11-27-2016, 05:07 PM | #1 |
Furnace leak ?
Went to down to cellar and noticed a small puddle around furnace. Enough water to wipe-up with a sponge, maybe a 1/2 -3/4 cup water. Doesn't seem to be coming from any pipes but under furnace ?
Just had serviced 2 months ago and all was good. Furnace has never leaked before but it is 19 yrs old the fuse has been set! Typical Beckette/Burnham setup. Contractor grade when house was built 19 yrs ago. Thoughts??? Hoping this is not serious, but if the boiler is cracked, could be a replacement and with Christmas a month away not the greatest time, at least this didn't happen in the middle of Jan or Feb. Just as a side note, I'm in process of selling house this Spring, and pushed this out from last summer. Note to self, never hesitate a decision, it may come around to bite you ! |
11-27-2016, 05:22 PM | #2 | |
11-27-2016, 06:33 PM | #3 |
Sounds like a boiler and not a furnace.
If it continues then time for a service call. |
11-27-2016, 06:37 PM | #4 |
Water Leak
Had our home hot air furnace serviced this fall. After the service call, a leak was discovered. The service man came back to secure a hose connection that was loosened during the previous visit. No charge, of course, for the return visit.
11-28-2016, 05:25 AM | #5 | |
11-28-2016, 08:31 AM | #6 |
Your right, I messed it up. It's a pressure relief valve, I was confusing the btu rating of the boiler valve with T and P valve, which would have too high a pressure value for most boilers. Sorry.
11-28-2016, 03:01 PM | #7 |
I had the same issue with my boiler of similar age. Spent $800 on repairs and had other problems soon after. I threw away $800, should have just replaced it to begin with. My new boiler is so much more efficient also. And since it's a second home the peace of mind of not having problems is priceless. Boilers will last more than 20 years but they aren't nearly as efficient as the newer units.
11-28-2016, 06:58 PM | #8 |
I just replaced a boiler in a house I bought last summer. The boiler was so old it had a Shell Oil service sticker on it. Had the chimney cleaned at the same time and a huge amount of carbon and soot was removed. The installer figured the previous owner had been running diesel in it all winter last year. The new furnace will pay for itself in about 5 years, less if oil spikes high again. If it's leaking, replace it. It's not worth the hassle of multiple repairs.
11-28-2016, 09:07 PM | #9 |
Furnace leak ?
Furnace leak was a false alarm.... Whew... Dodged that bullet.
Thought at first, I had a cracked boiler liner. Sort of jumped to a conclusion, without first diagnosing the underlying issue. Where you see water leaking, it's not necessarily that source. The water was leaking from gasket on a Circulating valve, dropping down on the motor, running underneath, the onto the floor. Hence, I thought was coming from the boiler itself, not so ! Had HVAC service tech replace two 'football shaped' gaskets, on valve flanges, and that did the trick. However, after reviewing the entire system it was determined the expansion tank above furnace had no air. This was causing my pipes to gurgle and bubble sounds I've been hearing. Must have had a leak in expansion bladder ? Also had to replace a release valve about expansion tank, and also a faucet valve on back of boiler. Hour and half of labor, plus parts under $200 Case closed for the time being...... |
11-28-2016, 09:27 PM | #10 | |
11-29-2016, 10:52 AM | #11 | |
11-29-2016, 03:17 PM | #12 | |
11-30-2016, 01:01 PM | #13 |
Biggd,
Work was performed at my other house in Mass. ! Bigdog |
11-30-2016, 02:53 PM | #14 |
FWIW, I had a relief valve that kept purging on my Becket boiler. I assumed the automatic water feed was bad because I could watch the pressure on the boiler go past the normal 12-15 lbs. I replaced and had the same issue. I have a tankless coil in the boiler and it turned out that the coil had a hole and the pressure from my domestic water supply (50 lbs) was leaking into the boiler water and raising it. Lesson learned. BTW..easily replaced by myself.
SIKSUKR |
12-03-2016, 08:39 PM | #15 | |
