Old 05-19-2019, 08:40 AM   #1
Pricestavern
Pricestavern's Avatar
Default Island Plumber Required
We are in need of a plumber to come out to Rattlesnake and fix our water pump. Pump runs fine but won’t turn off. No leaks, holds it’s pressure, no air, no idea. Bad pressure switch?
Anybody have recommendation for a plumber who can come out (must have own transportation)?
Old 05-19-2019, 12:06 PM   #2
JEEPONLY
I have an above-ground well water pump. There is a small, flexible plastic tube running to the pressure switch from another part of the pump- runs horizontally to the switch. The tube (not sure of the inside diameter-maybe 1/8 inch) is less than 6 inches long. Available at any hardware store.
Easy (homeowner) fix, if this is the problem.
Hope this helps.
Old 05-19-2019, 02:39 PM   #3
The Real BigGuy
I had a problem with mine running and rapped the pressure switch box and it shut off. I think I hit the open electrode faces with a very fine sand paper and it has been running fine since. My pressure switch is right at the pressure tank.
Old 05-30-2019, 01:24 PM   #4
fireman
Could be pump fins bad Seen it before......usually older pumps..
Sent from my SM-G960U using Winnipesaukee Forum mobile app
fireman is offline   Reply With Quote
Old 05-30-2019, 01:29 PM   #5
fireman
We also thought it was the switch......even bought a new one and didn't fix it....spoke to my brother in law (plumber) explained issue and tested items and he said pump issue was the most likely culprit...purchased and replaced problem solved
Old 05-31-2019, 09:46 AM   #6
Pricestavern
We replaced the switch which did not help. I'm guessing that there is a problem with the impeller fins not generating enough pressure to reach cut-off.
We're going to be looking for an island plumber to come out and change our the pump for us. I could probably do it but will take 5x longer and at great personal consternation and embarrassment as I fumble my way along.
Old 05-31-2019, 10:08 AM   #7
Try Rob Bell. Not sure if he has a boat or not, but I know he will do island work time permitting. I am sure he can arrange something.
Old 05-31-2019, 12:45 PM   #8
bkelly13
Default Plumber
Paul with http://www.islandservicecompany.com is very good and has his own boats. Hope that helps.
bkelly13 is offline   Reply With Quote
This page was generated in 1.33140 seconds
