Old 04-08-2012, 10:45 PM   #1
Piston
Piston's Avatar
Default Reminder to correct your BIZER charts!
Hi All,
I just got through correcting/updating my 8th edition Bizer chart (the current edition) for Winni, and thought I would post a reminder for everyone.
If you have anything later than the 8th edition it would be wise to update it to the current edition (8th-same as last year) and make the corrections listed on their website.
Also wanted to mention that keep in mind the depths listed on the Bizer chart are in reference to a lake level of 503.1' (the average lake level in October). If the lake level is not exactly 503.1', the depths will not be exact, keep this in mind. (However, it is usually within a foot so it isn't much different anyways)
This is usually less than the typical summertime level of the lake but not always. Also, some people forget that the heights listed for bridge clearances are in reference to full pool, or 504.3'. All these references come from the "zero point" of the gauge at Weirs, as stated on the Bizer chart.
The reason for the differences for heights vs. depths is to give the boater the 'most likely worst case scenerio' This way, there will usually be a little more water under your boat than the chart says, and a little more clearance for the bridge than your chart says, but of course, not always.
I'd also like to mention to everyone, that something just as important as using the chart that often gets overlooked, is to actually go through and read all the information on the chart, meaning all the little notes written on the chart. There is a lot of good information on it.
Another note, if you were blessed with a new GPS for Xmas and this is the first year your using it, be sure the datum is set correctly. Often times GPS come with the correct datum for the Bizer chart (WGS84, same as NAD83) but not always. If your GPS is set to anything but WGS84, change it! It's always prudent to double check this.
Here is a link to all the chart corrections Bizer has published since the 8th edition chart has been out. http://bizer.com/bztnews.htm#updates
Most are minor, but they are worth taking a look at. (specifically, the addition of another ice cream parlor in Center Harbor )
I'm not sure if there is a way to correct the electronic chart for our chartplotters?
If I've made any mistakes in this post please correct me.
Have a happy and safe boating season!
Piston is offline   Reply With Quote
The Following 5 Users Say Thank You to Piston For This Useful Post:
Alsobig (04-09-2012), Billy Bob (04-09-2012), mhtranger (04-09-2012), pcmc (04-08-2012), trfour (04-09-2012)
This page was generated in 0.24825 seconds
