Old 07-05-2018, 06:25 AM   #1
Default Forced hot air cleaning.
Who around Moultonborough is there to do a duct cleaning on a forced hot air heating system? Thanks...
Old 07-05-2018, 02:05 PM   #2
FYI - If your duct sections are wrapped in white cloth tape, that may be asbestos. The cleaning company my wife called, refused to touch it. Said it was cheaper to cut out and replace the ducts than to do asbestos remediation.
Old 07-10-2018, 06:36 AM   #3
Ducts are not wrapped nobody out there does this??? House has never had this done that I know of anyway, definitely want them done by the fall.
Old 07-10-2018, 07:51 AM   #4
Originally Posted by dpg View Post
Ducts are not wrapped ...
I have an old house and I've seen it in new buildings too. It prevents air from leaking past the joints in places you might not want drafts. That's why they invented duct tape. It will also keep fumes out of the system if your ducts pass though a work shop or garage.
This is probably not a critical need. Tape probably adds a slight bit of stiffness at the joint but the hangars can probably do that job, alone.
Definitely get the job done before it gets cold. Good luck!
Old 07-25-2018, 11:13 AM   #5
Hmmm does nobody do this cleaning service?
Old 07-25-2018, 11:18 AM   #6
joey2665
joey2665's Avatar
I had a quote a few years ago from Laconia Refrigeration. 2800 sq ft home was 1,000.00. Way tooo expensive
joey2665 is online now   Reply With Quote
This page was generated in 0.58486 seconds
