08-30-2014, 08:07 PM | #1 |
Wood pellets?
We just purchased a used nearly new pellet insert stove. Owner demoed, and stove throws off lot's of heat !
Stove has only had 5 bags of pellets burned in it, then origianl owner decided he wanted a larger one,with more output, Harmon size ! Stove insert is a Napolean NPI-45. Any suggestions on the type of wood pellet is best to burn ? Lot of factors to consider: ash content, moisture content, , as well as options of hardwood, softwood, or a mix? I was told by many that a pellet with ash content less than 1% is best to control ash and klunkers. Also that a softewood burns hotter, but burns quickly, whereas hardwood pellets will give you a longer burn. Have found pellets at Tractor Supply Co., that are <1% ash, low mositure, and 80% (hardwood)/ 20% (softwood), at a great price ! This is a our first pellet stove as is all very confusing..... Thanks for your suggestions ! Bigdog |
08-30-2014, 08:58 PM | #2 |
We have had the same model for over six years, and is a decent stove. We have replaced minor items like the igniter a couple of times and the burning pot needs replacing this year, but it had been pretty solid and paid for itself the first year.
I get hardwood pellets if I can - less ash, but if there are pellet shortages, you buy what you can get. Buy early to be safe and to get the best prices. Last year everywhere was sold out by mid winter and word is that there will be shortages again this year. I clean the ash out about every 4 or 5 days. Daily when I add a bag of pellets, I also clean out the burning pot by tipping it into the ash pan. |
08-31-2014, 06:18 AM | #3 |
I've had a Harmon stove for about 8 years.
At first I was always trying to find the "best" pellets. Now I just dump whatever into it and it works fine. Ours is for supplemental, not primary, heating and I haven't noticed huge variances from one brand/kind to another. I do stick with hardwood pellets, but beyond that don't get caught up in the details.
[insert witty phrase here] |
08-31-2014, 06:22 AM | #4 | |
08-31-2014, 08:06 AM | #5 | ||
Blends are fine and the best pellets we ever had were softwood, higher heat output in BTUs per pound due to the resins.
Initially, as a long term wood burner, I was under the impressionism that softwood should be avoided. However unlike cord wood, pellets are dry compressed cellulose sold by the lb. So BTU/lb is what counts. Beyond that ash % and trace minerals that cause "clinkers" are considerations especially in top feed stoves. Not really an issue in our bottom feed Harman. My best advice is to try 2 bags prior to buying a ton or several. As the raw material input is variable even for the same brand, last year's winner may be this years dog. Some info here:http://www.pelletheat.com/for-consum...sumer-faq.html Quote:
08-31-2014, 01:21 PM | #6 |
Thanks everyone for your feedback, especially 'Hig' whos owns the same model pellet stove....
Not sure of Tractor Supply brand, they seem to be selling their own private brand...... See here: http://www.tractorsupply.com/en/stor...-pellets-40-lb No details given except on bag as noted previously. After doing so additional research, going to try Maine Woods and New England Hardwood brands. They have good rating, reviews, and priced resonable. Will buy a few bags of each before buying by a ton! Forecast I heard for this winter, was 'colder' than avg. but less snow. Thanks again everyone ! Bigdog |
09-09-2014, 06:27 PM | #7 |
Bigdog
As I told you before, join the forum at Hearth.com, the Pellet Mill and you won't be disappointed. Thousands of threads and posts to answer your every question. I've been a pellet burner for 18 years. Tractor Supply carries a house pellet made by Maine Wood Pellet MWP. Very good pellet for the money. BT
The Following User Says Thank You to Blue Thunder For This Useful Post: | ||
bigdog (09-09-2014) |
09-09-2014, 08:59 PM | #8 |
Wood pellets?
After some long research and not wanting to be late with my initial pellet purchase I have decided to buy some 'New England Wood Pellets".
http://www.pelletheat.com/products-a...-products.html I have heard nothing but positive feedback about these pellets, from Forums and stove dealers. Also called Napolean customer service and they basically, the stove can burn hardwood or softwod if it meets the following P.F.I. pellet stadards for my stove as follows: * Size 1/4" to 5/16" diameter, 1/2" - 1 1/2" long maximum * Ash Content 1% maximum (Premium grade) / 3% maximum (Standard grade) * Moisture Content 8% maximum * Heat Content Approximately 8200 BTU per pound minimum That said N.E. Wood Pellets fits the bill ! Thanks, Bigdog |
09-10-2014, 06:37 AM | #9 | |
BT
09-10-2014, 08:25 AM | #10 |
Thanks to everyone, especially Blue Thunder for his last comments regarding NEWP pellets.
Yes, pellet stoves are a whole new and mysterious world to me. Hopefully, after my first burning season, I'll have more knowledge about the subject. Until then everything will be experimental. At least with my wood stove fireplace insert at other property is really a no brainer! Buy good dry seasoned firewood, throw it in and burn it ! Thanks again to everyone....... |
09-11-2014, 08:38 PM | #11 |
Buying pellets can be a frustrating thing. There really is no regulations on the pellets so the info they put on bags in terms of ash content, btu's moisture etc are not always accurate. As said above try different brands and see what you like best. Then hope you can find them again. Good luck.
Thread Tools | |
Display Modes | |
