Old 07-09-2017, 06:02 PM   #1
NoBozo
Default 20 # Bottle
I have been using my BBQ for decades..currently a Weber Spirit. When the bottle is near empty..it weighs in at 18 pounds..maybe slightly less. When the bottle is getting low I weigh it on my digital bathroom scale. Don't want to get caught empty in the middle of a meal.
All's well. The other day I went to my Propane supplier for the last 30+ years . While charging the bottle..The guy doing the recharge put a screwdriver to a little "blead screw" on the side of the bottle valve. Never noticed this procedure before. I asked him about it and didn't get much of an answer.
When I got home I weighed the "Full" bottle. (Never done that before) It weighed 35.2 pounds. My impression was it should weigh 38+ pounds. 18 pounds for the empty bottle + 20 pounds for the propane.
Is this Normal..? NB
Old 07-10-2017, 08:34 AM   #2
Hillcountry
Hillcountry's Avatar
I believe it's general practice to fill propane tanks (large and small) to about 80% capacity. Not sure if this is for safety or that it's a law but my twin 250 gallon tanks are never filled more than 75-80%.
As for the 20 lb. grill tanks, I always have a full one on hand as a backup in case I run out while grilling...never cared about how much propane was inside...
Old 07-10-2017, 08:38 AM   #3
joey2665
joey2665's Avatar
Default Expansion and Contraction
You are correct the 75-80% allows for the expansion and contraction of the propane with changing temperatures.
Old 07-10-2017, 10:57 AM   #4
When you think about it, you don't want the liquid level too close to the outlet. You want vapor going out the pipe to the grill, not a slug of liquid, which would provide a sudden surge of fuel to the grill, maybe blowing flame all over your face!
Old 07-10-2017, 12:35 PM   #5
TheProfessor
Understand the point of the post is about weights and mathematics.
The place I go to uses both a scale and a unit counter. Gallons I think.
The screw I think is to let excess air out. But let other chime in on that.
Me, I have an extra full tank. So don't have to worry if grille tank runs out while cooking.
Old 07-10-2017, 05:27 PM   #6
RUGMAN
seems like when we swap one out at cumberland (blue rhino), there is even less propane in them than when I get the tanks filled back home.
Old 07-10-2017, 06:05 PM   #7
Yup, Blue Rhino only fills it 75% or so to be "extra safe."
Old 07-10-2017, 06:07 PM   #8
NoBozo
I think you are correct about bleeding off AIR at the top of the bottle. We always keep a spare bottle. I guess using my bathroom scale to weigh the bottle is a bit Anal...that's me.. NB
PS: NEVER lay the bottle on it's side..Always keep it VERTICAL while transporting the bottle in your car.
Old 07-10-2017, 06:39 PM   #9
SteveO123
Last time i got Blue Rhino they advertised it as 15#. I thought I was getting ripped off but maybe it was just truth in advertising! And it was actually on the 4th of July last year, 2/3 of the way into the cookout! Be prepared! I learned my lesson and keep the spare "full" or at least 3/4!
Old 07-11-2017, 09:47 AM   #10
Default Tanks are limited to 42% of liquid weight
Here is a real thorough explanation. Cant confirm if its correct but it seems reasonable.
http://modernsurvivalblog.com/preps/...ank-really-is/
Old 07-11-2017, 10:42 AM   #11
Let's examine the numbers on that URL Siksukr cited. The WC (water capacity) of the tank shown is 47.6 lb of water, specific gravity 1.0 at room temperature. At 77 F, propane's density is 0.493 (https://en.wikipedia.org/wiki/Propane). Full of propane, the contents would weigh 47.6 * 0.493/1.0 = 23.47 lb. The 42% of WC regulation would allow for 20.0 lb, which is 85% of propane capacity. The numbers all agree.
Old 07-11-2017, 02:22 PM   #12
I had a friend who had Blue Rhino tank exchange at his store. When I said that could come in handy if I ran out when the refill stations were closed (he was opened until 9pm). He told me how Blue Rhino was only filled with 15 lbs, and if I ever did run out, grab a tank at his house because BR was a ripoff. What seems like a good idea on the isn't.
Sent from my SM-T580 using Winnipesaukee Forum mobile app
Old 07-12-2017, 09:07 AM   #13
bilproject
bilproject's Avatar
The screw the filler opened is an outage gauge. It is connected to a tube in the valve that goes down to the 85% level. Gas will come out at first and when liquid reaches the end of the tube a white fog will appear out of the small hole to the outside of the valve telling the filler that the tank is full. However, all 20# tanks that are legal to fill today have an auto stop fill feature that will stop the filling at 85% or less. Sort of an idiot proof system to prevent overfills which could cause the relief valve to open if the tank became liquid full and the pressure inside reached 250 psi. There is never air in a propane tank except when new. a new tank must be purged of air before filling. If air and gas were mixed it could explode although unlikely as propane's range of flammability is about 1.9 to 2.4%.
bilproject is offline   Reply With Quote
This page was generated in 0.26980 seconds
