Old 10-18-2006, 07:35 AM   #1
feb
Default Help with Cost Estimates
As someone said here recently, this place is better than Google.....
I am toying with the idea of tearing down my 50 year old seasonal cottage and putting up a smaller (say 2000 sq/ft) permanent home. I have 1/2 an acre with 1/4 clear and 1/4 wooded. I would need to impede into the wooded section a little bit I suspect.
I have absolutely no idea what some items such as designing a new septci and installing, architecture fees, selectively clearing 1/4 acre for construction leaving as many trees as possible, drilling a new well. Would also be interested in typical cost per sq/ft for a regular framed house, not timber frame or anything out of the ordinary.
If anyone has any idea what these types of tasks would cost, could you please share . Any numbers, estimates, previous experience, etc. would be appreciated. I'm just curious if we're talking 5k, 10, 50k, or 1000k. I'm trying to draw up a budget to see if it's doable or not.
Thank you.
Old 10-18-2006, 08:21 AM   #2
Smile While you're "toying"...
Two possible budget-saving alternatives have been done in my neighborhood in the past year:
1) Build a second, winterized, floor on top of the existing structure. (This was done to a 60-year-old cottage with a marginal concrete-block basement).
2) Lift the entire existing structure, and put a poured concrete basement under it. (Only $50K—and also a 60-year-old existing cottage—I may have this done to my cottage).
Both turned out beautifully. If no additional bathrooms are added, the existing septic may get OK'd.
Also, new construction may limit the number of seasons that you can use it while it's under construction. For example, a "new" house next door is still not finished, and next season will be its fourth year "under construction".
Old 10-18-2006, 09:11 AM   #3
Paugus Bay Resident
Paugus Bay Resident's Avatar
In terms of new construction, it depends on three things:
1 - the site (i.e., how easy is it to work on, what site work needs to be done, etc.)
2 - the amount and type of square footage (a 2000 SF rectangle will cost less to build than a 2000 SF hexagon)
3 - the level of fit and finish you want (from the heating system, coutertops, flooring, fireplaces and on and on)
All that being said, typical stick frame on the low end, around $100 per SF. You should be able to get decent fit and finish for $125, but as I mentioned it all depends.
We often start with the customer's budget and work backwards. PM me if you need some specifics. I've got quite a few estimates that I can share.
Old 10-18-2006, 12:07 PM   #4
Weirs guy
Weirs guy's Avatar
Not sure how you feel about modular or log cabin kits, but there may be some time and money saved there. Acres per Second also raises some good options, a lot of the older cabins at the Weirs get the basement and insulation redo with good results, plus you don't need to learn your way around a new house!
Is it bikeweek yet?
Now?
Weirs guy is offline   Reply With Quote
Old 10-23-2006, 06:22 AM   #5
cappy56
do yourself a big favor , first talk to your building inspector , zoning , to see if you can do what you want to do . this has to be done first and it's free !
good luck cappy56
cappy56 is offline   Reply With Quote
This page was generated in 1.86026 seconds
