Old 04-03-2020, 10:30 AM   #1
Default Marine Grease?
I need to grease both my trailer hubs, and the grease fittings on my Outdrive, can I use the same type grease for both ?
Old 04-03-2020, 10:39 AM   #2
Now you're going to start trouble! I am on a ton of FB antique motorcycle pages and whenever oil comes up... wow opinions vary!
I like using Merc 2-4-C on boat stuff, but if I had to I would squirt in some good high temp wheel bearing grease. I use the premise that I would rather have the wrong oil, than no oil!
Edit note- the 2-4-C can be used in your wheel bearings.
Old 04-03-2020, 10:50 AM   #3
Yes, use a good quality MARINE grease.
Here’s what I use in all my trailers.... https://www.lowes.com/pd/Lucas-Oil-P...rease/50353742
bigdog (04-03-2020), Top-Water (04-03-2020)
Old 04-03-2020, 11:25 AM   #4
I'm assuming that this Lucas grease can be used on the Outdrive Zerk fittings, as well as the prop spline ?
Thanks Dan !
Old 04-03-2020, 11:28 AM   #5
Anything that goes under water needs marine grease. But if you're buying a tube of marine grease you might as well use it everywhere on a boat, even above the water line.
Old 04-03-2020, 11:51 AM   #6
Thanks Dan !
Yes it can...
Old 04-03-2020, 01:56 PM   #7
For the outdrive it is always best to refer to your manual. 2-4-C as mentioned is very good. I have a Volvo Penta with an exterior fitting that goes right into the gimbal bearing. Very nice feature.
Old 04-03-2020, 02:17 PM   #8
WJT2
Default Always good to check
According ti QuickSilver web site you are good to go! NLGI 2 approved rating.
WJT2 is offline   Reply With Quote
This page was generated in 0.44936 seconds
