Old 01-30-2010, 07:51 AM   #1
Old Hubbard Rd
Default Refrigerator issues
Hello All,
Happy Fishing Derby Weekend. It's cold up here!! Not much snow but plenty of ice. Need some advice. When we are not using our Winni home during the winter we turn the heat down to 47. I have a very nice neighbor (he's really not that nice but he turns my heat on so..........) that comes over and turns my heat on before we arrive so the house is toasty. I have noticed that the refrigerator and freezer have defrosted and the refrigerator appears to be blowing not so cold air. I realize I need to empty the freezer and throw most things away as they have defrosted. I thought maybe that the refrigerator may be frozen up or something so I turned it off completely and I am allowing the thing to rest and possibly defrost. Any thoughts??
Old Hubbard Rd is offline   Reply With Quote
Old 01-30-2010, 08:12 AM   #2
TomC
TomC's Avatar
Default minimum temp
there is minumum room temperature for a frost-free refrigerator to operate - usually 60 degrees...
read a little about this, here: http://www.aham.org/consumer/ht/a/Ge...tAction/id/844
The Following 2 Users Say Thank You to TomC For This Useful Post:
Old Hubbard Rd (01-30-2010), Sunrise Point (01-30-2010)
Old 01-30-2010, 10:19 AM   #3
hazelnut
hazelnut's Avatar
OHR, I hope that the beer supply was not affected???
Sorry to hear of the Fridge trouble.
Stayed home this weekend due to lack of snow for any riding. Also, it looked like it was gonna be coooolllllllddddddddd brrrrrrrrrrrrrrrrrr.
hazelnut is offline   Reply With Quote
Old 01-30-2010, 10:21 AM   #4
EricP
I hear your neighbor heats up the house and locks you out so you can't go in and warm up when you arrive late in the evening
EricP is offline   Reply With Quote
Old 01-30-2010, 10:34 AM   #5
Default gas refrigerator
hopefully my beer will be OK.
Old 01-30-2010, 05:08 PM   #6
Rattlesnake Guy
Rattlesnake Guy's Avatar
We had this issue with an older fridge.
The research we did suggested placing a light bulb under the unit near the coils. (possibly with a thermostat at 60 degrees.) Safety first!!!
Old 01-31-2010, 08:30 PM   #7
Seriously.........fridge should operate at any room temperature.Sometimes in older models the coils ice up and you did the right thing by turning it off and letting it thaw.Sometimes this is caused by a cracked or older door gasket. After it is totally thawed,plug it in again with the temp settings in the middle.High temp should be in the mid to high 30's......freezer should be close to 0.
If you've tried these things and it still runs warm........better call a priest.
Old 02-01-2010, 07:37 PM   #8
Sunrise Point
Default Religion won't help...
We finally gave up trying to keep food or ice in our freezer during the winter months.
We would arrive on a Friday or Saturday with the outside (and inside) temperature anywhere from 10 - 30 degrees and find the ice cubes in the freezer melted and the beer and water in the refrigerator frozen solid! The refrigerator would start to function after a few hours as the temperature in the house rose.
It would drive my husband crazy. It made no sense to him at all. I showed him Tom C's post explaining the problem but I'm not sure he believes it completely.
Old 02-02-2010, 08:48 AM   #9
Old Hubbard Rd
Default Refrig Repaired!
I did some research on the internet describing my situation with my model refrigerator (6 years old refrig) and according to the web sites it said it could have been dirty coils, bad compressor, or bad relay switch. I had a refrigerator repair person come out and within minutes he determined it was the reply switch and we are up and running. The repair person also said that it had nothing to do with me keeping the temps in the house at 47 degrees. The repair person did ask if I noticed if things in the freezer and been softening and I did tell him that I felt things were softer than I though they should be. He said that was a sign that the relay was going. The relay was attched to the compressor which was accessed from the rear.
The Following User Says Thank You to Old Hubbard Rd For This Useful Post:
Sunrise Point (02-02-2010)
This page was generated in 0.30610 seconds
