Old 07-29-2018, 09:34 AM   #1
Coach
Default Help with a 1996 Polaris SL780 jet ski
We can not get the jet ski to start like I am not getting gas. It is not turning over.
We can starter fuel to the carburetor and it will start but once it burns off it is done. It will not turn over then.
Took gas tank off and got all the old gas out.
Took carburetor off and cleaned it all out.
Put new gas pump on.
Checked all lines from gas tank to gas pump and from gas pump to carburetor.
Charged battery to full charge. Have not tried a different battery.
Checked the electrical box and the fuse appeared to be good.
Put in new spark plugs in.
What am I missing please?
Coach is offline   Reply With Quote
Old 07-29-2018, 11:57 AM   #2
Outdoorsman
Not to be a wise guy, but did you check the fuel shut off valve?
Did you replace the fuel filter?
Did you check to see that the new spark plugs are actually sparking?
Outdoorsman is online now   Reply With Quote
Old 07-29-2018, 02:37 PM   #3
Coach
Any assistance is appreciated.
The fuel valve is on. The spark plugs were firing.
We have not changed out the fuel filter yet.
Old 07-29-2018, 02:57 PM   #4
Does the carb have gas in it?
Old 07-29-2018, 03:22 PM   #5
If the carb has gas in it check to see if you are getting compression and check that air is sucking through the carb. I suspect, if gas is getting to the carb, that the reed valve(s) are sticking or broken. But you need to confirm, you should have been able to see the reed valves when you took the carb off. Also when you said you cleaned the carb, did you blow carb cleaner through the jets and passages to make sure they are clean and clear? I wouldn't buy any more parts until you figure out what is wrong.
Old 07-29-2018, 06:33 PM   #6
Coach
We did blow/clean out carb.
The reed valve looked good.
We are not getting gas to the carbs.
Old 07-29-2018, 08:06 PM   #7
Formula260SS
Formula260SS's Avatar
Fuel Pump not pumping maybe?
Old 07-29-2018, 08:54 PM   #8
Poor Richard
Poor Richard's Avatar
Ensure your filler cap if sealing properly.
The fuel tank needs to be pressurized and a leaking filler cap seal will prevent this which will result in your exact symptom.
This page was generated in 0.66193 seconds
