart. This position needs a south/east marker, we don't have one. So they place the most helpful marker we have. Most people will know not to travel between the marker and shore.
challmec (06-25-2011)
Old 06-25-2011, 08:45 AM   #4
Rattlesnake Guy
Rattlesnake Guy's Avatar
Just looked at the Duncan Green map and it shows staying away from the island to the south side.
Ben = Black East North
so Red = South West
But we all know it's not an exact process. I always thought the markers that required counter intuitive behavior should have an extra designation so you knew to pay extra attention. Like when you are supposed to go on the land side of a marker. Or go outside of a pair and not between etc.
There is a black marker south of Treasure that confuses the heck out of me. I just stay away from it.
The Following User Says Thank You to Rattlesnake Guy For This Useful Post:
Old 06-27-2011, 06:51 AM   #5
Bizer
Bizer's Avatar
According to my notes, there is a rock about 5m (16 ft) north-northwest of the buoy. The rock is about two feet below the surface (at fall lake level) which would put it about three feet below the surface today.
One problem with this rock/buoy is that it lies in one of the "Zones of Ambiguity" (as Bizer calls them). In this case, boaters should stay southeast of this buoy. The ambiguity is: Should the buoy be red (so that one passes to the south) or black (so that one passes to the east). The other ambiguity zone arises when one is to pass northwest of a buoy. So, if the buoy is southeast of the hazard (as in this case) or northwest of the hazard, look at the chart.
There are other buoys that lie in a Zone of Ambiguity, like the buoy southeast of Treasure Island (as RG pointed out). In most cases, it is intuitively obvious on which side to pass (e.g. Ayers Point, FL#25). A good rule-of-thumb: If there is a lone buoy, the hazard usually lies between the buoy and the nearest shore.
The Following User Says Thank You to Bizer For This Useful Post:
Sue Doe-Nym (06-27-2011)
Old 06-27-2011, 08:45 AM   #6
granny
Default Ragged Island solved…
When going south and west around Ragged Island, go out in the deep water. OR, if you are going to land or find some other reason to be in the shoal area , go at NO WAKE speed (6 miles an hour) and keep one eye on the water. There could be rocks, as in most shoals.
Go at NO WAKE speed whenever you are in a shoal area.
When you're not sure what a buoy means, try the Duncan Press chart. Chances are very good that the routes around the buoys WILL be accurate.
granny is offline   Reply With Quote
Old 06-27-2011, 12:56 PM   #7
That was one area I messed up with the markers. I stopped and used my chart and realized I went the wrong side. I was on my PWC so I didn't hit anything with that low draft. I watched a longtime Governors Isl resident friend go full speed on the Ragged side of the markers and never hit a thing. Lucky boy!
Old 06-27-2011, 02:37 PM   #8
jrc
There was talk a few years back about NH changing away from the current spar system to the more widespread US system.
That system has a simple black and white vertical striped marker that could be used a lot of places:
Inland Waters Obstruction Marker
These are white with black vertical stripes and indicate an obstruction to navigation. You should not pass between these buoys and the nearest shore
There are places where the safe course is between the shore and the marker so this is not a perfect replacement.
Old 06-27-2011, 09:36 PM   #9
challmec
Thanks to everyone who has posted on this subject.. I guess the bottom line is to read the charts and not rely on the markers most of the time...
Very interesting stuff to think about
Thanks again and safe boating to all!!
Old 06-28-2011, 08:24 AM   #10
granny
Default Which chart?
This is one of the many cases where the Duncan Press chart is preferable to the Bizer map. Compare the two... (The one at the left is Duncan Press.)
Old 06-28-2011, 10:03 AM   #11
Huh?They both look the same to me.
I take that back.Bizer has much more detail on rock locations.Thanks for pointing that out.
Old 06-28-2011, 01:05 PM   #12
Sue Doe-Nym
Actually, I think the Bizer chart is clearer. It shows the rock to be avoided whereas as the Duncan chart does not. Also, Granny, I think it has been a few years since the SLA/Science Center has owned Ragged Island. Shouldn't the LRCT be shown as the current owner?
Old 06-28-2011, 08:12 PM   #13
Rattlesnake Guy
Bizer,
Does the direction of the marker have any meaning on your chart? (Pointing left or up etc.) It seems like it could, but it has not clicked for me.
Old 06-29-2011, 07:05 AM   #14
Baja Guy
Someone already said it but this bears repeating. Markers are great and can be used. But when going somewhere you are not familiar, you really must use your chart and proceed with caution.
I use markers where I remember the lake and charts in the shallows & less familiar spots. It's one more fun thing to me. Just yesterday we came through between Timber, Mark, Mink & Round Island, I could not remember the last time I went through, so the stick got pulled back & the chart got pulled out...very idyllic and quiet there on a sunny Tuesday in June.
And as said there are places where the system isn't perfect. Generally it's where the system would transition from a red to a black.
And as was said, markers can be dragged by the ice, I would think rocks can too.
1989 Baja Sunsport 196, Mercruiser 5.7, For Sale
1987 Formula 223 LS with 1997 350 Mag
Baja Guy is offline   Reply With Quote
Old 06-29-2011, 08:09 PM   #15
challmec
Thanks to all who have responded to my original post. I have learned some valuable info through all of the responses and I now pull out my chart when in doubt, This forum is a valuable tool and thanks to all once again
Safe boating out there
Old 07-03-2011, 07:14 PM   #16
Bizer
Bizer's Avatar
Originally Posted by Rattlesnake Guy View Post
Bizer,
Usually, but now always, the buoy diamond points away from the boating route. Do not rely on this because many buoys are rotated due to congestion or to reveal a nearby rock. Rather, use the color of the water on the chart for reference. White = more-than-six-feet-deep-so-it's-safe-to-boat-here. Blue = something-in-this-vicinity-is-less-than-six-feet-deep-so-be-cautious. Bizer offers a cash reward for anyone finding a place less than six feet deep that is not marked in blue. Because of Bizer's obsession to accuracy, we were happy to pay out $560 because it made our chart better.
... When you're not sure what a buoy means, try the Duncan Press chart. Chances are very good that the routes around the buoys WILL be accurate.
Using a word in all-caps for emphasis, Granny aims to create the impression that something specific and meaningful has been said, when, in fact, her claim is vague and ambiguous. What are "very good" chances? 80%?
Challenge accepted. To make it easier for anyone to compare, I have taken Bizer's chart and
  • rotated the chart 45 degrees so that it is at the same orientation as the pictured Duncan map.
  • made the scale the same on both maps.
  • added a dashed orange line (on the Bizer chart) that shows exactly where Duncan Press depicts the safe boating route.
  • added an orange dot (with black center) at the location where Duncan incorrectly depicts the black-and-white buoy at light #41.
Proceeding northward, Granny's safe boating route passes over a field of rocks about 80 yards south-southwest of light #41. Then, Granny's route pass directly over the true location of light #41 (and the rock next to it). In addition, Granny misplaced light #41 by about 205 feet.
The Following 3 Users Say Thank You to Bizer For This Useful Post:
challmec (07-04-2011), Lakegeezer (07-04-2011), SIKSUKR (07-07-2011)
Old 07-04-2011, 08:18 AM   #17
challmec
Bizer hands down looks alot more accurate .
Thanks much
This page was generated in 0.23397 seconds
