11-14-2014, 10:52 AM | #1 |
Pitch
Does anyone have a good method for removing pitch off a car?
11-14-2014, 10:57 AM | #2 |
Wd-40
Spray a little on the pitch, let it soak for a few minutes and wipe it off!
Unless the pitch have hardened under the direct sun, this is a safe method.
11-14-2014, 10:57 AM | #3 |
Rubbing alcohol on a rag and rub very gently in a rotational direction
11-14-2014, 11:03 AM | #4 |
There was a recent thread on the general subject:
http://www.winnipesaukee.com/forums/...hand+sanitizer I don't know if a car's finish would be different from boat cover, though. Perhaps you first should try whatever you use on a normally hidden part of the paint surface, like inside a door frame. |
11-14-2014, 06:09 PM | #5 |
Liquid Luster
I use a product called Liquid Luster it removes sap, tar and oil and it leaves a shine and is wax. Other methods remove wax from the surface. It looks like pepto bismol. I first found it at car shows but now I need to order it on line. Works great on the SeaDoo to!
11-14-2014, 07:08 PM | #6 |
I use Goo Gone.....sold every where
How to Remove Tree Sap REMOVE TREE SAP FROM FIBERGLASS, GLASS, LAMINATE, METAL, PAINTED WOOD, PLASTIC, VARNISHED WOOD, VINYL, WINDOWS, BRICK, CERAMIC, COUNTEROPS, FLOORING, GRANITE, MARBLE, STONE, TILE OR WOOD: Pretest on an inconspicuous area Apply Goo Gone Wait 1-3 minutes Wipe to remove Reapply as needed Wipe off and clean area with soap and water Use caution not to scratch the surface if a scraping tool is used Note: Use Goo Gone on non-porous surfaces only. It is safe to use Goo Gone on porous surfaces such as marble, granite, ceramic, concrete and brick only if they are sealed. If a water droplet beads on the surface, that would indicate the surface is sealed and it is safe to use cleaning products like Goo Gone on that surface without it soaking in.
“Better to remain silent and be thought a fool than to speak out and remove all doubt.” |
11-14-2014, 08:09 PM | #7 |
With a name like "Sal", you KNOW that I recommend olive oil.
Put a drop or two on the offending spot. Let it sit a minute or two, then rub it away. |
The Following 2 Users Say Thank You to Sal For This Useful Post: | ||
Airedale1 (11-20-2014), Slickcraft (11-14-2014) |
11-14-2014, 10:32 PM | #8 |
Use a little butter....rub it on and the pitch will come right off. Great when you get pitch on your hands, etc. Just a little butter and it is gone.
11-15-2014, 01:16 PM | #9 |
Vegetable oil
Any type of vegetable oil (corn, canola, etc.) also works, and with the price of butter lately, a cheaper alternative.
11-15-2014, 04:52 PM | #10 |
All good advice.....somewhat.
I was in the car detail business for years, and automotive finishes are somewhat touchy, all of those suggestions will work, but i cant promise good end results, after strong sun, salt and acid rain have their way with the finish after treating them with those things......several manufacturers Make automotive clay, this clay is re-usable and i would suggest everyone own a hunk. You simply use a bug and tar remover, made for auto finishes with this clay to pick up anything on the surface of the car, without harming the finish.......just a suggestion.
You have to go out on a limb sometimes, cause that is where the fruit is. You can't get to the fruit from that nice safe spot, clinging to the trunk of the tree...... Last edited by glennsteely; 11-15-2014 at 04:53 PM. Reason: MISTAKE |
11-15-2014, 06:48 PM | #11 |
Thanks everyone for your ideas! I will let you know if the itch comes off after I try some of these products.
11-17-2014, 02:43 PM | #12 |
Itch?Thats a lot different than pitch.First put some cream......
SIKSUKR |
The Following User Says Thank You to SIKSUKR For This Useful Post: | ||
rander7823 (11-17-2014) |
11-17-2014, 04:53 PM | #13 |
Hahahaha!!
Hehehehe!!! Siksukr strikes again......too funny!!
You have to go out on a limb sometimes, cause that is where the fruit is. You can't get to the fruit from that nice safe spot, clinging to the trunk of the tree...... |
The Following User Says Thank You to glennsteely For This Useful Post: | ||
BroadHopper (11-18-2014) |
11-18-2014, 07:02 AM | #14 |
Keep in mind unless you use something wax based already think like your also removing whatever protection (wax) you may of already had on the car. Might want to have some wax handy and just hit that spot when your finished. Personal preference I like keeping my car waxed others are like "wax what's that??"
11-18-2014, 03:45 PM | #15 |
I thought you were going to invite us to a pitch party....
11-18-2014, 03:55 PM | #16 |
gasoline works awesome
just re-wax that little spot after also works awesome on road tar
Capt. of the "No Worries" |
11-20-2014, 01:47 PM | #17 |
Electric shave! That’s all you need to know.
