Old 11-30-2005, 12:45 AM   #1
JK47
JK47's Avatar
Default Suggestion for Picture Organization
Don,
Wanted to know if there is any way to organize the pictures in photophost by resolution? For example, I often search photophost for desktop wallpaper and because my desktop is at a fairly high resolution (1280 x 854), I spend a good amount of time stumbling through to find appropiate resolution sizes. Thanks for the advice/help!
JK47 is offline   Reply With Quote
Old 11-30-2005, 01:21 AM   #2
Mee-n-Mac
Mee-n-Mac's Avatar
Lightbulb An alternate solution
Originally Posted by JK47
{snip} I often search photophost for desktop wallpaper and because my desktop is at a fairly high resolution (1280 x 854), I spend a good amount of time stumbling through to find appropiate resolution sizes. Thanks for the advice/help!
Here's one idea that might help. Instead of trying to find (and be limited to) those pictures which are the *right* resolution, you might try to resize (and crop as needed) those pictures you like. You can use Microsoft Photo Editor (included with Windows XP) to do this although some other picture editors do a better job at resizing (especially up-rezzing). One that's supposed to be good and also easy to use (and is freeware !) is Irfanview.
http://www.irfanview.com/
Mee'n'Mac
Old 11-30-2005, 08:24 AM   #3
webmaster
Moderator
webmaster's Avatar
There is no sort option for that but there is another way to make it easier. Make sure your View mode is on "Gallery". Then sort in descending order by filesize. In the box under each picture the dimensions are shown. Usually the largest file sizes are also the largest resolutions so you'll can easily pick out the resolutions that you want.
Hope that helps.
Don
This page was generated in 0.24284 seconds
